Old Mar 23, 2009, 11:29 PM
vortices's Avatar
Joined Sep 2006
EDF vtol..most successful
VTOL 4X EDF (4 min 3 sec)
Hello, can the inventor of the edf in this video share his set up. I think he has achieved a break thru. Feedback would be much appreciated.
The stability demostrated is second to none, considering it was flown outdoors. No oscillation whatsoever was observed.
Feed back would be appreciated.
Kevin
Singapore
vortices is offline Find More Posts by vortices
Old Mar 23, 2009, 11:53 PM
capt's Avatar
Nevada, USA
Joined Sep 2007
Way cool! sure looks like fixed EDF's with thrust vectoring paddles. I count 4 batts. 3s or 4s.
capt is offline Find More Posts by capt
Old Mar 24, 2009, 01:21 AM
capt's Avatar
Nevada, USA
Joined Sep 2007
another tri-fan
http://www.rcgroups.com/forums/showt...ight=tricopter
Tricopter Test Flight (1 min 19 sec)
Old Mar 24, 2009, 05:59 AM
VTOLicious's Avatar
Austria
Joined Oct 2007
Detailed description of likais 4EDF-VTOL HERE
Regarding EDF-VTOLs:
The Tricopter uses the Wemotec Mini fan 480 each with a Typhoon 2w-20 motor providing the power. Two 3300mAh lipo’s in parallel.
Unfortunately, tests were to prove that the power requirements left us with about 5 minutes total duration time even before a payload was fitted.
This is a good example how inefficient EDFs are for static thrust applications.
Anyways, it looks cool!
Rgds Michael
VTOLicious is offline Find More Posts by VTOLicious
Old Mar 24, 2009, 10:44 AM
vortices's Avatar
Joined Sep 2006
thank you. thru reading thru the thread I think I have found my mistakes. basically I have everything but wrong settings and wrong gyro mode. will try again.
Build Log My Attempt At EDF VTOL Lewist Electric Ducted Fan Jet Talk 77 Apr 15, 2012 04:00 PM
Discussion EDF Vtol Jet Lewist VTOLs 18 Dec 28, 2006 07:12 PM
My most successful thread Miami Mike Life, The Universe, and Politics 3 Oct 29, 2003 09:34 AM
What is the most successful method of antenna shortening? sizam Parkflyers 58 Mar 30, 2003 10:37 PM
EDF VTOL Project blswinney Electric Ducted Fan Jet Talk 14 May 19, 2001 06:36 PM
