Old Mar 23, 2009, 10:06 AM
donjiskra is offline
Find More Posts by donjiskra
WAA-08 Pilot Eventually
donjiskra's Avatar
Darien,IL,USA
Joined Jul 2000
Aurora 9 & Two Motor Differential Thrust
Hello Don,
The Aurora will be able to accomplish what you are looking to do. Our terminology might be different, but it is definitely capable.
Thank you,
Billy Tompkins
Customer Service Rep.
Hitec RCD, LLC
FOR DETAILS ON THIS NEW HITECH TRANSMITTER GO TO:
http://www.rcheliresource.com/detail...-radio-system/
donjiskra is offline Find More Posts by donjiskra
Old Dec 25, 2009, 08:13 AM
parkcityskier is offline
Find More Posts by parkcityskier
Parkcityflier
parkcityskier's Avatar
Park City, UT, USA
Joined Aug 2001
Differential thrust with twin motor model
Mike, I understand that the Aurora 9 can mix rudder and throttle for differential thrust with a twin motor model with two ESCs but the manual does not address this. Would I just select "dual engine" for engine type and then mix rudder to throttle with rudder being the master? Being able to have the capability to do this was the primary reason that I purchased the A9.
parkcityskier is offline Find More Posts by parkcityskier
Old Dec 26, 2009, 10:42 PM
Parkcityflier
Park City, UT, USA
Joined Aug 2001
Well, it appears that the A9 program is very intuitive after all. I worked my way through it and the Tx is programmed for two motors and differential thrust. A great RC Tx!
Discussion Hitec Aurora 9 Transmitter prondel Radios 26229 Yesterday 11:49 PM
