Old Mar 23, 2009, 06:10 AM
nodirbek13 is offline
Find More Posts by nodirbek13
Denmark
Joined Aug 2005
Question
What's the largest UAV you built?
Hi
And how heavy is your non-flight essential gear, if any used?
I'm working on a pano pan&tilt for a 2.5-3kg cam&lens (initially to be mounted on a blimp) so would be nice to hear if you flew with that load of photo/video gear.
The current thread for the tilt assembly is at Builders Workshop, and it's a bit raw at the moment.
PS: yes it would be quite dangerous to put up decent dslr and lens on an ordinary model, but it's not a much higher risk, compared to flying those pimped UAVs with expensive electronics and passion put into them.
nodirbek13 is offline Find More Posts by nodirbek13
Old Mar 23, 2009, 12:00 PM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
48"
w/250mah 9oz
w/2200mah 13oz
w/photovoltaics+250mah 15oz
camera 1.8 grams
XBee plane tracker 4.9 grams
Originally Posted by nodirbek13
Hi
rich smith is offline Find More Posts by rich smith
Old Mar 26, 2009, 02:12 PM
icebear is offline
Find More Posts by icebear
icebear's Avatar
Helsingborg, Sweden
Joined Sep 2001
Mountain Models Tyro 150
55"
AUW 35 oz (with 3S2500 pack)
42 oz (with 3S4200 pack)
camera/payload capability 16 oz so sorry no DSLR's here either...
/Icebear
icebear is offline Find More Posts by icebear
Old Mar 26, 2009, 03:56 PM
Denmark
Joined Aug 2005
55"
/Icebear
That's a bit less than half a kilo for gear, right?
Very good, given the size of the model.
Old Mar 30, 2009, 06:45 AM
icebear is offline
icebear's Avatar
Helsingborg, Sweden
Joined Sep 2001
Yes, or 454 grams to be exact.... Not that I have estimated payload that accurately...
The Tyro 150 i very light and yet strong so with an extra pound it still flies comfortably.
Old Mar 30, 2009, 09:38 AM
ShadesOfGray is offline
Find More Posts by ShadesOfGray
Atlanta, GA
Joined Dec 2007
We've got a senior telemaster (8' wingspan) that we use to test-fly our equipment.... To date we've loaded it up with a 500 MHz single board computer, two cameras, a wifi connection to the ground, GPS, and some other random stuff. Soon we'll be adding a pitot-static system and 3-axis information (angle roll rate sensors and linear accelerometers)....
Once all that stuff is ready, it's being put onboard our 58" scratchbuilt UAV.
http://www.vanderbilt.edu/USLI/
ShadesOfGray is offline Find More Posts by ShadesOfGray
Old Mar 30, 2009, 12:30 PM
jtprouty is offline
Find More Posts by jtprouty
Inherent Tinkerer
Wichita, Kansas, USA
Joined Jul 2003
Vector P (designed and built the proto and molds for the original Vector P UAV.)
101" and 55 pounds wet. Great flying plane IMHO.
Jimmy
jtprouty is offline Find More Posts by jtprouty
Old Apr 01, 2009, 04:41 AM
Blunderbum is offline
Find More Posts by Blunderbum
Australia
Joined Feb 2007
Aus-sky (designed and built by us at Avitus UAV Systems)
144", 20kg payload, full composite, hollow core wing.
Very stable platform.
Blunderbum is offline Find More Posts by Blunderbum
Old Apr 01, 2009, 04:47 AM
Denmark
Joined Aug 2005
That's more inspiring
Old Apr 01, 2009, 04:51 AM
Denmark
Joined Aug 2005
Jimmy
Blunderbums 144" is carrying 20kg, how did you manage to get 24kg with just 101" wings? is the wing surface huge?
for a while, it had doubts i wont even see a hobby plane to mount a DSLR on, lol
Old Apr 01, 2009, 05:04 AM
Airboatflyingshp is offline
Find More Posts by Airboatflyingshp
Airboatflyingshp's Avatar
B'ham UK
Joined Oct 2005
Check out the vintage Guff and Radio Queen designs.... the latter was the first plane to cross the English channel and the first to fly with a huge electric motor and the battery payload was massive for a stick built model and it landed in one piece.
Airboatflyingshp is offline Find More Posts by Airboatflyingshp
Old Apr 01, 2009, 08:06 AM
CenTexFlyer is offline
Find More Posts by CenTexFlyer
Near Austin
Joined Dec 2001
96" Spectra flying wing
O.S. 1.2 converted to gas
Bungy launched
13 pounds AUW
8 lbs fuel and payload
Design won the USAF Texas Challenge between Univ. of Texas and Texas A & M for 24 hour persistent surveillance UA.
CenTexFlyer is offline Find More Posts by CenTexFlyer
Old Apr 01, 2009, 07:55 PM
Aerofoam is offline
Find More Posts by Aerofoam
Always Tinkering
Aerofoam's Avatar
United States, AZ, Tucson
Joined Jan 2005
Sort of Large UAV's
130lb., 12' span UAV's are the largest I have built, the current version
is still a 12' span but has trimmed down to 60lbs. to 65lbs. wet with a 30lb. payload. It is launched by bungee or rail.
M.M.
Aerofoam is offline Find More Posts by Aerofoam
Old Apr 02, 2009, 12:07 PM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
The wings are fairly thick and have flaperons as well as flaps. Surprisingly enough, the plane floats on landing and is actually enjoyable to fly.
Jimmy
www.hangar18uav.com
Old Apr 06, 2009, 12:36 AM
EddieWeeks is offline
Find More Posts by EddieWeeks
EddieWeeks's Avatar
Baton Rouge, LA, USA
Joined Dec 2001
All RC... 2 x 28 lb turbines... 14lbs of fuel good for 10min..
Eddie Weeks
EddieWeeks is offline Find More Posts by EddieWeeks
What's the cheapest thing you ever flew? sarge Parkflyers 36 Jul 13, 2008 09:21 PM
What's the largest/heaviest airplane you've flown on KP00? iter Scratchbuilt Indoor and Micro Models 3 Feb 16, 2005 01:10 AM
what's the weirdest foamy you've ever seen? TheAtomicMan Foamies (Kits) 7 Oct 25, 2004 11:32 PM
Axi 2820/10 Motor: What's the smallest plan you guys have packed these into? kbw99 Electric Sailplanes 16 Apr 09, 2003 08:20 AM
Just For Fun.. What's the smallest space you fly in??? boomerace Parkflyers 27 Oct 21, 2002 04:51 PM
