Old Mar 22, 2009, 08:55 PM
the_canuck is offline
Find More Posts by the_canuck
Where's the wind?
the_canuck's Avatar
United States, CO, Denver
Joined Jun 2004
The Bad Voodoo ODR
Here's my latest build I've been working on.
The Bad Voodoo by Eaton Air RC. http://www.eatonairrc.com/home/theBadVoodoo.php
The quality of the parts are top notch. Eric did a great job of finishing the wing and tail feathers which was unexpected. His covering jobs are a thing of beauty.
The fuse I got was a blemish one but still looked great. With a bit of sanding, some high build primer and a couple spots of Bondo everything looked nice and smooth. It took about 1 hr to get the fuse ready and painted.
The wings are balsa sheeted foam core. Eric told me where to find the wire channels and I cut slots for HS5085 servos. I potted the servo's with 5min epoxy and micro balloons. The servos are slightly thicker than the wing but easily fixed with servo covers.
Next was the tail feathers. I set up incidence to zero zero and epoxied on the tail after a few quick measurements to make sure the tail was true.
For the wing to fuse joint, I chose to use nylon bolts and thread inserts. First I installed a plywood former inside the fuse surrounding the wing saddle area. This gives the fuse extra strength and allows use of brass threaded inserts instead of blind nuts.
Things left to do:
1. Battery, RX, elevator Servo in the fuse
2. Aileron linkages for the wing.
3. Trick graphics from my Vinyl cutter.
4. Balance and test fly.
I also plan to add fuse ballast plates just incase we have good conditions at MWSC this year.
Andrew
the_canuck is offline Find More Posts by the_canuck
Old Mar 23, 2009, 12:21 PM
windsinface is offline
Find More Posts by windsinface
windsinface's Avatar
United States, KS, Hays
Joined Jan 2007
Looking Good ,Can't wait to see her with graphics on.see you at the finish line. Erik
windsinface is offline Find More Posts by windsinface
Old Mar 23, 2009, 09:06 PM
wavebuff is offline
Find More Posts by wavebuff
wavebuff's Avatar
McPherson, KS
Joined Mar 2005
Sweet! Nice covering Eric! Any chance making a run to Kansas anytime soon?
Chance
wavebuff is offline Find More Posts by wavebuff
Old Mar 23, 2009, 10:20 PM
Where's the wind?
the_canuck's Avatar
Joined Jun 2004
Probably won't make it to KS till the event unless there's an F3F race before the event.
Andrew
Old Mar 24, 2009, 12:58 PM
Joined Jan 2007
Here are a few pictures of the Voodoos little brother, a 48 in. and a mg 06 taper in a 48in should have them in mid summer on site.
Old Mar 26, 2009, 07:40 PM
relaxnfly is offline
Find More Posts by relaxnfly
relaxnfly's Avatar
Knoxville, TN, United States
Joined Jan 2004
That 48 incher looks nice! The Bad Voodoo and more of Erik's planes are also available through
http://www.magnumrcmodels.com/
relaxnfly is offline Find More Posts by relaxnfly
Old Mar 28, 2009, 12:06 PM
ouluckydogu is offline
Find More Posts by ouluckydogu
Joined Feb 2004
I am waiting for one of these, the prototype looks great.
Lucky
ouluckydogu is offline Find More Posts by ouluckydogu
Old Mar 30, 2009, 08:48 AM
Where's the wind?
the_canuck's Avatar
Joined Jun 2004
More info found on The Bad Voodoo in Feb. 2009 Soaring Digest
http://www.rcsoaringdigest.com/pdfs/...SD-2009-02.pdf
Old Mar 30, 2009, 07:28 PM
Jack B is offline
Find More Posts by Jack B
Jack
United States, NE, Lincoln
Joined Dec 2005
I don't have a Voodoo yet, but i do have one of Eriks Dusters. its a great plane. highly recommended. The Duster has an EPP fuse.
Jack B is offline Find More Posts by Jack B
Old Apr 05, 2009, 10:58 AM
Eternalflight is offline
Find More Posts by Eternalflight
"I want more air time!"
Eternalflight's Avatar
Joined May 2008
I am moving slow on building the Voodoo. Will try to finish the wing this week.
I hope!
I have been enjoying flying Erik's Thunder Storm.
EF
Eternalflight is offline Find More Posts by Eternalflight
Old Apr 05, 2009, 02:24 PM
Joined Jan 2007
Looking good Ken.Can't wait to see it finished . Hope you come out soon. Erik
Old Apr 06, 2009, 09:12 PM
Joined Jan 2007
Waiting for test flight pictures.
Old Apr 10, 2009, 09:50 PM
corsha99 is offline
Find More Posts by corsha99
launch height can't fix stupid
United States, CA, Palmdale
Joined Jun 2005
Look what showed up
Thanks Andrew for letting me hijack your thread.
I call it the Bad Voodoo light. Eric special made one that will build out on the very light side of the weight requirement. Balsa sheeted white foam core wings with hardwood leading edge already installed. Unpainted fuselage. Tail group is plenty thick to do some advanced shaping with it to reduce drag. Vertical is reinforced with really thin plywood installed in a groove at the bottom of the tail.
Plan on putting in a 4 cell AAA pack, electron 6 reciever and 3 DS09AMD servos. Will paint the fuse ever so lightly. Thinking of trying to install the wing servo connections such that the flaperons are top driven from a bottom installed servo. Worst case will be bottom driven with larger covers.
Meanwhile, enjoy the pics.
Cory
corsha99 is offline Find More Posts by corsha99
Old Apr 10, 2009, 10:07 PM
Where's the wind?
the_canuck's Avatar
Joined Jun 2004
I hope to maiden mine tomorrow if the wind is right for powerlines.
See ya on the slope!
Andrew
gotta remember to glue in my servos.
