Old Jun 11, 2001, 05:19 PM
Looooeeee! is offline
Find More Posts by Looooeeee!
Heli Bouncer
Looooeeee!'s Avatar
At the Discount Clambake
Joined Feb 2001
Trying out Motocalc, some questions...
Hi all
I'm trying the 30 day motocalc offer and I'm already really impressed with the results. It's almost as addictive as the E-Zone..
Any-way the questions are such.. Is there be a way of figuring out how weird custom winds would run, such as five pole vs. three pole, armature diameter adjustments and GWS slow flyer motor constants, plus how do the conversions of previous bushing bearings to BB, (like the Mag Mayhem) effect the motor's efficiency.
I guess I should be asking Stef about this but I'd like to ask anyone who's done some filter adjustments in their's.
Thanx in
advance
Looee
Looooeeee! is offline Find More Posts by Looooeeee!
Old Jun 11, 2001, 05:32 PM
radix2 is offline
Find More Posts by radix2
Radix malorum est cupiditas
radix2's Avatar
Joined Jul 2000
Looee,
There really is no way to predict the effect of many of the parameters you mentioned, for that you would need a motor design analysis program(and the results would be of little benefit without a way to fabricate the proposed designs)
Motocalc is based on the gross behaviour of the motor as reflected in the Kv and resistance, so by knowing the effect on these parameters of a proposed change - like should I use the 5 or 6 or 7 turn motor, you can plug the motor constants in and get your answer.
For things like number of poles, diameter, etc, there is no general conclusion that can be made on how this will effect the motor constants, so motocalc can't help.
radix2 is offline Find More Posts by radix2
Old Jun 12, 2001, 01:10 PM
stefanv is offline
Find More Posts by stefanv
MotoCalc Developer
stefanv's Avatar
Moorefield, Ontario, Canada
Joined Mar 2001
You're probably already aware of this, but just in case you overlooked it...
The only thing MotoCalc has in the way of motor design features is the ability to change the number of windings, leaving all else the same. Just click the Design button in the Motor pane.
stefanv is offline Find More Posts by stefanv
Tried out my heli today - some observations and some questions lopsided Micro Helis 12 Dec 08, 2004 02:22 PM
Setting up my second Adrenalin, some questions... Erik Johansson High Performance 0 Jul 01, 2001 04:45 PM
Before buying the Stick, some questions... Magna Parkflyers 4 Jun 26, 2001 01:29 AM
Ok, I got my brushless setup, I have some questions: jhudak7 Electric Heli Talk 3 May 25, 2001 07:35 PM
I got my LMH!!!!!! + some questions. Lucas in Alaska Electric Heli Talk 5 Apr 25, 2001 07:01 PM
