Old Mar 21, 2009, 10:25 PM
chancesAU is offline
Find More Posts by chancesAU
chancesAU's Avatar
Australia
Joined Apr 2008
Cool
Ardupilot V2.0 test flight movies - Now with onboard Video
Hi,
Just got the maiden done for my ardupilot v2.0, just thought id share my quick video.
ArduPilot v2.0 maiden flight (1 min 5 sec)
All in all very impressive considering there was around 15knot winds.
Max
chancesAU is offline Find More Posts by chancesAU
Old Mar 21, 2009, 11:00 PM
zlite is offline
Find More Posts by zlite
Chris Anderson
San Francisco/Bay Area
Joined Mar 2007
Originally Posted by chancesAU
Hi,
http://www.youtube.com/watch?v=IvR3QM0iTPw
Max
Looks good! That is indeed a big rudder--I think that wobbling is saying you need to bring the gains down a bit ;-)
zlite is offline Find More Posts by zlite
Old Mar 22, 2009, 08:03 PM
dmgoedde is offline
Find More Posts by dmgoedde
Joined Aug 2007
I've seen the same wobble in other motor gliders with only rudder. You'll do well to just reduce the roll response gain to about 2/3 of current value. I also suspect that part of the issue is that the "closed loop" feedback between roll axis sensing and rudder control is partly not so closed loop; rudder does not directly modulate roll nearly so clean as ailerons would. This is why with AttoPilot I don't recommend to use it on planes lacking ailerons, and even went so far as to joke that I am anti-motor glider. Tha was a joke, and several people have used thermopile Atto with motor gliders to great success.
congratulations! That's a peppy little platform.
dmgoedde is offline Find More Posts by dmgoedde
Old Mar 22, 2009, 08:12 PM
zlite is offline
Chris Anderson
Joined Mar 2007
I'm sure that's right, and we get much cleaner performance with the Funjet, which does have ailerons (but is harder to fly in RC mode, which is why we released the EasyStar version first). Next week we'll release the ArduPilot 2.1 code, which uses the Z sensor. We get much better linear response with that, and it will help dampen the overcontrol, too.
Old Mar 22, 2009, 09:22 PM
Mick Molloy is offline
Find More Posts by Mick Molloy
MINE!
Mick Molloy's Avatar
Australia, VIC, Point Cook
Joined Jul 2003
Hi,
Max
Congrats on the first flight Max
I hope to have my Ardupilot in the post box today, I ordered it on the 10-3-09 so it should be here by now..
Mick
Mick Molloy is offline Find More Posts by Mick Molloy
Old Mar 22, 2009, 11:22 PM
chancesAU's Avatar
Australia
Joined Apr 2008
Mick
Thanks Mick,
Yea I paid $22usd from both sparkfun & FMA to get them here with UPS express... I hate waiting!
Let me know how you go, im eagerly awaiting v2.1
Old Mar 22, 2009, 11:32 PM
MINE!
Joined Jul 2003
Thanks Mick,
I paid the extra also..
Will have to cath up for an Ardupilot flyin ..
Mick
Old Mar 24, 2009, 01:10 AM
chancesAU's Avatar
Australia
Joined Apr 2008
My Ardupilot v2.0 code mod's
After the 1st test flight and seeing the plane wobble too much ive edited the code to make the following changes...
Original code
#define roll_P .8 //roll PID proportional
Rudder to sensitive
1st test
#define roll_P .5 //roll PID proportional
No wobble at all but wont turn...
2nd test
#define roll_P .65 //roll PID proportional
Still too sensitive but much better then .8 & seems to turn with alot of authority, would roll violently in the cross wind (was about 10-20knots) but would always level out.
Ill have to go down 1st thing in the morning when there is no wind, might also drop it down to .6 and see how it flys.
Max
Old Mar 24, 2009, 02:07 AM
_helitron_ is offline
Find More Posts by _helitron_
Multicopter/FPV/UAV/HAM
_helitron_'s Avatar
Austria, Stmk., Neudau
Joined Jun 2006
Hi,
how about adding some (two) little minipots/trimmers (adjustable resistors) to the free analog in for adjusting the most important PID params ? I'd put a little scale around the pots with min and max values and some points and would attach it reachable somewhere in the cockpit or on the outside of the plane. Only my 2cts.
I'll try to add this to my ArduPilot for the maiden next weekend.
Erwin
_helitron_ is offline Find More Posts by _helitron_
Old Mar 24, 2009, 08:35 AM
chancesAU's Avatar
Australia
Joined Apr 2008
Originally Posted by _helitron_
Hi,
Erwin
I wish I could do that, I got some ideas too but im going to try and do it myself & see how hard it is...
Also going to get a camera on the plane asap so I can record from the cockpits perspective, should be easier to see what its doing... plus then I dont need someone pointing the camera for me from the ground
Old Mar 24, 2009, 10:25 AM
_helitron_'s Avatar
Joined Jun 2006
Good luck furthermore, Max !
Erwin
Old Mar 26, 2009, 12:53 AM
chancesAU's Avatar
Australia
Joined Apr 2008
Update on my test flights.
#define roll_P <b>.6</b> //roll PID proportional
This is what im leaving it on I think as it seems to turn good and not wobble so much. (looking from the ground)
Couple of problems, the RTL mode works good but the plane seems to come back over the top and then keep going, I would have thought it would start to circle over top?
It has been very windy so I need to try this in calm weather *looks out the window* possibly this afternoon, if not tomorrow.
Ive got 2 new videos to show, both showing the effects of the changes in the code.
1st video is from the ground & 2nd video is onboard the plane.
From the ground
3rd Test with the ardupilot V2.0 in my Easystar (2 min 21 sec)
Onboard video
4th Test with the ardupilot V2.0 in my Easystar - onboard video (2 min 16 sec)
Max
Old Mar 26, 2009, 06:25 AM
MINE!
Joined Jul 2003
Max great work I see your using a black stork too, what camera and tx r u using
I was going to solder up my Ardu tonight but am stuck fixing a timing belt issue on the mrs car...
Old Mar 26, 2009, 07:54 AM
chancesAU's Avatar
Australia
Joined Apr 2008
Hey thanks Mick, camera is a kx191 and the TX is a 500mw immersionRC 2.4gig.
For that flight I was using a snazzy little 3db linksys wifi antenna with a connector to suit on the plane and on the ground I had a 5db "netgear" omni on 1 foot of shielded cable laying flat on the bonnet of the van.
Was really surprised with the quality of the link for how it was setup, I dont have my patch antenna at the moment
Perhaps we can meet up for a fly tomorrow?? Ive been talking to Chris & he is keen
Old Mar 26, 2009, 07:59 AM
MINE!
Joined Jul 2003
Sounds great
Discussion Parachute test flight movie. wep FPV Talk 3 Jul 01, 2008 12:16 AM
Discussion Micron V2 Test Flight cheekid Micro Helis 1 Oct 02, 2007 07:41 AM
Discussion FMS v2.0 Alpha8.3 Flight Sim Models Questions Crash-n-Hard Simulators 1 Jun 08, 2007 11:34 PM
GOLIATH maiden and flight test results Joe Ford Foamies (Kits) 7 Feb 20, 2005 08:30 PM
