Old Feb 16, 2011, 11:03 AM
Sir Dumb Thumb is offline
Find More Posts by Sir Dumb Thumb
Old Prop Buster
Sir Dumb Thumb's Avatar
United States, CA, Grass Valley
Joined Dec 2009
Paper
Bakon:
I use straight water. The trick for me is to let it dry totally and then it peels off pretty easy.
Sir Dumb Thumb is offline Find More Posts by Sir Dumb Thumb
Old Feb 16, 2011, 09:47 PM
SNice is offline
Find More Posts by SNice
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
rubbing alcohol! works like a charm... wipe it on one side, by the time you do the other side, the first side is ready to peel. Paper comes off clean and in one piece.
SNice is offline Find More Posts by SNice
Old Feb 16, 2011, 09:55 PM
bbjsw10 is offline
Find More Posts by bbjsw10
I crash planes
bbjsw10's Avatar
USA, OH, Findlay
Joined Apr 2010
I usually don't even wait that long, wipe on peel off. I leave paper on until after I have the parts actually cut out as well.
A bottle of rubbing alcohol usually does atleast 8-10 sheets for me. I dump it onto a paper towel then rub the paper with it. $1/bottle at $tree plus I like how it smells,
bbjsw10 is offline Find More Posts by bbjsw10
Old Feb 16, 2011, 10:28 PM
kennyt is offline
Find More Posts by kennyt
aka "wildhover" Semper Fly
kennyt's Avatar
southern cali
Joined Sep 2007
i had an interesting idea about a bunch of us emailing rediboard to see if they can start selling foam sheets without the paper. I'm sure that if they got enough people asking, then they would realise that the rc community could be a big paperless foam boards market for them.
kennyt is offline Find More Posts by kennyt
Old Feb 16, 2011, 10:31 PM
SNice is offline
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
Yes -- I cut out all my parts first too! i've also found that centerlines and reference marks drawn onto the paper with a ball point penn will bleed onto the foam with the alcohol too -- an added bonus!
Old Feb 16, 2011, 11:04 PM
RogueTitan is offline
Find More Posts by RogueTitan
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
I kind of like the paper on It protects the foam underneath besides if you use the awesome it peels right off.
RogueTitan is offline Find More Posts by RogueTitan
Old Feb 16, 2011, 11:06 PM
Foam Av8r
RogueTitan's Avatar
Joined Sep 2008
it is harder to cut that way besides that I use a hot wire router and the paper must be removed to do any hot wire cutting.
EDIT something elst to think about is there is a whole lot more paper peeling when you leave the paper on.
just sayin.
Old Feb 17, 2011, 12:15 AM
Eastcoast78 is offline
Find More Posts by Eastcoast78
Dixie Normious
Eastcoast78's Avatar
Can A da....Ehh!!
Joined May 2010
heres my first Build with DSF White GG ,i also used .. For the Main belly of the Fuse i used 5min epoxy form the DS to Speed up the drying time.
Parkflying (8 min 58 sec)
Plans
http://www.parkjets.com/eurofigher-tomhe/
Heres a direct Link to Tomhe's Main Website with more of his Awesome design's
http://rc.tomhe.net/eurofighter
60'' OSG(One Sheet Glider) with all DSF and White GG. FLyes Very nice in light wind days designed by Springer.
DSF Kicks Arse... IMHO and with experiences the White GG, Its one of the best glues for this foam. foams/becomes lighter. Fills gaps,sands nicely. Super Flexable.
heres a cool little thing i do too speed up set time when using GG. dab it a inch apart, then between that dot a small amount of Foam-safe Med CA between your GG. Wet the other joint lightly. Put your pieces of foam together,the CA bonds as normal 10-15 secs ,its like a tact weld. so you dont have too hold it for any period of time. It seems to make the GG even Stronger.
Ohh taping/T pins would good too. lol
Eastcoast78 is offline Find More Posts by Eastcoast78
Old Feb 17, 2011, 05:16 AM
kennyt is offline
kennyt's Avatar
southern cali
Joined Sep 2007
I really didn't expect them to stop selling the original foam board. I also have a few builds that require leaving the paper on and my 5 y/o son uses it for his occasional school projects. this would be a new product targeting the busy guys like me that don't even have 15 minutes in life to peel paper (i work 7 days a week most of the time).
Old Feb 17, 2011, 09:39 AM
Foam Av8r
RogueTitan's Avatar
Joined Sep 2008
I just came home from $Tree guess what I bought there?
Old Feb 17, 2011, 09:59 AM
SNice is offline
SNice's Avatar
Philadelphia, PA
Joined Aug 2009
I need to get more too! Posted a few of my builds...forgot about a few of theese!!!
My two latest Dollar Store Foam builds:
Low Pass' L-39
Mirage 2000 -- my own design - plans will be available soon
I love this stuff! Have never even tried FFF.
Old Feb 17, 2011, 12:09 PM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
Any Canucks out there know where to get this $tree foam North of 49? Specifically Vancouver B.C.?
Grejen is offline Find More Posts by Grejen
Old Feb 17, 2011, 12:17 PM
flypaper 2 is online now
Find More Posts by flypaper 2
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Try googling Dollarama. They have a map finder. It's where I get my stuff from here in Kingston.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Feb 17, 2011, 12:22 PM
Grejen is offline
IAMCANADIAN
Grejen's Avatar
Joined Jul 2002
Zoomed out on the map, Nothing west of Ontaio
http://www.dollarama.com/store-locator/
Years ago I found one sheet of this type of foam board at a LD and built the wing on the Beaver in my avatar. Michaels and Staples have foam board but at nearly $20 for 3 sheets hinged together
And Canada doesn't have FFF either. Just not used in construction here so it's not stocked.
Old Feb 17, 2011, 12:32 PM
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Found a bunch of places in BC in the cities chart, Victoria, Prince George, Nanaimo. etc. but I'm afraid I don't know where Squamish is.
Gord.
Video Dollar Tree Foam Eagle Rookiepilot2003 Electric Plane Talk 22 Jul 02, 2012 12:10 PM
Discussion Taking paper off dollar tree foam board ziomatrixacs Foamies (Scratchbuilt) 8 Mar 30, 2009 01:17 AM
Discussion Dollar Tree Foam vs Elmers Foamboard Tripod333 Foamies (Scratchbuilt) 19 Feb 11, 2009 02:55 AM
Video Scratch built full fuse foam Edge 540 demonGti Electric Plane Talk 2 Dec 17, 2008 10:50 AM
Discussion Glassing Dollar Tree Foam Board? Cdr.Instigator Foamies (Scratchbuilt) 6 Apr 26, 2008 09:29 PM
