Old Oct 13, 2012, 10:59 PM
Whiskers is offline
Find More Posts by Whiskers
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
Top job! Ya gotta be happy with that!
So, almost a One Sheeter huh?
I guess DGA6 also stands for "Darn! Gosh! Almost 6% over!"
Whiskers is offline Find More Posts by Whiskers
Old Oct 14, 2012, 07:53 AM
joker24458 is offline
Find More Posts by joker24458
Whatever goes up must go BOOM
joker24458's Avatar
United States, OH, Kent
Joined Mar 2012
Originally Posted by gromit38 View Post
You glue the plans onto card stock, cut those out, then trace those onto the foam. Oh, and you use new blades and sharpen or replace frequently. It is difficult to keep that blade perpendicular during cutting.
Originally Posted by springer View Post
One technique to maintain a straight line is to "drag" the knife. Hold it about 45deg to the foam, and relatively loose in your hand with index finger right on top, then just pull it down the straight edge with minimal pressure using index fingertip, only trying to get a partial cut (basically cutting through the outer "skin"). Once you get the hang of it, the knife will self align vertical to the cut. Then without moving the straight edge, make another cut with more down pressure and do this til it is through. Usually takes three strokes for me on FFF or MPF.
Thanks for your help. i can now make better, more vertical cuts.....and my sandpaper can take a break.
-joker
joker24458 is offline Find More Posts by joker24458
Old Oct 16, 2012, 05:40 PM
greedyg76 is offline
Find More Posts by greedyg76
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
This technique works best for me too and I usually build planes with 2 sheets laminated together. Don't try to make the cut in one pass, just drag your knife along the cut line several times. Results in much cleaner and accurate cuts.
greedyg76 is offline Find More Posts by greedyg76
Old Oct 16, 2012, 05:52 PM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
"Darned Good Airplane #4"
no really... that's what it stands for.
http://howardaircraft.org/
Grejen is offline Find More Posts by Grejen
Old Oct 16, 2012, 06:08 PM
bhoov128 is online now
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
-joker
I print the plans on regular ol paper, cut them out with scissors, then transfer them to foam by "coloring" the edges with a fat magic marker. It works well, makes an outline of your part and with fff you put the marker on the skinned side and when you peel it away goes the sharpie marks.
Also x100000 on the multiple passes of low-pressure knife work. The shallower the angle, the easier it gets. I routinely make clean cuts in foam with blades that are barely sharp enough to cut my finger with.
bhoov128 is online now Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Oct 20, 2012, 10:45 PM
sixfins is offline
Find More Posts by sixfins
sixfins's Avatar
United States, FL, Sunrise
Joined Jul 2011
finishing plane (adding color)
I'm building a "lil ripper" and want to paint it for color, but want to cover with tape for strength. My question to all you pros is, should I paint the foam then apply tape or tape first, then paint?
sixfins is offline Find More Posts by sixfins
Old Oct 20, 2012, 10:58 PM
Whiskers is offline
Whiskers's Avatar
Joined Feb 2010
What about colored tape instead of paint?
Old Oct 20, 2012, 11:20 PM
sixfins is offline
sixfins's Avatar
Joined Jul 2011
I prefer paint, for the available colors and ease of color design.
Wingman26 is offline
Find More Posts by Wingman26
Wingman26's Avatar
Oklahoma
Joined Aug 2008
Paint works fine on depron, but not paper covered foam board.
Water base paints, like foam safe acrylics, if applied to the paper will warp as it dries, the tape is generally a better choice for foam board.
Wingman26 is offline Find More Posts by Wingman26
Old Oct 20, 2012, 11:25 PM
sixfins is offline
sixfins's Avatar
Joined Jul 2011
I have removed all the paper, which is why I want to use tape to help strengthen it. Sorry for the incomplete info in my question.
Old Oct 20, 2012, 11:27 PM
goodhumormarc is offline
Find More Posts by goodhumormarc
figuring it out...sort of!
goodhumormarc's Avatar
USA, OR, Happy Valley
Joined Jul 2010
I paint with an airbrush using acrylics water based then tape to protect my colors. Paper of most times. If I leave the paper on then markers or colored pencils then tape. depends on if I'm building for durability or weight. Oh and by no way am I any kind of 'expert"
here are some examples...all are of course dollar tree or as I call it HobbyTree Foamboard
goodhumormarc is offline Find More Posts by goodhumormarc
Old Oct 27, 2012, 07:34 PM
V-Man is online now
Find More Posts by V-Man
Airplane and Heli Flyer
V-Man's Avatar
Canada, QC, Montreal
Joined Dec 2009
My latest Dollarama foam plane got its maiden today! I've already talked about it in my blog, no need to repeat the info.
Needs some tweaks, but it's a nice flyer. With the flaperons down, I can slow it down to a walk before landing.
V-Man is online now Find More Posts by V-Man
Old Oct 28, 2012, 01:56 AM
chris1379 is offline
Find More Posts by chris1379
chris1379's Avatar
United States, OH, Eaton
Joined May 2006
Paint it then cover it with tape. I like "Duck" brand packing tape for $1 a roll at Walmart. I've done all my painting by hand with acrylics and sharpies for fine lines.
Chris
chris1379 is offline Find More Posts by chris1379
Old Nov 25, 2012, 01:56 PM
boa2110 is offline
Find More Posts by boa2110
United States, AZ, Tucson
Joined Apr 2012
Here is my DTFB Bug with some of the paper covering removed. These planes are a lot of fun and easy to make from scratch.
Bug023 (1 min 59 sec)
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
boa2110 is offline Find More Posts by boa2110
Old Nov 27, 2012, 10:43 AM
olddog is offline
Find More Posts by olddog
olddog's Avatar
Here is a pic of my latest build, i call it the Sportster because i designed it for sport flying mostly.
Wingspan is 30inch
Did the maiden this morning and all went very well except for the landing in the snow.
Loosened the landin
Uploaded with ImageShack.usg gear and the motor mt. but no biggie its all repaired now.
olddog is offline Find More Posts by olddog
Video Dollar Tree Foam Eagle Rookiepilot2003 Electric Plane Talk 22 Jul 02, 2012 12:10 PM
Discussion Taking paper off dollar tree foam board ziomatrixacs Foamies (Scratchbuilt) 8 Mar 30, 2009 01:17 AM
Discussion Dollar Tree Foam vs Elmers Foamboard Tripod333 Foamies (Scratchbuilt) 19 Feb 11, 2009 02:55 AM
Video Scratch built full fuse foam Edge 540 demonGti Electric Plane Talk 2 Dec 17, 2008 10:50 AM
Discussion Glassing Dollar Tree Foam Board? Cdr.Instigator Foamies (Scratchbuilt) 6 Apr 26, 2008 09:29 PM
