Espritmodel.com Heli Air
Old Nov 18, 2009, 07:51 PM
In the 20' glider range
anti-gravity's Avatar
Boise, Idaho
Joined Jul 2009
So dollar tree foam board it is!
anti-gravity is offline Find More Posts by anti-gravity
Old Nov 18, 2009, 08:27 PM
Long time newbie
USA, TX, Katy
Joined Nov 2006
Guess I'll have to start building soon. Just order a case (50 sheets) for store pickup. Hopefully they don't crush the box. Price is $50 + $4.95 handling + tax. Ordered at Dollartree.com
heymak is offline Find More Posts by heymak
Old Nov 18, 2009, 08:49 PM
Pronounced "High Duck"
haiduk's Avatar
Marysville, WA
Joined Oct 2008
I accidentally discovered a good way to remove the paper from the dollar tree foam.
After putting a layer of .56 ounce fiberglass on a GWS bird with some Minwax water-based polyurethane I had the brilliant idea of hitting some of my Dollar Tree foam parts with some WBPU to "help the paper stay on better after flying in damp weather." Well, as it turned out it didn't work as I expected. After the WBPU dried, the paper peeled off like a post-it note. Downside was that I lost the little strength the paper added. Upside was it was very easy to remove the paper.
Since then, I found that simply wetting the paper and letting it dry completely (so the paper doesn't tear) has a similar effect. The paper comes off easily.
If you fly these Dollar Tree foam planes with the paper in damp weather I found that the paper tends to collect the moisture and the planes start to get heavy. After the paper dries out it tends to "fall off." An example: My pop built a small park-sized plane out of the Dollar Tree foam and went out to fly it one "wet" afternoon. First few minutes the plane flew normally, but after that it started flying "heavy." Feeling brave he continued to fly it, but after a few more minutes and a somewhat high-G turn he folded a wing. Thanks to practice with RealFlight he was able to actually fly the plane with the limp wing and land it on the runway (a bit of knife edge practice and luck). Good job Pops!
I've been messing around with different lightweight coverings to replace the paper. Basically cut out your parts with the paper on. Then scrub the parts with a soft brush and tap water. Let them dry overnight and peel the paper. I have been using Econokote and covering the de-papered foam parts to regain the strength. The plastic covered parts come out lighter than the paper covered parts and seem to be a bit stronger. They will definitely handle damp weather better.
Just some thoughts. I thought I'd share.
EDIT: If you want to remove the paper from the Dollar Tree foam, by far the best method I've discovered is to paint your parts with WBPU and let it cure. The WBPU helps prevent the paper from tearing when its removed. The water helps dilute the glue. The paper comes off like a post-it note in a single sheet. If you don't want to waste your WBPU, simply scrubbing the paper-covered parts with tap water works well if you let the parts completely dry before attempting to remove the paper. If the paper is wet when you attempt to remove it, it tears easily.
haiduk is offline Find More Posts by haiduk
Old Nov 18, 2009, 09:03 PM
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
just make sure when using dollar tree foam that you add in the thickness differences when building with plans that are designed for building with 6MM foam because the dollar tree foam is only 4.5 MM
just something to keep in mind.
but Ya dollar tree foam is good stuff to build with.
RogueTitan is offline Find More Posts by RogueTitan
Old Dec 02, 2009, 10:07 PM
Boise, Idaho
Joined Jul 2009
Does anybody know what the weight is for an average sheet of dollar tree foam(paper on) vs. one without paper?
Old Dec 02, 2009, 10:30 PM
Kokopeli
wjbite's Avatar
Rochester, NY, USA
Joined Oct 2005
I don't have an "average". But here is my measurement from one sheet:
142 g. vs. 83 g.
[Thickness] [Sample sq"] [Weight (g)] [g/sq"] [g/cu"]
Dollar Tree Readiboard 0.130 600 83 0.138 1.064
Dollar Tree Readiboard w/skin 0.190 600 142 0.237 1.246
Walt
wjbite is offline Find More Posts by wjbite
Old Dec 02, 2009, 10:36 PM
Boise, Idaho
Joined Jul 2009
Ok thanks.
BTW I love kokapelis (spelling?)
Old Dec 02, 2009, 11:27 PM
haiduk's Avatar
Marysville, WA
Joined Oct 2008
I'm not too sure what a full sheet of Dollar Tree foam board weighs, but I do know that if you strip the paper off and recover it with Econokote (or other light film covering) it comes out lighter and stronger than with the paper. (... and the covering doesn't soak up moisture)
Here's a photo of my pops newest Dollar Tree foam plane. Has the paper peeled off and replaced with Olive Drab and Gray Monokote. The plane flew great until my nephew put it into a tree!
Old Dec 03, 2009, 09:14 AM
Kokopeli
wjbite's Avatar
Rochester, NY, USA
Joined Oct 2005
I wish all my tree landings were that low LOL
Does anybody know how much weight Econokote adds?
Walt
EDIT: Tower Hobbies says that it is 0.2 oz/ sqFt - not bad, that is 6 1/2 g. per sq. ft.
That is about half of what the two layers of paper weigh.
Whoops, not so good, if you put it on both surfaces of the wing, you are back to the old weight.
Oh well, at least it doesn't absorb water.
Old Dec 03, 2009, 09:26 AM
Flying high
billwhit's Avatar
Seattle, Wa
Joined Dec 2002
That works perfectly with Tony's plans (designed for 6 mil) at 75%!
billwhit is offline Find More Posts by billwhit
Old Dec 05, 2009, 03:41 PM
pro plane crasher
planeflyer94's Avatar
Dale City va
Joined Jul 2009
I built my first scartch build out of that foam the other day.It was a 6mmflyrc.com eurofighter.I still have to add power gear.cant wait to fly it=)
planeflyer94 is offline Find More Posts by planeflyer94
Old Dec 05, 2009, 03:45 PM
pro plane crasher
Dale City va
Joined Jul 2009
And what do u guys use to paint that foam???I tried normal spray paint and it totaly warped.......like almost in half.
Old Dec 05, 2009, 03:48 PM
Flying high
billwhit's Avatar
Seattle, Wa
Joined Dec 2002
Well, I use Testor's model masters paint. It's kind of expensive and you only get small cans, but it works well on foam and even tape. Most hobby shops cary it.
Old Dec 05, 2009, 03:53 PM
treefinder
springer's Avatar
SE MI
Plane: the trick with spray cans and any foam is to do VERY dry, light sprays. Do couple of coats that way, and if you don't get enough color, try a little bit heavier coat. But you will run the risk of warps & melting the foam. I think the problem is about half paint solvent, and half propellant. If you want really bright colors, try the craft acrylics (apple?) that walmart sells with airbrush or brush. You can lay them down heavier.
springer is offline Find More Posts by springer
Latest blog entry: OSE One Sheet Edge 540 Video
Video Dollar Tree Foam Eagle Rookiepilot2003 Electric Plane Talk 22 Jul 02, 2012 12:10 PM
Discussion Taking paper off dollar tree foam board ziomatrixacs Foamies (Scratchbuilt) 8 Mar 30, 2009 01:17 AM
Discussion Dollar Tree Foam vs Elmers Foamboard Tripod333 Foamies (Scratchbuilt) 19 Feb 11, 2009 02:55 AM
Video Scratch built full fuse foam Edge 540 demonGti Electric Plane Talk 2 Dec 17, 2008 10:50 AM
Discussion Glassing Dollar Tree Foam Board? Cdr.Instigator Foamies (Scratchbuilt) 6 Apr 26, 2008 09:29 PM
