Old Mar 21, 2009, 09:08 PM
Pronounced "High Duck"
haiduk's Avatar
Marysville, WA
Joined Oct 2008
Originally Posted by aeronca52
Hi haiduk, Didn't have time to read the whole post on your other build but just wanted to type my two cents in here. Long time ago I worked for a Piper distributor and knew quite a few people at Piper. One day I was talking about cooling vents and their design. The tech said the Tomahawk fresh air vent (which is an innie) was more effective than an outtie. The vent they used was actually some sort of NACA design. Look here just ahead of the door, it's about 10" big. http://www.pipertomahawk.com/N2468N.jpg Perhaps the outtie will work better at the speeds we fly, but this worked for them. Again my two cents .
I appreciate the input. Thanks.
Originally Posted by waqa
Funjet, also done with a 30 inch wing, built the same way as the BB30 but with some taper and flaperons. At the end of the video I nose it into the ground real hard, and the damage is minimal, I suspect thanks to the paper left on the foam. Motor is a 4200+Kv Outrunner in a EDF55 on 2S from here . On 3S it flies level at 1/4 throttle. 8.5 oz's AUW.
funjet
I can't help but imagine an A10 built up from a pair of those EDF's.
haiduk is offline Find More Posts by haiduk
Old Mar 22, 2009, 10:59 AM
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
I really despise "dollar stores" that don't sell anything for a dollar. Simple fraud IMO. Specially when they are more expensive than other places like those servos.
Family "dollar" is another example.
Originally Posted by Wake Turbulence
You can get low priced servos from RCdollar store and fast shipping.
http://www.dollarrcparts.com/8gservo.html
rich smith is offline Find More Posts by rich smith
Old Mar 22, 2009, 11:46 AM
foo
Monroe, Louisiana, United States
Joined Aug 2003
Rubbing alcohol will remove the paper in jigtime,I just leave mine on.
foo is offline Find More Posts by foo
Old Mar 22, 2009, 09:05 PM
Culper Junior
eastern pa
Joined Feb 2007
rich smith- I was miffed by the name Family Dollar until someone pointed out that all their merchandise was ( I guess still is) priced 'on the dollar'. ie $6.00 or $9.00, hence DOLLAR store. In their case it didn't mean it cost just a $1.00
Everything at Dollar Tree, however, costs just $1.00.
aeronca52 is offline Find More Posts by aeronca52
Old Mar 22, 2009, 10:13 PM
have foam, will fly
waqa's Avatar
San Diego
Joined Dec 2008
Yes it does , including:
Awesome in spray bottle (if you want to remove the paper)
90% Alcohol (if you want to remove the paper)
Empty Spray bottle for making 50% alcohol (if you want to remove the paper)
Hot Glue guns
Hot glue sticks
Rulers
Ruler Squares
Blades
Mechanical Pencils
Pens
Masking Tape
Clear Tape
Packing Tape
Snacks (for those late night builds)
etc....
waqa is offline Find More Posts by waqa
Old Mar 22, 2009, 11:11 PM
rich smith's Avatar
Joined Dec 2006
Apparently that differs by location because I just bought some calculators (I collect them) for $1.95. Also saw some RC cars there today for $19.95. I just don't like the place and if I could have got the calcs elsewhere I would.
I love Dollar Tree and the other "true" dollar stores.
Old Mar 23, 2009, 02:43 PM
Pompano Hill Flyers
Wake Turbulence's Avatar
United States, FL, Coconut Creek
Joined Aug 2007
Hot Glue guns
Hot glue sticks
Rulers
Ruler Squares
Blades
Mechanical Pencils
Pens
Masking Tape
Clear Tape
Packing Tape
etc....
I got to go to the dollar tree store.
Wake Turbulence is offline Find More Posts by Wake Turbulence
Old Mar 23, 2009, 03:02 PM
Long time newbie
USA, TX, Katy
Joined Nov 2006
My Dollar tree hanger
Not the prettiest, but they're all from dollar tree foam. There were others but they didn't fly well so I didn't post them. They were good models but I am not a great builder.
Mike K
heymak is offline Find More Posts by heymak
Old Mar 23, 2009, 03:39 PM
"Fly, yes... Land, No"
Joined May 2005
So heres what I've been working on for the last few weeks. 2 1/4 boards of the Dollar Tree "R.L.Adams Plastics, Inc" foam board.
The black one is the first one I made useing EPS and covering it in Depron. I think I'm going to stick with the dollar tree foam. shapes easily, good solid foam when you get over 4 layers. about 4mm thick without the kraft paper on it.
OutcastZeroOne is offline Find More Posts by OutcastZeroOne
Old Mar 23, 2009, 03:47 PM
Eventually...I will fly
Israel
is this "dollar tree" foam the one with paper on both sides?
isn't awfly heavy for suce small planes?
eran_k is offline Find More Posts by eran_k
Old Mar 23, 2009, 05:47 PM
Flying high
billwhit's Avatar
Seattle, Wa
Joined Dec 2002
I just started using dollar tree foam and I really like it. In fact I am grabbing it before the depron and epp I have on my shelf, although I'm not apposed to mixing foams!
A friend of mine just used my scraps to build a Spitfire, I'll have to post a pic later.
Here is my first Dollar Tree build, the FFF Eagle. I use "Awesome" to take the paper off and then resurface it with packing tape when I'm done.
billwhit is offline Find More Posts by billwhit
Old Mar 23, 2009, 07:13 PM
Long time newbie
USA, TX, Katy
Joined Nov 2006
The paper is peeled off. At a dollar for a 20" X 30" sheet it is worth peeling. Once you peel it it's hard to tell the difference between Dollar Tree foam and midwest celfoam 88.
Mike K
Old Mar 23, 2009, 07:14 PM
Long time newbie
USA, TX, Katy
Joined Nov 2006
I was thinking of building this one. Was it hard to adapt it to Readiboard?
Mike K
Old Mar 23, 2009, 09:36 PM
Joined May 2005
I spray on some denatured alchohol to pull off the craft paper.
Old Mar 24, 2009, 09:51 AM
Flying high
billwhit's Avatar
Seattle, Wa
Joined Dec 2002
Mike K
Nope, it was actually a very easy build. The top and bottom pieces need to curve a bit, so you might need to use a little heat to get them to shape.
Video Dollar Tree Foam Eagle Rookiepilot2003 Electric Plane Talk 22 Jul 02, 2012 12:10 PM
Discussion Taking paper off dollar tree foam board ziomatrixacs Foamies (Scratchbuilt) 8 Mar 30, 2009 01:17 AM
Discussion Dollar Tree Foam vs Elmers Foamboard Tripod333 Foamies (Scratchbuilt) 19 Feb 11, 2009 02:55 AM
Video Scratch built full fuse foam Edge 540 demonGti Electric Plane Talk 2 Dec 17, 2008 10:50 AM
Discussion Glassing Dollar Tree Foam Board? Cdr.Instigator Foamies (Scratchbuilt) 6 Apr 26, 2008 09:29 PM
