Old Mar 20, 2009, 06:52 PM
fvasileios is offline
Find More Posts by fvasileios
life is a beach
fvasileios's Avatar
thessaloniki-greece
Joined Sep 2008
Build Log
sunseeker predator 108
hi there guys....
i'm back with my new project...once revell produced this model i felt like i have to rc it cause i love this type of boats....it's a very beautiful model in my opinion with many pretty scale details...i placed two simple motors which you'll see in photos and i'm about to finish the construction....then i have to order and place the electronics in the hull and it's ready.a few pieces left to be stuck on the model and some painting corrections.i also place two bulbs that lights the cockpit and all the living room.i'm planning to use a 4ch receiver,an esc and the power for the motors will be 9.6 volts.any suggestions accepted specially for how to light up the bulbs from the transmitter.sorry for posting close to the end of this project but there was no time because of work...i really want to listen to your opinion cause it's my second rc model after QM2.....
bill
fvasileios is offline Find More Posts by fvasileios
Old Mar 20, 2009, 08:55 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
Interesting rudder position.
How does the actual boat steer?
I am guessing that you have the correct position for the
surface drive propellers...
How is the model for displacement?
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Mar 21, 2009, 08:21 AM
life is a beach
fvasileios's Avatar
thessaloniki-greece
Joined Sep 2008
hi there Umi...well i want to install the servo and see if the rudder will work cause i made it by myself...in the model characteristics it says that it has 3 drive pods.i don't know if this explains how the actual boat steers cause in the actual boat there is no rudder...
what do you mean when you say "I am guessing that you have the correct position for the surface drive propellers..." and "How is the model for displacement? "... ?
Old Mar 21, 2009, 11:59 AM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
My investigations say that the boat has three six bladed surfaces drives.
This would place all three propellers high on the transom with
only half of the propellers in the water. So the position where
you placed your props looks correct, but I am wondering if
the actual boat used steerable drives, or if there was a rudder.
Displacment, is how much water does the model displace, or
how deep it sits in the water.
Does the model sit well, or is the displacement low compared to the waterline?
When you put all the equipment into the model, is it heavy?
Or is the model light, and you have extra displacement to put
more batteries or weight into the model?
Old Mar 22, 2009, 07:32 AM
life is a beach
fvasileios's Avatar
thessaloniki-greece
Joined Sep 2008
hello Umi....
i found this on a website:
STEERING: Hydraulic
PROPULSION: Direct gear drive through triple Arneson surface drives.
also this:
Propulsion: Direct gear drive through triple Arneson surface drives, or submerged twin props in semi-tunnels
also there is a photo from my model's instruction book...
well about displacement when i fload tested it i had bateries and motors inside and it seemed that it could carry some more weight...now i'll know once i'll buy all the electronics...i think it will be ok...
Old Mar 22, 2009, 08:17 AM
FatBeech is offline
Find More Posts by FatBeech
FatBeech's Avatar
Bavaria, about 45km from Neuschwanstein-Castle
Joined Nov 2006
Hi Bill,
looks very good yet. But the props are too big. We have ordered the smallest props from Propshop, UK. They will be 15mm diameter, but you can't get them as surface-cleavers.
In our german forum we did find out, that you have 70 gram only to put it into the hull to get the correct cwl.
Some of us are doing the tunneled hull, some the arneson's.
I was thinking about using a coax-helicopter-radio. There you have 2 esc's (one direction only) for two props, and 1 servo for steering. Another method will be, to control both motors similar to Tamiya TamTech cars. That means, you can use your servo-motors for the props and the servo-electronics for controlling forward/back driving. So you don't need a rudder. Maybe a third motor as booster. Then driving the small hull with lipo 2s350mA or 500mA, or 2 Konion cells.
Best Regards,
Ernst
FatBeech is offline Find More Posts by FatBeech
Old Mar 22, 2009, 08:46 AM
life is a beach
fvasileios's Avatar
thessaloniki-greece
Joined Sep 2008
Originally Posted by FatBeech
Hi Bill,
Best Regards,
Ernst
hi there Ernst...
i ripped out the motors with the shafts and props from a cheap boat toy...i'm not really looking for scale stuff under the waterline.i only want to see my baby working...besides i'm looking for cheap ways to make this happen...i'm not yet in a position where i can spend much money for my hobby and i'm not also so experienced like most of you are...i hope that in future i will learn from you and i'll be able to do better projects...now you made me worried by saying this for 70 grams only...in the fload test i had the motors you see in picture and the 8 pack 9.6 volts battery...i think it looked ok....maybe i have to try again...
bill
Old Mar 22, 2009, 09:20 AM
life is a beach
fvasileios's Avatar
thessaloniki-greece
Joined Sep 2008
Ernst can you check this please?it might be some you'll need...from what you and guys in german forum trying to do this might be helpful.....
http://www.action-electronics.co.uk/...k/pdfs/P94.pdf
bill
Old Mar 22, 2009, 12:41 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
Bill,
Thanks for the picture of your instruction sheet.
That's the only image I have seen that shows how the
drives are located on that boat.
Fatbeech,
Any pics of the semi tunnel mods to the hull?
Old Mar 22, 2009, 05:18 PM
FatBeech is offline
FatBeech's Avatar
Joined Nov 2006
Hello Umi,
here are some pics from the german thread...
http://www.rc-modellbau-schiffe.de/w...?threadid=6334
You have to register in the forum first, to be able, to see the pics. If you need a translation, I will help.
In this forum my nick is "promocean".
Best Regards,
Ernst
Old Mar 22, 2009, 05:29 PM
life is a beach
fvasileios's Avatar
thessaloniki-greece
Joined Sep 2008
Hello Umi,
Best Regards,
Ernst
hi Ernst,
i think it would be easier if you could upload these pictures here ...i can't understand a word...but from the pictures already in this thread it seems a pretty nice work...why this shape in the hull where the rudders took place?
bill
Old Mar 22, 2009, 07:08 PM
Sea Dragon-Lover
PDX, OR
Joined Dec 2002
Ernst
Good images there.
Seems like they have some issues with placing the tunnels first, then
trying to line up the motor and shafts.... But the images are very informative.
Aimee
Old Mar 23, 2009, 01:05 PM
FatBeech is offline
FatBeech's Avatar
Joined Nov 2006
My friend Olaf, known in our german forum as "The Bastelritter" (that means someone like a model building knight, who always does his thing), has a homepage on which you can read the story in english language:
http://www.bastelritter.de/index.php...d=23&Itemid=94
If now are more questions, please ask and I will translate or explain (cause Olaf uses a translating program).
Best Regards,
Ernst
Old Mar 23, 2009, 05:29 PM
life is a beach
fvasileios's Avatar
thessaloniki-greece
Joined Sep 2008
Best Regards,
Ernst
Thanks a lot Ernst...
quite interesting website...olaf seems like an experienced modeller...i'm worrying about the weight in mine...i haven't taken anything out to gain weight and i'm going for 9.6v 8pack battery...should i worry???i think i'll have to test it...have you shown olaf mine?opinions from you and other experienced modellers is what counts....
efcharisto,bill
Old Mar 23, 2009, 07:19 PM
FatBeech is offline
FatBeech's Avatar
Joined Nov 2006
Hi Bill,
did you ever test the hull with needed additional weight in a bathtube before building together?
Ernst
