Old Mar 20, 2009, 09:40 AM
congcon97 is offline
Find More Posts by congcon97
Joined Jun 2007
Applications of Delta & Star winding
Wish to know where Delta type winding and where Star type winding is used. I meant the aplication;I know star is more common and easier,but certainly delta is for specific one. Anyone pl tell me which one is good for what?
congcon97 is offline Find More Posts by congcon97
Old Mar 20, 2009, 12:52 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Star (aka. WYE) is not more common. Delta is a more common configuration among factory motors. It really depends on personal preference more than anything. I typically try to get two layers of the thickest wire possible around each stator tooth and select a termination based on that and my desired kV.
In rare instances, WYE termination is necessary for a smooth motor run. Motors such as the 9N8P and 9N10P will vibrate excessively if terminated Delta. Also, in the case of the 12N14P (dLRK) Wye is occasionally more efficient due to circulating currents present in the Delta.
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 20, 2009, 02:18 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Apart from what IB/Alex wrote above, you can get the same motors with star and delta just by changing number of winds (and wire thickness): same efficiency, weight, torque, power and rpm. A star hookup is the same as a delta hookup with #winds increased by factor 1.8.
Pretig weekend Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Mar 20, 2009, 02:42 PM
Joined Jun 2007
Ok, Now can u tell me what type of winding is used in a helicopter motor? In a heli the motor has to drive a big main rotor as well as tail one, but in a plane only a little prop. WHich termination is better for which one??
Old Mar 20, 2009, 03:53 PM
jj1 is offline
jj1
Find More Posts by jj1
jj1
jj1's Avatar
Finland
Its not about termination, u need the right kv for given application.
Example u need a kv 1500...
use thick wire and say 10 turns/stator tooth WYE OR
Thinner wire and 18 turns/delta
AND you have two different ways to make identical motors of same Kv.
-JJ
jj1 is offline Find More Posts by jj1
Old Mar 21, 2009, 07:56 PM
Ron H is offline
Find More Posts by Ron H
Night flying
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Pretig weekend Ron
I must have missed something somewhere. Didn't it used to be 1.73?
Ron H is offline Find More Posts by Ron H
Old Mar 21, 2009, 08:57 PM
Joined Feb 2001
1.7-1.8 probably because signals are not sinusoidal, in that case it would be sqrt(3).
Prettig weekend Ron
Discussion Motor with Quick Delta, Star Connector manuel v Electric Motor Design and Construction 7 Jan 23, 2007 06:19 PM
R&R Delta Star rocket plane conversion dottney Sport Planes 33 Jan 10, 2006 06:23 PM
Delta Star Rocket plane dottney Pusher Prop Jet Models 4 Nov 15, 2005 12:19 PM
Delta Star RocketRob Scratchbuilt Indoor and Micro Models 0 Mar 19, 2003 08:08 AM
New Delta Star 500 For Sale snipesja Aircraft - Electric - Airplanes (FS/W) 0 May 06, 2002 07:33 PM
