Old Mar 24, 2003, 03:52 AM
Peter Young is offline
Find More Posts by Peter Young
Dead stick!!
Peter Young's Avatar
Joined Mar 2002
Need help with motor instructions - QRP HYPER 400 6V Motors w/timing advance
Hi all
I just received a QRP HYPER 400 6V Motors w/timing advance
(reverse) for my combat wing from Aircraft World:
http://www.aircraft-world.com/prod_d...S400motors.htm
The motor came with Japanese instructions, and I'm unsure how to connect it up. In particular it came with five capacitors, and I have no idea which one(s) to use.
I'll post the Japanese instructions in case someone can translate for me.
Many thanks
Peter
Peter Young is offline Find More Posts by Peter Young
Old Mar 24, 2003, 03:57 AM
Dead stick!!
Joined Mar 2002
page 1 of instructions
page 1
Old Mar 24, 2003, 03:59 AM
Dead stick!!
Joined Mar 2002
here's page 2
Old Mar 24, 2003, 08:34 AM
KLH is offline
KLH
Find More Posts by KLH
KLH
Pack Rat
KLH's Avatar
Hayward CA / Valley Springs CA USA
Joined Jan 2001
Peter
Sorry can't read Japanese. However I can tell you that I've used several of these motors from Dave and they all come with 5 capacitors, but I only use 3. I solder 1 cap each between both the + and - leads from the end ball of the motor to the outer case of the motor and a third cap directly between the + and - leads. Take a look at the pic in the instructions it shows how 2 of the caps get placed between the leads and the case. The third cap which I don't see in the instructions just gets soldered between the leads.
What I've tried to describe is pretty much standard practice with small brushed motors. If you have never done it before I'm sure it sounds strange especially a cap soldered directly between the + and - leads. The purpose of the caps is to help reduce the elec noise from the motors thus reducing the chance of elec interference to the receiver in your plane.
A lot of motors come with the caps already soldered in place more or less as I've described above and some come with caps pre installed inside the case where they aren't visible.
I've seen people fly planes with out caps soldered in place with no problems, but if its my planes I use them.
Good luck with it. Those are good little motors that Dave sells.
Kern
KLH is offline Find More Posts by KLH
Old Mar 24, 2003, 08:42 AM
pda4you is offline
Find More Posts by pda4you
pda4you's Avatar
USA, TX, Trophy Club
Joined May 2002
I am 99.9% sure that these motors come with caps inside - so the only thing I do is solder the cap between "+" and "-" terminals. I have used 3 or 4 of these motors and have not had any issue with noise.
Old Mar 24, 2003, 02:38 PM
Dead stick!!
Joined Mar 2002
Thanks Mike and Kern
I got an e-mail from Aircraft World which helps to explain things. I'd still appreciate a translation if anyone can do one for me.
btw - can someone explain how to "insulate these with the supplied tube"? The caps come with a little plastic tube - how do I use this?
Many thanks
Peter
"Hi,
We don't have English instructions, but the diagram tells it all, really. Here's an interpretation:
QRP recommends using two of the caps across the +/- poles (insulate these with the supplied tube), and one each from pole to case. So you have one extra.
Attach the (+) wire from the ESC to the red dot for "Normal" rotation motors
The (-) wire from the ESC to the red dot for "Reverse" rotation QRP motors.
Cheers,
Brian
AC Staff"
Old Mar 24, 2003, 03:20 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
Peter,
Just cut a small piece of the tubing so that it covers all of the exposed wire on the capacitor (right from it's base) to the +,- terminals. Just leave enough exposed wire to solder to the terminals. The goal here is to aviod a metal object contacting the exposed wires on the capacitor and causing a short.
Old Mar 24, 2003, 05:18 PM
bhchan is online now
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
loosely translated.
bhchan is online now Find More Posts by bhchan
Old Mar 24, 2003, 09:10 PM
pda4you is offline
pda4you's Avatar
Joined May 2002
Too funny!
Old Mar 25, 2003, 02:28 AM
Dead stick!!
Joined Mar 2002
It works for me - thanks bhchan
Old Mar 25, 2003, 10:56 AM
Peter Mar is offline
Find More Posts by Peter Mar
EMFSO, CRS, MAAC
Peter Mar's Avatar
Toronto, Ontario
Joined Oct 1999
I have run a Hyper 400 with NO caps installed with a Cosmotech gearbox. Jeti JES180 and Rondo 18 ESC.
No problems with interference.
This was suggested by Alex Larionov (Starflight). I was a bit skeptical. However, I was not interested in soldering 3 caps to the can. So I gave it a try without any.
Even when climbing high with my 1.8m glider, I have no control difficulties in a typical RC field environment.
Peter Mar is offline Find More Posts by Peter Mar
Old Mar 25, 2003, 10:59 PM
epkoncept is offline
Find More Posts by epkoncept
San Diego Lindberg, California, United States
Joined Jan 2002
The 1st page mentions that 2 caps are spares !
It also mentions that in the case that the standard usage with 3 caps
does not cut the noise enough sometimes adding the spare caps in
parallel with the cap which is located between the two motor terminals
helps.
THe caps are non-polarized and the value is 104, which means
10 x 10e-12 x 1e4=0.1uF
THe other pages concern break in etc
EP
epkoncept is offline Find More Posts by epkoncept
Old Mar 26, 2003, 04:10 AM
Dead stick!!
Joined Mar 2002
epkoncept - what do the break-in instructions say? I'd normally tape together a couple of D-cell alkalines in series, and run them flat. Will that be ok?
Peter
Old Mar 26, 2003, 09:42 AM
Joined Jan 2002
break in
Peter
Ok, it mentions to break it in with only 1 nicad and no propellor. The next paragraph mentions that it can be run in with an esc, until the auto low voltage cut off turns on. (It did not explicitly mention the esc setting, but I assume it is implied that it was set to the lowest speed. ) It then mentions that the break in should be monitored so that the "can " temp does not go higher than the temp of "hot water", I believe that is roughly about 50C. When the motor gets hot, please stop, let it cool and then continue.
It also mentions in the next paragraph that the motor should be operated gently for the first few flights, ie no quick changes in throttle. (I guess that that is to reduce the peak current, ie even braking can generate high brush currents.
EP
Old Mar 26, 2003, 11:44 AM
Joined Jan 2002
more clarification
3. is motor break in
1 Nicad and no prop
check temp, warm is fine.
can use cooling fan
4. is motor break in while flying.
fly gently for firs few flights
5. motor cooling
make adequate cooling holtes
motor spec
35 turn 15degree advance, either for or rev
Need help with motor overheating! rdogg32 Electric Heli Talk 11 Jul 14, 2002 10:34 AM
Desperately need help with motor interference problem Ken Lapointe Electric Plane Talk 8 Jun 22, 2001 06:40 AM
I need help with motor timing. jtthebiggafigga Electric Plane Talk 3 Jun 09, 2001 11:12 PM
E.E. Lightning-pusher scale electric need help with motor/battery etc bipeflyer Scale Kit/Scratch Built 5 May 01, 2001 05:33 PM
E.E. Lightning-pusher scale electric need help with motor/battery etc bipeflyer Scale Kit/Scratch Built 0 Apr 29, 2001 05:02 AM
