Mar 19, 2009, 08:55 PM
Bellevue, WA
Joined Feb 2004
Yellow Aircraft F-18 Twin Build
Things are starting to get back to normal at work so now I have some time to get to back to doing the things I like. Unfortnately, the weather in the Pacific Northwest is still cold and rainy so I can't do the glassing and finishing work on the Fury so I decided to start on the F-18. I will work on the F-18 until the weather gets better, then I will switch back to the Fury.
Demensions of the F-18 are:
Length -- 97 inches
Wingspan -- 72 inches
The first step is to build the elevator shaft bearing boxes. The top, bottom, and sides are epoxied together making sure everything stays squared.
Kirk
Reason: fix typo
