Old Mar 23, 2003, 05:12 PM
Al
Al
Guest
n/a Posts
need help with O.S. Max 28F
Would anyone know how I can set up the mixture on this
engine. Seems someone played with it before I bought
it and not been able to get it to start for me. I was
even told someone had played with the adjustment, and
don't have a clue how to set it. Even if I could get
it to run then I could adjust it from there.
Any ideas!
Thanks in advance
Al
Old Mar 23, 2003, 10:02 PM
Dr1Driver
Dr1Driver
Guest
n/a Posts
Re: need help with O.S. Max 28F
>engine.
I will assume you have a good glow plug and good fuel. Set the high speed
needle about 1 1/2 turns out and the low speed needle about the same. That
should be a good starting place.
Dr.1 Driver
"There's a Hun in the sun!"
Old Mar 24, 2003, 08:02 PM
Al
Al
Guest
n/a Posts
> >engine.
Yes glow plug and fuel are both good. Thanks for info,
I will give it a try.
Al
Need help with Al's CCPM for Raptor--Linkage setup ICRSHLTS Electric Heli Talk 1 Jul 03, 2004 10:51 PM
Yippee! Help with O.S. .40FSR J.A.Bairos Aircraft - Fuel - Airplanes (FS/W) 2 Oct 27, 2003 04:39 AM
Need help with Motocalc #'s for speed 300 7.2v roguewolf Power Systems 2 Apr 20, 2003 01:19 PM
Need help with my Crazy Max JStory Parkflyers 0 Jan 24, 2002 05:29 PM
