This thread is privately moderated by Bombay, who may elect to delete unwanted replies.
Old Mar 17, 2009, 01:46 PM
Bombay is offline
Find More Posts by Bombay
Slow Flyer
Bombay's Avatar
Richmond, TX
Joined Apr 2008
In the Hangar...
In the Hangar...
> PZ Micro Cessna 210 #1
> PZ Micro Cessna 210 #2
> Hobbico FlyZone SkyFly #1 - Pushrod and hinge mods
> Hobbico FlyZone SkyFly #2 - Night Flyer with Glowire
> Parkzone Slo-V - NightFlight Module and Sonic Combat Module
Stock setup but running on the 8.4v battery instead of the 7.2v(tired & retired)
> Brushless Slo-V - Brushless setup with Glowire and flashers
Motor - BP 9YSS Outrunner Brushless Motor With Short Shaft at 840 kv.
Prop - GWS 12x6 SF
Servos - Hextronik HXT900 9gram
ESC - HW25A with programming card
Battery - Rhino 1250 2s 20C lipo
RX - AR6100E
Amps - ~10-11
> Cox Lazy Bee (Bionic Bee)
Motor: BP 8YSS Outrunner
Prop: APC 10x3.8 Slo Fly with large aluminum collet spinner
Battery: 3s 2150mah Rhino
Speed controller: Castle Creations T-Bird 36 (used it for the extra weight)
Servos: GWS Park LF (17grams)
Receiver: AR6100
Amps: ~12 (need to use throttle management)
..........Successful maiden flights.
> War Eagle
Motor: Suppo 2212-15 (930kv)
Prop: 9x4.7 SF Need to play around with different props.
Servos: Hitec HS-55
Battery: Thunderpower Prolite 3s 2100mah 15c
ESC: SS 20A (card programmable)
MS Composit "Blade Dancer"
My first 3D plane
Motor: 2830-09 850kv
Prop: APC 11 x 3.8SF: 27 oz thrust, 12.5 amps, pitch speed 23 mph
Servos: HXT900 9gram and Power HD 8g
Battery: 3s 1300mah 25c
Receiver: AR6100e
ESC: CC 25A (usb progammable)
Plenty of expo and reduced rates
..........Successful maiden flight. ~10 flights. Flies great...still pushing the CG back to find the sweet spot.
> PZ Plug-n-Play F4U Corsair - various cosmetic mods
Battery: 3s FlightMax 2200mah
Receiver: AR700
Stock motor, esc, 3-blader prop, and servos
Lighting kit
> Scratch-built Flat Foamy F22 Raptor (based on Dekan's plans)
Motor: BP A2208-12 Brushless Outrunner (1800kv, 135w)
Prop: APC 6x5.5e
Servos: Power HD 8g
Battery: 3s 1000
Receiver: AR6100e
> Scratch-built Profile Foamy F22 Raptor (based on Tomhe's plans)
Motor: 2212-06 Brushless Outrunner (2200kv)
Prop: APC 6x4e
Servos: Power HD 8g
Battery: 3s 1550mah
Receiver: AR6110e
ESC: SS 30A (card programmable)
> Titan 60 Night Flyer Wing
Motor: CF2812-14 (1534kv)
ESC: 30amp rctimer
Battery: 3s 1550mah
Prop: 7x6
RX: AR6110e
Other: LEDs galore
> Scratch-Built AlleyCat profile pusher jet
> Assassin Combat Wing
ESC: 25 amp HK
Battery: 3s 1300mah
Prop: 7x6
RX: AR6110e
Servos: HS-82MG
In the "works"...
> e-flite T-34 Mentor
> Jeff Troy's Tamecat 40
> Wattage F22 Raptor
(SOLD)
> Another Brushless Slo-V - Brushless setup
Motor - TBD
Prop - TBD
Battery - TBD
RX - AR6110E
Amps - TBD
This one will have two wings that can be switched out. Both will be set with ailerons...one will be setup for a little more speed and durability...the other for night flying.
Bombay is offline Find More Posts by Bombay
What happens when the lights go out in the hangar... Mikey C. Parkflyers 2 Nov 08, 2003 04:35 PM
As Requested... Planes in my Hangar! boomerace Parkflyers 32 Sep 06, 2003 12:32 AM
I want a warbird in the hangar! RCace Scale Fuel Planes 2 May 26, 2003 10:56 PM
Big Sale! - Just making room in the hangar / shop Sal C Aircraft - Electric - Airplanes (FS/W) 62 Aug 31, 2002 04:43 PM
the "beast (J3 Stik) in the hangar firstdegree Parkflyers 6 Jun 24, 2002 07:33 AM
