Old Mar 23, 2003, 03:35 AM
f5b-uk
Mike Seale's Avatar
Devon, UK
Joined May 2002
Schulze isl8 won't work with power supply
My power supply (Watson, 22A continuous, bought from WLM last year) won't run my isl8 anymore
I think the charger has a big capacitor to charge up and the initial surge overlaods the PS and it shuts down. I have been overcoming this by connecting the PS to a 12V battery and the Schulze to the PS before switching on the supply. Removing the leads from the PS to the battery would then leave the Schulze working OK. However, now this won't work either.
Has anyone had a similar problem and is there a cure? Can anyone suggest why my original hookup has stopped working when it seems to be fine in the past?
Mike Seale is offline Find More Posts by Mike Seale
Old Mar 23, 2003, 12:03 PM
small electrics r BIG FUN
Iowa
Joined Aug 2000
Does the charger still work ok with a good 12v battery ? That would isolate the charger or the ps.
Could be your power supply was going bad a long time ago.
I have also found that some chargers will function just fine on a certain power supply, while a different charger will refuse to.
Al
Al P is offline Find More Posts by Al P
Old Mar 23, 2003, 02:43 PM
Menber
60013
Joined Feb 2003
Mike,
Read this.
http://www.rcgroups.com/forums/showt...5&pagenumber=1
Theox is offline Find More Posts by Theox
Old Mar 23, 2003, 05:30 PM
f5b-uk
Mike Seale's Avatar
Devon, UK
Joined May 2002
Originally posted by Theox
Mike,
Read this.
Thanks for this. However, I've solved the problem in a different way. Hooking a 1 Ohm resistor in series with the charger when the PS is switched on limits the current. This resistor is then removed whist keeping continuity in the circuit. Seems to be working fine now.
My EVO won't work with some receivers? bomeara Radios 7 Mar 13, 2005 01:22 PM
Pheonix 45 dated September 2003 won't work with PHX-link FrankW Castle Creations 1 May 03, 2004 05:02 AM
Motocalc won't work need power system help. Hopperfly22 Power Systems 2 Aug 02, 2003 07:15 PM
Help!! - Quicken 2002 Basic won't work with Windows XP!? mrebman Life, The Universe, and Politics 1 Dec 28, 2001 02:54 PM
