| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||||||
#1 |
can buzzards see thermals...
RADIAN Replacement Prop
I have a RADIAN with a broken prop. The weather has been horrible the last 4 days. It finally got real nice today, warmed up into the upper 60's and just a slight breeze from the south
. Got my RAIDAN out, took the boys to the park and just got one motor run up to about 200 feet *when* the canapoy fluttered off and the airframe started buzzing , so I shut the motor down and made a nice landing, noticing that one blade was broken just beyond the attachment root. I have looked online, and everyone says they are out of stock (eary April is the best date I can find). Does anyone have any suggestions or an available replacement prop? I'd hate do be down for several weeks, when this is the best weather period coming up (not too hot yet). Please give me some suggestions on where to look, or if anyone has any available plz let me know. Thanks- |
#2 |
Horizon Hobby sells all the parts of the plane...
http://www.horizonhobby.com/Products...ProdID=PKZ1017 Dave |
#3 |
Thanks Dave (GREAT name BTW). However, they say the part will be available in April. That's a few weeks away. Anyone have one available in March?
#4 |
Can't you just replace it with a Graupner CAM or Aeronaut folding prop of the same size? (These normally have 8mm blade grip width & 3mm bolt hole)
Quality hardware, these them paddles ![]() Aeronaut home Last edited by Test005; Mar 16, 2009 at 10:25 AM. |
#5 |
That's where I was headed today. I've been trying to find out what types will fit in the hub, and I think the 8mm Graupner cam blades will be a direct fit. Can someone confirm this for me? Also, what size prop is recommended? 9 x 6, 10 x 6, 11 x 6, probably somehwere in this ballpark--I'd like a little info from anyone who has made a swap to these blades. This is my first experience with a folding prop, so any suggestion is welcome.
Thanks for the input so far! -David |
#6 |
Just meassure the distance between the two thingies on the prop holding-center-thingie in the spinner, this should be 8mm or 0.31496 inches for you with American meassurement.
The hole for the bolt should accomodate a M3 bolt. For size, check some reviews or write up's on the Radian online. Im sure someone has mentioned the stock prop size somewhere?!? |
#7 |
Taking Over the World!
radian props...
David,
this is too funny...I was just looking into it for you when I found this thread. There has already been a discussion on the Radian Prop. Apparently we are starting to find out the true fatigue life of the stock props by many people, and I have seen it personally. They all seem to have the same failure mode. check this link out and read post #26... and there are pics of the setup. spinners come in white, red ,or black. I put together the shopping list..... this is the hot set-up for props.... Aeronaut is an excellent carbon prop and waaay better than the stock prop. So are the Graupners. I will see if I have any. Go with either 10x7 or 10x8. Stock is 9.75x7.5. Aircraft-world in Japan is the place to get these. I don't know how they do it, but shipping is about $2.00 and a couple of days!!! AN-7242-24 Aluminum Hub 52mm - Neutral Pitch US$12.90 AN-7251-50 Spinner 50mm - WHITE US$5.70 US AN-7124-04 4mm Aluminum Collet US$5.95 US The prop choices are: AN-7234-31 Aeronaut CAM Carbon-Plastic 10.0x7.0 Blades (S8,R3) US$11.60 AN-7234-32 Aeronaut CAM Carbon-Plastic 10.0x8.0 Blades (S8,R3) US$11.60 AN-7234-39 Aeronaut CAM Carbon-Plastic 11.0x6.0 Blades (S8,R3) US$11.90 Last edited by SUNSQUINT; Aug 27, 2009 at 12:42 PM. Reason: fixed link |
#8 |
Thanks, that's exactly what I was looking for. I think I'll go with the 10 x 7, any reason to pick one over the other? I like the idea of an upgrade to the prop.
I couldn't get the link to work, I'd like to read that other thread. Can you help get it to work, or give me some search criteria to get there? I appreciate all the help, I think I'm gona like being on this board more than I thought! |
#9 |
calc'd
David, I fixed the link for you....
Here is how the numbers calculate on Steve Neu's calculator on the Castle Creations website.... I input the Park 480 specs as a custom motor and a Kokam 1300 3s battery. The 10x8 prop shows: ![]() ![]()
There should be no heat issues with the 10x8. The 10x7 is the closest replacement for the stock setup with negligible performance difference. Things do get a little bit ugly when you go much bigger than 11x6.... Your mileage may vary depending on the discharge rate of your battery, but this is good for comparison. I hope this helps. Mark EDIT after flying them all, the 11 x 6 is actually the best rate of climb and overall perfomance. Last edited by SUNSQUINT; Jan 31, 2010 at 01:31 PM. |
#10 | |
Prop
#11 |
Gohmer,
were the blades able to fold all the way back to the fuse? Last edited by SUNSQUINT; Mar 19, 2009 at 11:46 AM. Reason: typo |
#12 | |
Blades
#13 |
I have some on the way from my list above.... I did read on an Australian thread that a second version from Parkzone is coming out, but I have not heard it from anywhere else. It sounds like you did what was in the pics in my link on post #7 ? |
#14 | |
Prop
My first glider experience was in Tucson! Free flight tow line at the UofA Polo field. Mid 1950's |
#15 |
naw, the Graupner can take it....it's of good quality and is under rated.
| Thread Tools | |
| Replacement Prop shaft, with no threads? | Nethole | Beginner Training Area (Aircraft-Electric) | 3 | Oct 16, 2004 11:03 AM |
| Question Replacement prop for GWS 12x6 slow flyer? | JAM | Electric Plane Talk | 7 | Sep 09, 2004 10:27 AM |
| Replacement prop for Slow Stick | Carl Weaver | Parkflyers | 2 | May 28, 2003 01:09 AM |
| Which replacement prop to get for my Soarstar? | f2racer | Electric Plane Talk | 6 | Jan 10, 2002 02:36 PM |
| NEED A REPLACEMENT PROP FOR ZAGI!!! | RG5384 | Foamies (Kits) | 30 | Oct 06, 2001 02:57 PM |
