Old Mar 14, 2013, 09:58 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Originally Posted by Friesianflyer View Post
Hi everyone, just setting up my penguin with osd pro, and am getting horizontal lines where the text is displayed? It is obviously coming from the osd, as I have tried bypassing it and the video signal is clear. Has anyone seen similar, or am I being picky :-)
Originally Posted by Kloner View Post
try turning down the white level
& turn up black level.
These levels are found in the menu...
m_beeson is offline Find More Posts by m_beeson
Old Mar 15, 2013, 03:13 PM
suri0712 is offline
Find More Posts by suri0712
Prof 40, EZG, Extra 330 L
United States, CA, Santa Clara
Joined Jan 2010
OSD not connected message on the PC
Hi,
I have slowly been accumulating ET hardware for my FPV project & recently have everything I need to get started. But I'm running into some issues with the OSD.
I plugged in my OSD Pro which is connected with the right polarity to the elogger V4(which is also connected to a GPS) using a mini usb cable to the PC (no other hw is connected to the ET system). I see under fw control that the elogger is detected, but I dont see the OSD as detected. The led on the elogger seems fine (3 blink loop) & the the led on the GPD lights up too. Do I need to power the OSD pro separately for it to show upon the PC? When I try to configure parameters to show up on the OSD, it says initializing & then OSD board is not detected
Another thing I tried was connecting a battery to the eloger & OSD to a camera. On the Video out I see the ET systems banner & no receiver detected. So the OSD works but doesnt want to get detected on the PC.
Any help will be appreciated.
PS:I've owned a remzibi OSD on my previos FPV system & none of the stuff in the ET system is reused.
Suresh
suri0712 is offline Find More Posts by suri0712
Old Mar 15, 2013, 05:20 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi Suresh,
Sorry to hear about the issue. The symptoms indicate that the OSD is receiving power, but that the eLogger is not able to communicate with the OSD.
I'd recommend these steps:
1) Please confirm that the GPS is connected in the TOP port (nearest the eLogger label) and that the OSD is connected to the bottom port, of the eLogger. With both connections, the red wire of the cable should be at the outer edge of the eLogger.
2) If that does not resolve it, could you check the OSD's cable to make sure there's not a loose pin or physical damage.
If neither of these resolves it, we'll need to get both pieces into our shop and replace the piece that has failed.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Mar 16, 2013, 07:14 AM
nogas is offline
Find More Posts by nogas
Because gas is for BBQ's
nogas's Avatar
Australia, QLD, Brisbane
Joined Feb 2011
Hi All,
I'm trying to get my UHF Rx connected using PPM. I am trying to follow the instructions given by Bill in march last year (see link below) but cant find the 'serial PPM ' button anywhere. I'm running v10.08. Please help asap, trying to get out tomorrow to make the most of this brief window of good weather.
http://www.rcgroups.com/forums/showp...postcount=8040
nogas is offline Find More Posts by nogas
Old Mar 16, 2013, 08:08 AM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
Originally Posted by suri0712 View Post
Hi,
Suresh
Check to see if all parts have the latest firmware.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Mar 16, 2013, 10:19 AM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Originally Posted by nogas View Post
Hi All,
Hi Nogas,
i donŽt use the ppm, but as far as i rember ppm needs a newer firmware than 10.08.
update to the latest alpha an youŽll see the button.
cu Thomas
Thint1 is offline Find More Posts by Thint1
Old Mar 16, 2013, 01:53 PM
surf1punk is offline
Find More Posts by surf1punk
RC FPVer
surf1punk's Avatar
United States, FL
Joined Nov 2011
I'm attempting to get my external mic working correctly and running into some buzzing issues.
I've gone through all the troubleshooting suggested, the OSD on/off makes no difference or white/black levels, And I even tried completely disconnecting the line in servo and only have the signal/ground wires going to the VTx from the audio out on the OSD. Still get an awful background hum.
The audio voice commands do work and I can hear them fine, just has a bad hum in the background constant. If I mute "external audio input" and the buzz goes away, doesn't seem to matter if the mic is connected or not. Also the mic does work, I get audio from it when connected but has the hum with it.
Where can I troubleshoot from here? Thanks!
Edit: I did a little more testing, tried a 10k resistor inline with the audio signal out to the Vtx, didn't stop the buzz, just made everything a bit quieter maybe.
Also I did find out if I unplugged my PPM servo wire from the OSD to the Rangelink PPM pins the buzz went away. I am using PPM out so just using the 1 servo wire. Is there some bad ground loop going on somewhere? Anyone else had audio issues using PPM?
surf1punk is offline Find More Posts by surf1punk
Old Mar 16, 2013, 04:00 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I have never had this issue, but I have read of a few people who have.
I am currious,
which mic and Vtx are you using?
I am convinced that it is a hardware issue...
Old Mar 16, 2013, 04:09 PM
RC FPVer
surf1punk's Avatar
United States, FL
Joined Nov 2011
I am currious,
It's the Mini Mic Amplified from ReadymadeRC http://www.readymaderc.com/store/ind...oducts_id=1039
And the 800mw 1.3 Vtx from ReadymadeRc http://www.readymaderc.com/store/ind...roducts_id=914
If you think its a piece of hardware being the issue, I get the buzz without any mic plugged in at all, so that would have to be the Vtx. But sound works fine and clear with just the voice alerts when I disable the external audio with that same Vtx....
Old Mar 16, 2013, 04:48 PM
wazoo22 is offline
Find More Posts by wazoo22
wazoo22's Avatar
France, Bourgogne, Nevers
Joined Feb 2012
I have the same mic, and my hum is 60-cycle.
Think of the audio hum that comes from an open or unshielded input lead on an amplifier- is the hum at that 60-cycle region? If so, it's a good clue.
It has been suggested, I think by Billpa, that inside your house or workshop is a high-hum environment, and you should try the same setup outside, away from power wiring. If that significantly reduces the hum, then we can take a shot at shielding some leads.
There is a copper foil tape made just for this problem on guitar pickups. Can be had on ebay. I got some to use myself, but haven't gotten around to it. To work, the tape will probably need to be grounded. You CAN solder to it, but it's delicate. It's not heavy.
wazoo22 is offline Find More Posts by wazoo22
Old Mar 16, 2013, 04:52 PM
RC FPVer
surf1punk's Avatar
United States, FL
Joined Nov 2011
Originally Posted by wazoo22 View Post
Think of the audio hum that comes from an open input lead on an amplifier- is the hum at that 60-cycle region? If so, it's a good clue.
It has been suggested I think by Billpa, that inside your house or workshop is a high-hum environment, and you should try the same setup outside, away from wiring.
Hmm yeah I've been testing indoors, I'll test later today outside and see if the results differ.
Old Mar 16, 2013, 05:56 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Good point.
If you are using a UHF, and the transmitter is next to your equipment, then that could be a cause, as well...
Old Mar 16, 2013, 05:58 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
surf punk,
I have not used either of these. I have used the mic from hobby wireless, and the Vtx from range video.
It will be interresting to get some feedback on possible causes of this anomaly.
Could you list your cam also for research purposes?
Thanks.
Old Mar 17, 2013, 12:38 AM
RC FPVer
surf1punk's Avatar
United States, FL
Joined Nov 2011
surf punk,
Thanks.
The camera is a 600tvl SONY 1/3 " Super HAD II CCD+Nextchip 2040 DSP.
Doing some more testing tonight, I found that if I boot it all up without my controller Tx on, there is no buzzing, as soon as I turn it on and the receiver binds to it, I get a buzz, but only after it binds. Turning it off after that point, the hum actually remains, and again, if I disconnect the 1 servo wire that goes to the PPM pins on the receiver the hum goes away.
I also walked far away with the Rangelink UHF Tx just to see if it made any difference, it did not, and I tried booting it up in micro power, made no difference, still initiated the buzz once it was bound.
My only next test would be to disable PPM and try wiring all the servos to see if there is any difference. Other than that, what could I do??
Old Mar 17, 2013, 02:29 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
It is worth a try to disable PPM.
I will be interested to see how it goes.
New Product OSD PRO from Eagle Tree (RTH, AHI, Waypoints, Variometer, Voice, now shipping) billpa FPV Equipment 11411 Jan 01, 2016 08:16 PM
New Product OSD from Eagle Tree with logging/Google Earth support billpa FPV Talk 552 Apr 28, 2009 01:21 PM
Discussion New Video On-Screen Display (OSD) Expander from Eagle Tree - $44.99 billpa Aerial Photography 0 Jun 08, 2008 11:30 AM
Pro Data Acquisition Systems now available from Eagle Tree billpa Product Announcements 0 Aug 02, 2005 01:56 PM
New USB data logger accessories and Holiday specials from Eagle Tree Systems billpa Product Announcements 0 Nov 08, 2003 01:51 PM
