Old Feb 12, 2013, 03:24 PM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Thanks, that's great, and I have all the options. Hopefully the ET stuff comes later today.
u2builder is offline Find More Posts by u2builder
Old Feb 12, 2013, 04:02 PM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
zxr static stats (0 min 17 sec)
Kloner is offline Find More Posts by Kloner
Old Feb 12, 2013, 06:55 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Originally Posted by Kloner View Post
Looks perfect.
m_beeson is offline Find More Posts by m_beeson
Old Feb 12, 2013, 07:12 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
One more thing: what are Aux1 in and Aux 2 in.
Old Feb 12, 2013, 07:26 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
You want to connect Aux 1 to a two position switch, and aux 2 to a three position switch.
Then designate the switching mode to 3 pos (rth)
This way you can navigate and select in the menu by using the two switches.
You can also involk RTH by using the three position switch.
There are other ways to configure the switches, and you can change them in the future, if you choose to do so,
but this is the best way to utilize them for set-up and calibration.
So, you take the aux 1 (two position switch) receiver channel, to aux 1 input on the osd, and etc...
Old Feb 12, 2013, 07:29 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Kloner,
Excuse my inability to remember...
What frequency are you on?
Old Feb 12, 2013, 08:05 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
This stuff is a huge help. I have read the manual but there is so much stuff and I am trying to get the wiring done. I am almost there, trying to get it right and organized as much as I can. I tried to put little stick on labels where I could. There are a lot of wires. Now I need to check and double check it all. I am still awaiting my Ubec.
Old Feb 12, 2013, 09:05 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
It is a bit of a process, but once you get it calibrated and tested sufficiently, you will be able to rely on it...
Old Feb 12, 2013, 09:56 PM
Kloner is offline
Aerial DP
Joined Apr 2010
Thats 2.4 video,,, lawmate, ezuhf for rc
got a 10x4 prop on there and shes running 1300 cont watts, got enough service there for 2000,,,,,, and 130mph. 70" ZXR, 42mm motor on 8s 800kv
Old Feb 13, 2013, 08:15 AM
jr4081 is offline
Find More Posts by jr4081
Joined Feb 2013
Hi! ​​Billpa Please help me answer my the osd pro download 10.44 software Guardian Stabilization Expandet horizontal line, AUX1 + AUX2 menu on one side only action, the display GRAPHICE ERROR 00000.EMAIL the SUPPORT Why?
jr4081 is offline Find More Posts by jr4081
Old Feb 13, 2013, 09:05 AM
Kloner is offline
Aerial DP
Joined Apr 2010
try booting the camera before the osd, especialy if this is a gopro. The one i posted above gave me that the first couple boots, it is 8s with 2x 4s in series and i was plugging them in the wrong order
Old Feb 14, 2013, 09:05 AM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
If I choose this method, is it also possible to somehow control the overall gain of the Guardian and/or turn stablilization using Aux 2?
Or to I do the one swith option for Aux 1 and then put Aux two on a variable switch for the Guardian?
Old Feb 14, 2013, 11:01 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
No, this method gives you full access to the menu, and you can configure it using the menu,
You will have to access the menu a lot for a while, until you get it configured.
Your first time through will be a learning process, so it should take longer than any future projects.
-Mike
Old Feb 15, 2013, 07:14 AM
Kloner is offline
Aerial DP
Joined Apr 2010
I like aux1 setup 3 way switch and aux2 for guard gain, mainly cause it is easier to get it out of an oscillation when it's a dial, for me the first few flights setting it all up. I use the servo deflection stats and figure out how high it can be set to then I go in and reduce the main gain. At that point I still like the knob to turn it down in no wind just to free it up a tad. In a lot of wind ill max it out
Old Feb 16, 2013, 08:45 AM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Well, I got it all wired up and no white smoke so that is good. I am confused about the throttle.
I have receiver connected to OSD in and then out to the ESC. Since I have a Ubec I have only the signal wire of the ESC connected. Everything works fine and the motor spins up.
For testing I removed the wire to the ESC and plugged a servo into the OSD out. The servo doesn't respond to throttle properly and sometime moves when I move another control like aileron. It works properly when connected directly to the RX channel.
I must be missing something. Any ideas?
New Product OSD PRO from Eagle Tree (RTH, AHI, Waypoints, Variometer, Voice, now shipping) billpa FPV Equipment 11420 Jul 22, 2016 05:10 PM
New Product OSD from Eagle Tree with logging/Google Earth support billpa FPV Talk 552 Apr 28, 2009 12:21 PM
Discussion New Video On-Screen Display (OSD) Expander from Eagle Tree - $44.99 billpa Aerial Photography 0 Jun 08, 2008 10:30 AM
Pro Data Acquisition Systems now available from Eagle Tree billpa Product Announcements 0 Aug 02, 2005 12:56 PM
New USB data logger accessories and Holiday specials from Eagle Tree Systems billpa Product Announcements 0 Nov 08, 2003 12:51 PM
