Old Jan 08, 2013, 07:49 PM
nickwad is offline
Find More Posts by nickwad
Nine inch member
nickwad's Avatar
Thailand, Chon Buri, Bang Lamung
Joined May 2006
OSD pro problem
I am quite new toeagletree my problem is that the flight sim does not go into come home when switching off transmitter.
I am trying to set up my skywalker with OSD /V4 elogger/gaurdian/GPS expander.
Spektrum dx8 .
I have been flying the skywalker LOS for some time with some rudder mixed in with the ailerons should I take this out when using the gaurdian ?
I have the reciever type set to pcm failsafe?
The stabilisation horizon etc are working OK.
any ideas what I could have set wrong?
nickwad is offline Find More Posts by nickwad
Old Jan 09, 2013, 12:23 AM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
set your radio failsafes.
set them to
throttle off, and trimmed all of the way down
all other sticks set to level flight.
then trim the throttle up to normal, and run servo analysis wizard.
That should fix the issue.
-Mike
Spektrum dx8 .
m_beeson is offline Find More Posts by m_beeson
Old Jan 09, 2013, 09:06 AM
nickwad is offline
Nine inch member
nickwad's Avatar
Joined May 2006
Thanks for the tip Mike I will try that tomorrow, I did set the failsafes for level flight and throttle down but did not do as you suggest with the throttle trim.
When running the servo analysis wizard should the sticks be for instance be pulled and released during the countdown period or pulled and held for the duration of the countdown ?
Old Jan 09, 2013, 09:18 AM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
On mine, had to make a failsafe with slightly lower endpoint settings to get it to kick in...... also make sure you got 1ch failsafe so it just looks at the throttle to change
i hold mine the duration of the countdown
Kloner is offline Find More Posts by Kloner
Old Jan 09, 2013, 03:12 PM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Hi,
like kloner mentioned ... before running the wizzard you have to store the failsafe for throttle on the right position to your rx.
on a spectrum rx/tx: trimm throttle down (or prog a switchable mix ... -150% from switch X to throttle) - plug in the bining plug - power on the tx - switch on the mix or let the throttle trim down before you switch off the tx - press and hold the bind pushbutton on the tx an switch on - wait until rx and satellite shows a solid lightening led - release pushbutton -plug out the binding plug - disconnect rx - switch off tx.
rerun the wizzard: hold the sticks in the asked position until the next step is shown on screen ... the asked stick-position is stored when the countdown reaches 0, so itīs better to wait until the next step is shown.
cu Thomas
Thint1 is offline Find More Posts by Thint1
Old Jan 13, 2013, 04:02 PM
u2builder is online now
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
How to Set Eagle Eyes Battery Alarm Voltage
Directions indicate setting volts and fraction of volts.
However, I see only one number to set. Default is 100. Does this mean 10.0 volts? If I want 11 volts do I set 110? Or am I missing something? Thanks.
u2builder is online now Find More Posts by u2builder
Old Jan 13, 2013, 04:16 PM
Thint1 is offline
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Hi,
yes, thatīs right!
cu Thomas
Old Jan 13, 2013, 04:33 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Originally Posted by Thint1 View Post
Hi,
yes, thatīs right!
cu Thomas
Thanks!
Old Jan 14, 2013, 09:44 PM
johnfly1234 is offline
Find More Posts by johnfly1234
United States, KS, Arkansas City
Joined Oct 2012
I am trying to set up the dual a/d expander but i am having an issue.... looking for guidance.
I am using the dual a/d for low voltage readout so the voltage into it is 5.5 volts or less "determined by external pots" here's the issue.
If i power up the ad first it powers up the data recorder but not the osd then when i turn on the radio gear the ad sensor works but the osd displays an error to email eagletree osd has internal failure.... but sensors work.
If i power up the radio gear then the ad I don't get an "internal osd error" but the sensors don't work..... does anybody have any ideas.
The sensors i have hooked to it "just to clarify and i figure someone will ask anyway"
I gutted 2 old servos utilized the boards and tapped into their electronics to get a low voltage output of the pot location. voltage output on the signal side from pot is from 0 to 2.5 volts. If that helps!
johnfly1234 is offline Find More Posts by johnfly1234
Old Jan 15, 2013, 06:56 PM
Rickn816 is offline
Find More Posts by Rickn816
RCHN #150
Rickn816's Avatar
Lawrenceville, GA
Joined Nov 2007
A Simple Request
Yes, I read every post. Yay me!
Dear Eagle Tree,
While I like the modular nature of your product, mounting all of those pieces in an airframe can be a PITA.
Please give me a combination in a BOX, with appropriate connectors. What should be in the box? For me, it would be eLogger, OSD/Pro, and Guardian.
The BOX would need connections for servos, batteries, and the 4-pin connectors for other features. And the USB port.
In fact, the manufacturing costs may be less over-all if these three devices on one circuit board.
Thanks.
Rick
Rickn816 is offline Find More Posts by Rickn816
Old Jan 24, 2013, 08:56 AM
V_Okto is offline
Find More Posts by V_Okto
Joined Feb 2011
Hey is it important what order you connect the ET components with each other?
i want to connect:
gps <->guarian <-> osdpro <- >logger
or has it to be
osdpro <-> logger <- guard <-< gps
V_Okto is offline Find More Posts by V_Okto
Old Jan 24, 2013, 09:12 AM
Kloner is offline
Aerial DP
Joined Apr 2010
as long as gps is by itself, the daisy chain doesn't seem to matter on the osd side
gps> logger<osd<guardian<baromter (if have it)
Old Jan 24, 2013, 05:14 PM
Joined Oct 2012
I am having trouble with osd losing the firmware version..... i have to load it over and over but still shows as unknown..... it will adventually take but i don't understand why i have to load it over and over and over??????????? any thoughts?
Old Jan 24, 2013, 09:42 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
The computer in my garage is a little slower than the one that I normally use.
I can really struggle with that one, and setting up the firmware.
I don't know if that helps much, but what you are explaining, "that shouldn't be happening".
Old Jan 25, 2013, 07:24 AM
Kloner is offline
Aerial DP
Joined Apr 2010
I'd hit "HELP", "display settings", "email support info to eagle tree"
New Product OSD PRO from Eagle Tree (RTH, AHI, Waypoints, Variometer, Voice, now shipping) billpa FPV Equipment 11441 Aug 30, 2016 11:40 PM
New Product OSD from Eagle Tree with logging/Google Earth support billpa FPV Talk 552 Apr 28, 2009 12:21 PM
Discussion New Video On-Screen Display (OSD) Expander from Eagle Tree - $44.99 billpa Aerial Photography 0 Jun 08, 2008 10:30 AM
Pro Data Acquisition Systems now available from Eagle Tree billpa Product Announcements 0 Aug 02, 2005 12:56 PM
New USB data logger accessories and Holiday specials from Eagle Tree Systems billpa Product Announcements 0 Nov 08, 2003 12:51 PM
