Old Dec 21, 2012, 11:44 PM
iskoos is offline
Find More Posts by iskoos
Orlando, FL
Originally Posted by johnfly1234 View Post
Just in from eagle tree....... copied from the "ticket"
Sorry for the delay, the OSD Pro Expander can accommodate servos of voltages up to 7V and current up to about 5A per channel. Unfortunately, we suspect that damage to the OSD Pro could occur when used with fully charged LFe packs.
I don't know why they replied your question like that. Almost all ET equipments (loggers, sensors...) are good up to about 15 volts. So any 2s-3s lipo could be used no problem. I don't understand how your life pack would be an issue...
iskoos is offline Find More Posts by iskoos
Old Dec 22, 2012, 12:59 PM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I bought one of these.
http://www.ebay.com/itm/280788636283...84.m1497.l2649
I plug it into one of these:
http://www.readymaderc.com/store/ind...roducts_id=747
I plug that into a 3S Lipo. So I can power everything that needs around 12V power.
u2builder is offline Find More Posts by u2builder
Old Dec 22, 2012, 09:39 PM
johnfly1234 is offline
Find More Posts by johnfly1234
United States, KS, Arkansas City
Joined Oct 2012
I find the ends that i need and then solder them to the plug that fits the battery or cut the connector off the battery and put a deans on it. Just be sure to check your polarity before you solder everything up. Also don't forget to put the heat shrink on the wires before you solder.You have everything you need in the photo.
johnfly1234 is offline Find More Posts by johnfly1234
Old Dec 23, 2012, 07:58 AM
quickpix is offline
Find More Posts by quickpix
Quickpix
Joined Apr 2012
Originally Posted by billpa View Post
It sure is!
http://www.rcgroups.com/forums/showt...ight=eagleeyes
Regards,
Bill, for Eagle Tree
I have been fighting another brand system for most of the year and still don't have it working properly or reliably. It is soo darn hard to adjust.
I know some trial and error setup is required.
That said: I need an OSD/Stabilization/RTH unit that is easy to setup and reliable.
I have all the best equipment already.
Convince me, please.
quickpix is offline Find More Posts by quickpix
Old Dec 23, 2012, 10:47 AM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Nothing is easy, until you learn it.
That's why we help you get it set up.
It is up to you to learn it, so that it is easy to you.
there are plenty of resources for learning the system.
there are the manuals, there is this thread, and I have made some tutorials on my blog.
You can look around for more tutorials.
The one thing that I can say for Eagle tree is that it is reliable.
You can spend your time trying to set up another system, and never get it to work just right, or you can set this one up. and fly...
That's how I look at it.
m_beeson is offline Find More Posts by m_beeson
Old Dec 24, 2012, 05:46 AM
tritan is offline
Find More Posts by tritan
Joined Apr 2007
I have used E.T for many years now and I am very happy with it. It can be very complicated if you want but also very, very easy - in others words it is very flexible to suit both beginners and pros.
I am using the OSD pro but I can choose how many (or few) things/sensors i want to use. E.T has very thorough manuals and best of all - if you need help they have extremly good customer service.
tritan is offline Find More Posts by tritan
Old Dec 30, 2012, 01:50 AM
mumupilot is offline
Find More Posts by mumupilot
Joined May 2011
value in Configure OSD Display menu
Hi all
I am configuring OSD display part with TX switch and i don't find an array with indication of the mining of number on each item of the menu
There is nothing in the OSD Manual
Thank for help
Best regard
mumupilot is offline Find More Posts by mumupilot
Old Dec 30, 2012, 10:42 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Hi mumupilot.
I am sorry, I cannot figure out what you are trying to say.
Maybe if you type it in your native language, that may be useful.
-Mike
Originally Posted by mumupilot View Post
Hi all
Thank for help
Best regard
Old Dec 30, 2012, 11:54 AM
Joined May 2011
Hi Mike
Thank you to try to help me
Finaly i find the array wich give the number need to be set to display for instance the AHI or radar on 1,2 or three osd pages
I have two new question
1)After finishing all setting and configuration on OSd ,I have a new message on screen :internal error 60000 email support!!!!!
Except this message all seem running normaly
Do some boddy know the origine of it before i open a ticket
I try to update the firmware a second time (osd 2;66) (e logger v4; 1,21) (gardian expender 1,19)
e logger is provide with GPS v4 and external pilot tube option,no barometric altitude option
2)Does the RTH is running correcly with only external pilot tube for speed and GPS Altitude information or i need to have external barometric altitude option
In case of GPS altidude is use, the setting of RTH altitude need to be in accordance with the initial groud level of take off or not?
Sorry for my English
Thank again
Best regard
Old Dec 30, 2012, 12:13 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I cannot find any reference to that error. I don't know what has caused it.
You can email Bill and he can tell you about your error.
RTH will work with gps only, you do not need to have the altimeter microsensor.
Best to get a good gps lock, and then reset home position so all is close to "0".
You may experience a little gps drift but for the most part, that is ok. The most important part is that the plane responds correctly in RTH.
When you first test RTH make sure that you have enough altitude to take control of the plane if it does not respond correctly.
Thank again
Best regard
Old Jan 01, 2013, 09:57 AM
carlocivicsi is offline
Find More Posts by carlocivicsi
United States, FL, Miami
Joined Mar 2012
new video.
zii cloud SURFING. (4 min 9 sec)
carlocivicsi is offline Find More Posts by carlocivicsi
Old Jan 01, 2013, 09:07 PM
stevo6739615 is offline
Find More Posts by stevo6739615
yakum smakum
stevo6739615's Avatar
United States, FL, Naples
Joined Jan 2012
ET and Rangelink set up
Hello,
Is there anyone out there who is or has set up an ET system with a Rangelink LRS, or can someone tell me what thread I can go to so I can get some answers for some questions I have on my setup?
Thanks in advance,
Steve S. Naples, Florida
stevo6739615 is offline Find More Posts by stevo6739615
Old Jan 01, 2013, 09:20 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
What's happening stevo?
Originally Posted by stevo6739615 View Post
Hello,
Thanks in advance,
Old Jan 04, 2013, 06:41 PM
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
I have an RSSI question that I posted here in case BillPa or someone else has some suggestions:
http://www.rcgroups.com/forums/showthread.php?t=1130784
Basically I can't figure out how to get ET Pro OSD to display my RSSI signal. It works on a Skylark OSD but I can't get it to work on the ET. I am probably doing something wrong but need help.
Old Jan 04, 2013, 06:54 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
http://www.rcgroups.com/forums/showp...&postcount=161
New Product OSD PRO from Eagle Tree (RTH, AHI, Waypoints, Variometer, Voice, now shipping) billpa FPV Equipment 11420 Jul 22, 2016 05:10 PM
New Product OSD from Eagle Tree with logging/Google Earth support billpa FPV Talk 552 Apr 28, 2009 12:21 PM
Discussion New Video On-Screen Display (OSD) Expander from Eagle Tree - $44.99 billpa Aerial Photography 0 Jun 08, 2008 10:30 AM
Pro Data Acquisition Systems now available from Eagle Tree billpa Product Announcements 0 Aug 02, 2005 12:56 PM
New USB data logger accessories and Holiday specials from Eagle Tree Systems billpa Product Announcements 0 Nov 08, 2003 12:51 PM
