Old Dec 11, 2012, 12:17 PM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Originally Posted by tritan View Post
UPDATE:
it worked fine with the neighbourgs laptop but I was a bit puzzled why it didnt worked on my old laptop. Well, I asked my neighbour again and as he is employed at a well known software company he talked to some of his friends at work and found that I probably just had to change the fonts from large to normal in the control panel - thats it! So now I again can use my IBM oldie from the mid 90's again with ET software OSD!
Hi tritan,
thank you for sharing the solution of this problem .... now iīm a little bit "wiser" than before.
cu Thomas
Thint1 is offline Find More Posts by Thint1
Old Dec 11, 2012, 12:38 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I would have never guessed it.
UPDATE:
m_beeson is offline Find More Posts by m_beeson
Old Dec 11, 2012, 02:55 PM
Thint1 is offline
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
thatīs exacty what i like at rc-groups, especially the "ET branch" ... a response how the problem was solved
cu Thomas
Old Dec 12, 2012, 02:33 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
WOW, glad that worked, tritan. That's one to add to our list of unexpected solutions.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Dec 12, 2012, 03:04 PM
tritan is online now
Find More Posts by tritan
Joined Apr 2007
Actually, the day after I got the help from my neighbour, which solved my problem, I also got a reply from ET, as I thought that, well as they claim at ET to have a customer service I might as well try them. To my big surprise ( in my 35+ years of RC flying I am not used to get good customer service) I got a reply from ET by email with the exact same solution!
I am really impressed and I will continue to be a loyal customer to ET.
/Tritan
- eLogger v4 (100A)
- eLogger v4 (150A)
- OSD pro
- GPS v4
- Power Panel
- Altitude microsensor v4
- 2x Brushless Motor RPM Sensor V2
- 2x Micro Temp Sensor
- 2x Temperature Sensor LOOP
tritan is online now Find More Posts by tritan
Old Dec 14, 2012, 04:41 PM
johnfly1234 is offline
Find More Posts by johnfly1234
United States, KS, Arkansas City
Joined Oct 2012
I have been waiting for 4 days now for some basic voltage info........ Hmmmmmm.
johnfly1234 is offline Find More Posts by johnfly1234
Old Dec 14, 2012, 04:46 PM
Thint1 is offline
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Hi,
whatīs your question?
cu Thomas
Old Dec 14, 2012, 04:58 PM
Joined Oct 2012
I don't need a guess...... I need to know!!! I am going to be putting a 16,000.00 plane on the line.And it's not my money.
1. Will the osd handle 2cell life voltage. ie 6.3 to max 7volts.
2. Will the osd handle a 4 amp servo load?
Old Dec 14, 2012, 05:56 PM
Joined Oct 2012
Just in from eagle tree....... copied from the "ticket"
Sorry for the delay, the OSD Pro Expander can accommodate servos of voltages up to 7V and current up to about 5A per channel. Unfortunately, we suspect that damage to the OSD Pro could occur when used with fully charged LFe packs.
Old Dec 14, 2012, 06:04 PM
Joined Oct 2012
Allthough a fully charged life pack is 7.2volts. as soon as the charger stops balancing and stops applying current, the battery drops to about 6.7~6.8 within a minute. just offering this as info ............ I think i may go another route as i am really not interusted in risking my word on 2 tenths of a volt !!!!!!!!!
Thanks to all that responded and have a merry Christmas.
Old Dec 17, 2012, 06:36 PM
junioro16v is offline
Find More Posts by junioro16v
junioro16v's Avatar
Brazil, PR, Curitiba
Joined Mar 2009
Originally Posted by junioro16v View Post
Hey guys,
I think I already read about that but I canīt find where.
There are any plans on ET to implement automatic waypoints navigation or this is an "out of running" feature?
junioro16v is offline Find More Posts by junioro16v
Old Dec 18, 2012, 05:59 AM
garris2 is offline
Find More Posts by garris2
Australia, VIC, Glen Waverley
Hi Johnfly, the OSD will have no problem in your scenario as it does not power your servos.
As such it does not need to deliver high currents.
The servo connections are "pass through" so you can put what ever voltage you like to power your radio gear and the OSD will not be affected.
This design makes it very flexible in being able to meet the wiring design of many people and situations.
The manual explains it well.
http://www.eagletreesystems.com/support/manuals.htm
garris2 is offline Find More Posts by garris2
Old Dec 20, 2012, 08:09 PM
Verify is offline
Find More Posts by Verify
Joined Aug 2012
Ground stn and tx questions
Hi Everyone, ground stn and tx questions, with pictures.
GROUND STATION
I have a few questions about my ground station set up. Basically getting power to it.
I have a 12 channel receiver, and Eagle Eyes Distribution Box, a and a Turnigy 4000 Mah
Battery.
A) Transmitter needs power
B) Eagle Eyes needs Power
C) I have the barrel plug and wire that fits both Transmitter and Eagle Eyes,
D) End of wire with Barrel plug on it
E) Battery
Does anyone know what goes where and how?
FPV EAGLE / TRANSMITTER / GO PRO
Also a few questions, as in the photo
A) The video signal to the tx
B) The video signal from the Go Pro * What type of connector should I use? This cord is way too long and
I have to cut it down. Which I have no skill at doing, is there an after market cable?
C) A inline fuse I am considering putting between the power and the tx
D) E Logger V4 * Does the battery power connect here?
E) Red wire power to camera Blk to ground. * Do I need power to camera if the GO Pro camera
battery will be enough?
Is there anyone out there that would be interested in being paid to put this all together for me?
Verify is offline Find More Posts by Verify
Old Dec 20, 2012, 09:17 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
You need to add to your profile; where you are from...
Maybe there is someone near you...
Old Dec 21, 2012, 07:15 AM
Jeff Watt is offline
Find More Posts by Jeff Watt
Joined Dec 2004
Try this for "B" (GoPro video connection)
http://www.readymaderc.com/store/ind...roducts_id=290
Jeff Watt is offline Find More Posts by Jeff Watt
New Product OSD PRO from Eagle Tree (RTH, AHI, Waypoints, Variometer, Voice, now shipping) billpa FPV Equipment 11420 Jul 22, 2016 05:10 PM
New Product OSD from Eagle Tree with logging/Google Earth support billpa FPV Talk 552 Apr 28, 2009 12:21 PM
Discussion New Video On-Screen Display (OSD) Expander from Eagle Tree - $44.99 billpa Aerial Photography 0 Jun 08, 2008 10:30 AM
Pro Data Acquisition Systems now available from Eagle Tree billpa Product Announcements 0 Aug 02, 2005 12:56 PM
New USB data logger accessories and Holiday specials from Eagle Tree Systems billpa Product Announcements 0 Nov 08, 2003 12:51 PM
