Old Dec 06, 2012, 02:39 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
There is a timer.
I can't remember exactly where it is, but I think it is under "Items to be displayed"
I use it all of the time.
-Mike
Originally Posted by tritan View Post
Hi,
I am flying AP with multikopter and I am looking for a timer in my OSD pro but cant find any - is there such timer? I reda it badly to have control of how much I can fly until my battery ends. I am of course using the mAh but I also want a timer.
m_beeson is offline Find More Posts by m_beeson
Old Dec 06, 2012, 02:51 PM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Originally Posted by m_beeson View Post
There is a timer.
-Mike
Hi,
additional to Mikeīs post a copy from the manual:
The Flight Timer feature is turned on and off via the PC software, as described in the Configuring Graphics Display section below, and can also be configured via the “Flight Timer/Elapsed Time” on-screen menu item.
this timer is counting the time since the first gps-fix ... therfore i do "reset home position" shortly before the takeoff to have a proper flight time.
cu Thomas
Thint1 is offline Find More Posts by Thint1
Old Dec 06, 2012, 03:54 PM
tritan is offline
Find More Posts by tritan
Joined Apr 2007
Thanks guys,
Too late now, but tomorrow I'll check again.
Thomas. how do I reset home position? I will have to do that just a couple of seconds before take off.
Thanksn
Hakan
tritan is offline Find More Posts by tritan
Old Dec 06, 2012, 04:09 PM
Thint1 is offline
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Thanks guys,
Thanksn
Hakan
Hi,
osd main menu - first selection
cu Thomas
Old Dec 06, 2012, 04:47 PM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
it's in there where you enable the ladders, artificial horizon in osd setup........ has a timer that counts up
live feed over walters K450 (5 min 28 sec)
Kloner is offline Find More Posts by Kloner
Old Dec 06, 2012, 09:53 PM
johnfly1234 is offline
Find More Posts by johnfly1234
United States, KS, Arkansas City
Joined Oct 2012
I am trying to hook up an fpv system mainly for the data collection. The airplane is large and gas powered and allthough i have the elogger v4 I don't plan on running major current through it. also have osd pro,Flight data recorder and host of other stuff...... but first .....
1. Will the osd handle current loads of possibly 4 amps per channel ?
2. Can i run 2s life packs ? I know it's ok for radio gear not sure about et stuff.
3. Does the data recorder somehow plug into the osd or is it a standalone recorder?
I realize these questions have maybe been asked but if they have I can't find them.... I have been educating myself for the last 4 days and i think my eyes are beginning to bleed!!!
Thanks in advance ............. John.
johnfly1234 is offline Find More Posts by johnfly1234
Old Dec 06, 2012, 10:44 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
2S Life packs are 7.2 Volts. That is just fine.
I'm not sure what you are getting at ith the 4 amps per channel, so I am reluctant to answer.
I did a preliminary search, and didn't find what I was looking for.
According to this picture, it is possible to connect your OSD to the Data Recorder.
I would have to read more in depth to figure out where it hooks. I searched the manual, and didn't find it, but I'm sure it is there.
It is just a little unclear as to how you want to configur the equipment, and what you want to accomplish, so I don't know how to approach it.
Concerning the amps, I would email Bill. He knows the system, and could give you a definite answer.
Old Dec 07, 2012, 12:58 AM
wazoo22 is offline
Find More Posts by wazoo22
wazoo22's Avatar
France, Bourgogne, Nevers
Joined Feb 2012
Originally Posted by Thint1 View Post
Hi,
yes, iīve tried this .... but i used a mixer that iīve build by myself 20 years ago (at a time before my first computerized transmitter). this mixer has potentiometers to match the pulse-lenght and servo-throw. unfortunatelly i lost the layout, therefore i canīt post it
so i linked to the hk-mix ... sorry that this mix doesnīt perform well.
your idea to use a guardian 2d-3d may work ... i donīt have a 2d-3d, but your configuration (ailerons and v-tail) is listed in the manual. therefore my opinion is "should work".
for rth functions i suggest to connect the osd between receiver and aileron/elevator on the 2d-3d - same like you wrote before.
cu Thomas
OK, so I've reorganized the control system as we discussed, daisy-chained. Can't test it yet, even on the bench, because my cat knocked my trans off the bench and broke off the 3-pos switch I was gonna use for mode, so it's in the shop- too tiny and cramped in there for me to repair myself. Anyway, it's snowing hard.
I plan to use one 3-pos for the 2D/3D mode, and the other for OSD on screen menu.
As I understand it, both units are pass- through when off. -right?
That way, if the two fall to arguing about how much aileron to use or something, I can pull someone's plug.
We're way into the twilight zone here-
Jim
wazoo22 is offline Find More Posts by wazoo22
Old Dec 07, 2012, 03:40 AM
tritan is offline
Joined Apr 2007
http://www.youtube.com/watch?v=_kPrsWtZ6rU
This box/window called: select graphical items for page1 is gray and has no text in it - how can I change that?
- eLogger v4
- OSD pro
- GPS
- Altitude microsensor v4
Old Dec 07, 2012, 05:54 AM
Thint1 is offline
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
- eLogger v4
- OSD pro
- GPS
- Altitide microsensor v4
Hi tritan,
there is a triangle-sign on the right side ... push it and a pull-down opens
see this post http://www.rcgroups.com/forums/showp...postcount=9703
cu Thomas
cu Thomas
Old Dec 07, 2012, 07:38 AM
tritan is offline
Joined Apr 2007
Hi tritan,
cu Thomas
cu Thomas
Hi Thomas,
it is the box in red I mean - it is completly gray and no drop down list!
No matter what I do I cant open it. I have selected different sensors such as Altitude, rpm etc and it is still gray ....
I upgraded from 10.04 to 10.43 to see if that changed anything but no. Before this I had the green area full of data - I have always wondered where people found the ladders beacuse I have never found them - I have always had this gray area.
Old Dec 07, 2012, 08:31 AM
Thint1 is offline
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Hi Thomas,
Hi tritan,
iīve never seen this before ... sorry, i can only guess whatīs going wrong with your equipment.
maybe your settings file is corrupted ... before you open a support ticket at eagle tree we can try to program your osd with my settings and see what happens.
iīll post my txt-file later, in the meantime you can try "Factory Reset" and test the behavior.
cu Thomas
Old Dec 07, 2012, 09:53 AM
tritan is offline
Joined Apr 2007
Hi tritan,
cu Thomas
I tested factory reset and reset parameters and when I do the text in that grey area becomes visible for about 0,2 seconds ....... and then return immediatly to grey again.
Old Dec 07, 2012, 10:38 AM
Thint1 is offline
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Hi,
here are my settings. try them - if they donīt work also, i suspect a problem with windows. do you have another pc to test?
cu Thomas
Old Dec 07, 2012, 10:51 PM
Joined Oct 2012
Ok..... I do not know how the osd can plug into the elogger and the data recorder!!!! Please clarify. and not by showing me a picture of a bunch of components!
1. My servos can draw up to 4 amps.... if we start at the reciever the ail, elev,and throttle all connect to the osd. Then from the osd to the perspective servos. If the servo draws 4 amps of current will the osd handle that kind of current ????? realize that the ail. and elev. can draw a total of 4+4 = 8amps !!! The throttle servo i am not worried about. Low current...
New Product OSD PRO from Eagle Tree (RTH, AHI, Waypoints, Variometer, Voice, now shipping) billpa FPV Equipment 11441 Aug 30, 2016 11:40 PM
New Product OSD from Eagle Tree with logging/Google Earth support billpa FPV Talk 552 Apr 28, 2009 12:21 PM
Discussion New Video On-Screen Display (OSD) Expander from Eagle Tree - $44.99 billpa Aerial Photography 0 Jun 08, 2008 10:30 AM
Pro Data Acquisition Systems now available from Eagle Tree billpa Product Announcements 0 Aug 02, 2005 12:56 PM
New USB data logger accessories and Holiday specials from Eagle Tree Systems billpa Product Announcements 0 Nov 08, 2003 12:51 PM
