Old Nov 06, 2012, 07:50 PM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
the wobble is whats driving me nuts. when it rolls over then does 2 or 3 little wobbles, not me..... the other thing is when i roll it on it's side, it does a wag towards where i want, then holds straight, then wags right, then holds.
I had just added these half way down the wing. it made alot less wag, especially for wind, but i think are responsible for that turn then not part.....
and the wing tips are about 1.5" longer than normal.... again trying to make some drag out the back to slow the wag. honeslty if that's all was there i'd be tickled.
Were leaving for the river thursday so i plan spending some time flying laps working on gains in flight to see if i can fix this thing once and for all. i was so close, but tail heavy and all a sudden, all this wobble. think it's been there, just gets pronounced in wind
check out my zxl
Kloner is offline Find More Posts by Kloner
Old Nov 06, 2012, 08:42 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
That is good looking.
Ya,
the first thing I would do is lower guardian responsiveness.
m_beeson is offline Find More Posts by m_beeson
Old Nov 06, 2012, 09:07 PM
Kloner is offline
Aerial DP
Joined Apr 2010
ok,,, for sure that's not an oscillation that guardian is supressing? like i got the ail gain too high?
heres some fun stuff
saturday @ daves live feed (7 min 53 sec)
Old Nov 06, 2012, 09:44 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
Way cool video.
2.8 mi right off the deck, that's pretty good.
i.e. guardian roll gain. I think you're right. I had mine at 4.
The wings are so much more efficient, that it doesn't take much to level them out, and anything excessive just works against you.
http://www.youtube.com/watch?v=KFUPCDIbfhk
Old Nov 11, 2012, 05:15 AM
goryc is offline
Find More Posts by goryc
Italy, Sicilia, Messina
Joined Apr 2011
Tiny-Mic DPCAV
I bought the Tiny-Mic DPCAV to record the sound. Failing to make it work I measured the voltage on OSD Pro Audio In and zero (0V) while on Video In is 12V. In your opinion is dead? I have to do something to feed the microphone? I can solve it by a cable to Y only for the power of Video In? Thank you.
goryc is offline Find More Posts by goryc
Old Nov 11, 2012, 05:32 AM
goryc is offline
Joined Apr 2011
Sorry but I panicked! The second solution is functioning and described in the manual! Need a separate power supply for the microphone slot Audio In port no power. Thanks anyway and sorry.
Old Nov 11, 2012, 07:52 AM
Kloner is offline
Aerial DP
Joined Apr 2010
mike, got the gains figured out to change from the radio, reliably and for sure that was a suppresion thing going on. it still was having a weird time making turns so i went back to the last mod i did and revisited them fins half way down the wing. i'm convinced it is either having that fin out over the front odge of the wing so i trimmed off that part and will try it again shortly. The wobble part is gone, but it is still turning 4 degrees then oscillates back a little then grabbed 4 degrees, over and over. It was not doing that before i added those.
Old Nov 11, 2012, 08:04 AM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
sorry but i panicked! The second solution is functioning and described in the manual! Need a separate power supply for the microphone slot audio in port no power. Thanks anyway and sorry.
cool
Originally Posted by kloner View Post
mike, got the gains figured out to change from the radio, reliably and for sure that was a suppresion thing going on. It still was having a weird time making turns so i went back to the last mod i did and revisited them fins half way down the wing. I'm convinced it is either having that fin out over the front odge of the wing so i trimmed off that part and will try it again shortly. The wobble part is gone, but it is still turning 4 degrees then oscillates back a little then grabbed 4 degrees, over and over. It was not doing that before i added those.
cool
Old Nov 12, 2012, 08:20 PM
daniel sanguinet is offline
Find More Posts by daniel sanguinet
Daniel del Chaco
Joined Sep 2012
Originally Posted by cvandenb View Post
Hi Kyle,
The OSD Pro has and supports Artificial horizon. We are waiting for the expander board to support the FMA co-pilot unit and then it will be fully integrated.
I have an artificial horizon osdpro but the PC software does not move, does not work, that problem?
thanks
daniel sanguinet is offline Find More Posts by daniel sanguinet
Old Nov 14, 2012, 02:45 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi Daniel, the PC AHI display is presently only active when used with EagleEyes telemetry.
billpa is offline Find More Posts by billpa
Site Sponsor
Old Nov 18, 2012, 03:38 AM
goryc is offline
Joined Apr 2011
Can be changed with a potentiometer radio sensitivity of the Guardian? And if you can as I do? thanks
Old Nov 19, 2012, 07:50 PM
The Job is offline
Find More Posts by The Job
Joined Nov 2012
Osd eagletree fail
Dear Friends, I am very sad about my OSD. You can see on the video link below 3 differents problems:
http://www.youtube.com/watch?feature...&v=tBQp1u-7SM4
1 - OSD data start change the color, and shake a lot during the flight.
2 - OSD display a text info: erro 0000000000 e-mail support
3 - My RTH never works.... My airplane always turns around (circle)and never come home!
Important info:
That problem number 1 and 2 is new. The first time that I could observe that error, was on my 7o flight.
If you need to see another example. Please, check this video too:
http://www.youtube.com/watch?feature...&v=dFyOKKYzVfY
Obs.: I have a forum on the web with 34.500 views on Brazil... waiting for a good answer. Help us!
The Job is offline Find More Posts by The Job
Old Nov 19, 2012, 08:20 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
I suspect the video issues are related to your camera, antennas, or something along that line.
For your return to home.
I see some issues with your settings.
Please post your config file, so we can take a look at it.
-Mike
In the mean time:
Here is some good study material
http://www.rcgroups.com/forums/showthread.php?t=1717573
Important info:
Old Nov 20, 2012, 05:52 AM
u2builder is offline
Find More Posts by u2builder
u2builder's Avatar
USA, NH, Alstead
Joined Oct 2007
Can I plug the audio as well as the video outputs of the Eagle Eyes into the audio/video jack on a small LCD TV. There is some mention in the manual about making sure the audio is not plugged into "speakers" and I just want to make sure I can plug it into the TV using the type of cable that has audio and video RC jacks on one end and a combined AV jack on the other end that goes into the TV.
u2builder is offline Find More Posts by u2builder
Old Nov 20, 2012, 07:02 AM
Thint1 is offline
Find More Posts by Thint1
Thint1's Avatar
Austria / Vienna
Joined Feb 2007
Hi,
yes, you can.
to "translate" the manual: the eagle eyes has no amplifier for audio - therefore you arenīt allowed to connect the audio signal directly to speakers!
as long as you connect the audio to signal inputs (e.g. connectors called audio in, line in, ...) all is fine.
cu Thomas
Thint1 is offline Find More Posts by Thint1
New Product OSD PRO from Eagle Tree (RTH, AHI, Waypoints, Variometer, Voice, now shipping) billpa FPV Equipment 11441 Aug 30, 2016 11:40 PM
New Product OSD from Eagle Tree with logging/Google Earth support billpa FPV Talk 552 Apr 28, 2009 12:21 PM
Discussion New Video On-Screen Display (OSD) Expander from Eagle Tree - $44.99 billpa Aerial Photography 0 Jun 08, 2008 10:30 AM
Pro Data Acquisition Systems now available from Eagle Tree billpa Product Announcements 0 Aug 02, 2005 12:56 PM
New USB data logger accessories and Holiday specials from Eagle Tree Systems billpa Product Announcements 0 Nov 08, 2003 12:51 PM
