Old Sep 13, 2012, 09:30 PM
m_beeson is offline
Find More Posts by m_beeson
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
elogger is part of the OSD. They work in conjunction with each other.
The GoPro takes pretty good HD video in a variety of conditions, with the exception of Low Light.
But it is not the best at Live feed video. It has something to be desired.
I would think that you would want to get the best video possible to your ground station recorder and to your on board HD cam...
http://www.eagletreesystems.com/
Originally Posted by paulskyone View Post
m-beeson
Why do you say I will need the elogger...I thought this is for monitoring electrical power systems?
1.2/1.3mhz 1.5watt vtx and a yagi antenna on the video receiver. Would this be sufficient in your opinion?
The GPS sensor is necessary for recovery of the gondola. I also have a spot GPS that I can use as well, but I was looking to try to simplify.
I am also considering lifting an RC airplane (instead of a gondola) and then fly it back. (as far as I am concerned there is no need for a gondola anymore, just lift an RC plane to 80,000 feet and then fly it down with video link.) What are your thoughts?( I know there are some high altitude aerodynamics to consider here, but it would be an interesting experiment anyway.) I am a pilot for Southwest Airlines so I am somewhat familiar.
I will consider both methods for the video feed (Go Pro / Security Cam). I saw on futurehobbies.com that they have the wiring harness for rigging up a GoPro to transmitter.
M-beeson, thanks you for taking the time to pass along some info! I appreciate it.
PK
m_beeson is offline Find More Posts by m_beeson
Old Sep 18, 2012, 01:41 PM
Kloner is offline
Find More Posts by Kloner
Aerial DP
United States, CA, Lakeside
Joined Apr 2010
this is the same recorder, one is the pixim 690 from security2000 and the second is a hero2 live feed
telink multifun FPV (7 min 13 sec)
2012 labor day disco live feed (4 min 30 sec)
Kloner is offline Find More Posts by Kloner
Old Sep 18, 2012, 05:24 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
http://www.youtube.com/watch?v=I50lk7PMsPc
http://www.youtube.com/watch?v=1RbtAjH8LF4
Sweet
Old Sep 18, 2012, 08:19 PM
junioro16v is offline
Find More Posts by junioro16v
junioro16v's Avatar
Brazil, PR, Curitiba
Joined Mar 2009
Hi guys.
I need some help.
I'm getting a lot of noise on my audio.
I made few tests. If I disconnect video out from osd to vtx and transmit only audio from osd Mic/Alarms, the sound is very clear.
If I connect video out in vtx, a lot of noise in the sound. Still hearing voices/alarm but with a lot of noise together.
I'm using separate 3s battery to vtx (lawmate), camera (pixim seawolf), and mic (electret). Ground between (camera, bat, mic) connected do osd. I already tried the 10k resistor inline between audio out of osd and vtx. Same thing.
Any another suggestions?
junioro16v is offline Find More Posts by junioro16v
Old Sep 18, 2012, 09:49 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
need video
Originally Posted by junioro16v View Post
Hi guys.
I need some help.
Old Sep 19, 2012, 08:09 AM
Kloner is offline
Aerial DP
Joined Apr 2010
junior, show us where everything is on the bird too.
Old Sep 19, 2012, 08:55 AM
junioro16v's Avatar
Joined Mar 2009
Ok.
Im not in home now. When get in there, Ill take some photos.
Not in bird yet. Mading lot of tests before put in airplane.
Ferrite in all the cables. But Il take photos to show.
Old Sep 19, 2012, 08:56 AM
junioro16v's Avatar
Joined Mar 2009
Originally Posted by m_beeson View Post
need video
Will do that too.
Old Sep 19, 2012, 11:21 AM
eroeder is offline
Find More Posts by eroeder
eroeder's Avatar
United States, TX, Frisco
Joined Jan 2004
For me, I had to reduce the 'white balance" in the OSD screen sub menu. No clue why it worked, but that's what I was told to do and it worked.
eroeder is offline Find More Posts by eroeder
Old Sep 19, 2012, 02:52 PM
junioro16v's Avatar
Joined Mar 2009
Hmmm. Good point.
Its one suggestion! I will try for sure!
And let you guys know about it!
Any other suggestion will be great.
Like I said, Im testing all the things before put it in the air.
Old Sep 19, 2012, 06:04 PM
Kloner is offline
Aerial DP
Joined Apr 2010
things touching things makes interference so spreading it all out and taping it to the plane might be all you need to make it go away. get it doing it and move stuff on the table if nothing else, see if theres a change
put the logger with the esc and keep that away from everything. if you have a bec, keep it near there too. then move away from there in one direction with your osd, camera, then vtx, put the rc control stuff on the other side. it can be front and rear, side to side, whatever, just not piled up together
left is rc rx, right side is vtx, middle is all the loud stuff and spread apart
Old Sep 19, 2012, 06:11 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
That was in the forefront of my mind. I made a mental note when you posted that...
Old Sep 19, 2012, 06:12 PM
m_beeson is offline
FPV junkie
m_beeson's Avatar
United States, UT
Joined Jan 2011
That's a good clean build...
Old Sep 19, 2012, 06:31 PM
junioro16v's Avatar
Joined Mar 2009
Hey guys,
Thanks for the suggestions. I'll do all that.
Old Sep 19, 2012, 06:50 PM
junioro16v's Avatar
Joined Mar 2009
Here the video!
ET AUDIO NOISE (2 min 37 sec)
Still mading all the possible tests that can I imagine.
(No rx receiver, no esc, no bec). Only the basic things hooked up.
New Product OSD PRO from Eagle Tree (RTH, AHI, Waypoints, Variometer, Voice, now shipping) billpa FPV Equipment 11420 Yesterday 05:10 PM
New Product OSD from Eagle Tree with logging/Google Earth support billpa FPV Talk 552 Apr 28, 2009 12:21 PM
Discussion New Video On-Screen Display (OSD) Expander from Eagle Tree - $44.99 billpa Aerial Photography 0 Jun 08, 2008 10:30 AM
Pro Data Acquisition Systems now available from Eagle Tree billpa Product Announcements 0 Aug 02, 2005 12:56 PM
New USB data logger accessories and Holiday specials from Eagle Tree Systems billpa Product Announcements 0 Nov 08, 2003 12:51 PM
