Go Back   RC Groups > Vendors > Eagle Tree Systems
This thread is privately moderated by billpa, who may elect to delete unwanted replies.
Old Mar 14, 2009, 05:06 PM   #1
billpa's Avatar
OSD Pro From Eagle Tree
Got video?
Do you fly, drive or boat with FPV, or do aerial photography? We’re pleased to introduce the Eagle Tree OSD Pro. The OSD Pro displays all the key information about your model’s status, and has many advanced features such as voice alerts, high resolution raster graphics, a new “RADAR” synthetic map, “Return to Home,” and manual waypoints.
How it Works
The OSD Pro connects between your model’s camera and video transmitter. It overlays critical data onto the video image, and sends voice alerts through the audio channel of your video transmitter. The information displayed can be as simple or advanced as you like, depending on what Eagle Tree sensors are connected to the OSD Pro system.
What Data Parameters can be Displayed on the OSD Pro?
All parameters available with our eLogger V3 and Data Recorders + optional sensors will be supported for display on the OSD Pro. Here are some examples:
• GPS Parameters (Distance to Home, Home Arrow, GPS Altitude, Ground Speed,Course, and more)
• Electrical Parameters (Pack Volts, Amperage, RX Volts, Servo Current, Milliamp-Hours, Watts)
• Performance Parameters (Airspeed, Barometric Altitude, Climbrate, Variometer, Temperatures, RPM, G-Force, EGT, Jet ECU Status, servo positions)
• Receiver Health (Dropped Frames, Antenna Fades, Missed Packets – requires Spektrum or JR FlightLog compatible Receiver)
• Call Sign, and many more
Tell me About the Advanced Features of the OSD Pro!
The OSD PRO advanced features include "RADAR," Voice Alerts, Return to Home, failsafe, and Waypoints within visual range.
RADAR
The plane icon labeled “RADAR” serves two purposes: the direction the icon is pointing indicates your present course. And, the location of the icon on the screen provides a synthetic map, similar to RADAR: the center of the screen marks the takeoff point, in a "bird's eye" view, and the plane icon moves around the screen indicating your model’s location. The maximum distance and the “up” direction is configurable.
Voice Alerts/Variometer
Imagine hearing the status of your model through earbuds connected to your video receiver! The OSD Pro fully supports voice warnings and status updates, via the audio channel of your video transmitter. Most of the available parameters can be programmed to provide voice alerts.
For example, you can program the OSD Pro to periodically update you on altitude once a minute: “Altitude 3-9-1 Feet”. And, you can also program a low voltage warning “WARNING- Voltage 12-point-5 Volts”. Voice alerts can be combined with your camera’s microphone, so you do not lose motor or other flight sounds when there are no alerts.
Additionally, a varying tone Variometer with Total Energy Compensation (completely configurable from the on-screen menus) is included. Any of our altimeters, or GPS altitude, will work with the variometer. But, the altimeters built into our Glide and Pro recorders have very high resolution, which is required for the variometer to be useful in finding thermals. You'd use the recorder instead of our eLogger as the 'data collector' if you need thermal sniffing capability. The OSD-Pro will work with either one.
Return to Home and Failsafe
The Return To Home feature will attempt to bring your stable plane in a “holding pattern” above the takeoff point if radio signal is lost, by manipulating your model’s rudder/ailerons, elevator, and throttle, based on your settings. GPS and other sensor information is used to attempt to return the plane to home.
Note that this feature requires configuration of several parameters via our on-screen menus. An on-screen Return to Home configuration wizard is built in to simplify this process. The feature may require “trial and error” testing, and may not work with all planes or under windy conditions. If you have a stabilization system, this process is greatly simplified. We plan on releasing additional sensors that will further simplify this feature.
A Failsafe feature is also included, if Return to Home is not desired, or you are not using GPS. The failsafe feature sets your aileron/rudder, throttle, and elevator to programmable positions, if radio signal is lost. This is most useful for radios without built-in failsafe.
The Return to Home and Failsafe features work with all known radio types.
Flight Simulator
A built-in flight simulator is included, letting you fly the RADAR icon around the screen, controlling altitude, throttle and turns with your RC Radio. Since the control surfaces of your model will move at the same time, this feature makes it easier to configure Return to Home and test your alarms and settings, and is also fun on rainy days!
Waypoints
Up to 3 waypoints (within visual range of the takeoff point) can be programmed into the OSD Pro, for aerial photography or just for fun. The locations of the waypoints are displayed on the RADAR display, making it easy for you to manually fly to the waypoints (the system will not autonomously fly to the waypoints).
How Do I Configure and Control the OSD Pro?
The OSD Pro's built in on-screen menus and Eagle Tree’s drag and drop configuration software makes it easy to configure the OSD Pro to display what you want to see, when and where you want to see it. As few or as many parameters as you need can be displayed.
Our software lets you configure the OSD with up to 20 data parameters per screen. Also, the same parameter can be displayed on multiple screens.
The OSD Pro's on-screen menus let you set up the Return to Home feature, set audio volume, configure GPS settings, turn on and off the graphical features, and much more, without needing a computer at the field.
Two servo channels (one of which must be dedicated full time to the OSD Pro) let you switch between on-screen menus to further configue the OSD, or turn off the OSD entirely.
How Do I Hook it Up?
The OSD Pro Expander has the following connections:
• Connection to the eLogger or Data Recorder
• Servo-style connections to your camera’s “video out” port and your video transmitter’s “video-in” port
• Servo-style connections to your audio microphone (if you have one) and to your video transmitter's audio in port.
• Servo connections for controlling the OSD from your radio, and for Return to Home and Failsafe features. The servo connections are Aileron/Rudder In and Out, Elevator In and Out, Throttle In and Out, Aux 1 In, and Aux 2 In. Note that the Aux 1 channel must be dedicated to the OSD Pro, but the Aux 2 channel may be shared with other functions on your model.
• Three male to male Servo extension cables are included for hooking up to your servos.
Is the Eagle Tree OSD Pro System “Future Proof”?
Yes! Eagle Tree has been in the R/C Data business for many years – it’s all we do! We won’t lose interest in your data equipment shortly after you buy our product, and we have full time support staff to help with any issues you encounter.
Also, our systems are fully modular. If we come out with a new sensor, a more powerful OSD Expander, a software improvement, etc., it’s easy and cost effective to update the system. So, your system is not obsolete a few months after your buy it.
And of course, the OSD Expander’s firmware is updatable from the internet, making it easy for you get support for new sensors, access to new features, and download the inevitable bug fixes.
But I also need Data Logging!
Complete data logging of most parameters is included. The data are downloaded via the included USB connection, and graphed and analyzed with our powerful Windows software.
I Need more Information about the OSD Pro!
Please visit our website at http://www.eagletreesystems.com or email us at info@eagletreesystems.com if we can answer any questions about the OSD Pro!
billpa is offline Find More Posts by billpa   Reply With Quote
Old Mar 14, 2009, 07:16 PM   #2
when will a laser tag combat system be ready?
JustinONE is offline Find More Posts by JustinONE   Reply With Quote
Old Aug 14, 2009, 09:06 AM   #3
gromitvt10's Avatar
Do you guys plan on adding an Artificial horizon to the display? Kind of like the RVOSD V3 (F-16) has? Just curious.
Kyle
gromitvt10 is offline Find More Posts by gromitvt10   Reply With Quote
Old Aug 15, 2009, 05:02 AM   #4
Hi Kyle,
The OSD Pro has and supports Artificial horizon. We are waiting for the expander board to support the FMA co-pilot unit and then it will be fully integrated.
cvandenb is offline Find More Posts by cvandenb   Reply With Quote
Old Aug 18, 2009, 02:42 PM   #5
gromitvt10's Avatar
I was just about to buy the Eagle Tree OSD and saw the EZOSD with Live Google Earth, and Antenna tracking. Looks very interesting, is the Eagle tree OSD going to eventually have an upgrade for Live google earth and antenna tracking?
Kyle
Old Aug 18, 2009, 02:49 PM   #6
billpa's Avatar
It sure is!
http://www.rcgroups.com/forums/showt...ight=eagleeyes
Regards,
Bill, for Eagle Tree
Old Aug 18, 2009, 04:15 PM   #7
gromitvt10's Avatar
Bill, Awesome...Looks like i'm back on track to buy an Eagle Tree system!!! Email sent.
Kyle
Old Aug 18, 2009, 09:33 PM   #8
FPVpilot.com
Crash9's Avatar
OSD Pro over the Grand Canyon
I have been playing around with my new OSD pro. This thing is a lot easier to use then I thought it would be. I finally got to fly with it...and in all places it was the Grand Canyons East rim . I installed it in my Easystar with 2 3s2200mah lipos and it flew for over 45 minutes . So long that I ran out of recording space. Sure was nice to use the Pro in a strange flying location....love all the needed info I was getting during the flight. Next I just need the AH and the ability for Spektrum logging when using GPS .
Here's the Grand Canyon Video...Enjoy.
http://vimeo.com/6169191
Crash9 is offline Find More Posts by Crash9   Reply With Quote
Old Aug 20, 2009, 06:54 PM   #9
billpa's Avatar
Wow, great flight!! Can I post that on our home page for a while??
Regards,
Old Aug 21, 2009, 02:17 PM   #10
FPVpilot.com
Crash9's Avatar
Regards,
Sure you can . Put it anywhere you like.
Old Oct 17, 2009, 07:47 AM   #11
EFlight Specialist
Send a message via AIM to Perflight
OSD FMA Co-Pilot for Pro Datalogger
I just got an OSD Pro and I have the FMA Co-Pilot sensor but it is only suports the data logger not the recorder, do you have an upgrade for this?
Perflight is offline Find More Posts by Perflight   Reply With Quote
Old Oct 21, 2009, 12:17 AM   #12
billpa's Avatar
HI Perflight,
We will be releasing an expander board this year, that supports connecting the FMA sensors to the recorder. This will also support stabilization without needing the FMA computer.
Regards,
Old Oct 21, 2009, 12:55 AM   #13
I think my wheels fell off.
Thumb_number's Avatar
hey Bill,
Out of interest, will aboved mentioned expander enable us to use the FMA sensors in the 'X' configuration? (free of the co-pilot computer)
Cheers
Thumb_number is offline Find More Posts by Thumb_number   Reply With Quote
Old Oct 22, 2009, 05:01 AM   #14
New user EagleTree osd
Dear sirs,
i'm new to these stuff and i'm reading quite a lot and would like to post the following question and hopefully the answer would help me in my project.
Q: i have bought the eagletree osd pro and the e logger v3 and will be installing them with a copilot and all the rest of the equipents cameras and stuff, my question is how can i get real time data fromthe gps and send them directly to me so that can use them with google earth. that is i want to see my plane track on google earth in real time.
who have done this and what extra equipment will i need to perform this task.
thank you.
mounirzoorob is offline Find More Posts by mounirzoorob   Reply With Quote
New Product OSD PRO from Eagle Tree (RTH, AHI, Waypoints, Variometer, Voice, now shipping) billpa Video Piloting (FPV/RPV) 2705 Today 07:14 PM
New Product OSD from Eagle Tree with logging/Google Earth support billpa Video Piloting (FPV/RPV) 552 Apr 28, 2009 01:21 PM
Discussion New Video On-Screen Display (OSD) Expander from Eagle Tree - $44.99 billpa Aerial Photography 0 Jun 08, 2008 11:30 AM
Pro Data Acquisition Systems now available from Eagle Tree billpa Product Announcements 0 Aug 02, 2005 01:56 PM
New USB data logger accessories and Holiday specials from Eagle Tree Systems billpa Product Announcements 0 Nov 08, 2003 01:51 PM
Bored? Want to fight?
Join the RCGroups clan!
