Old Mar 14, 2009, 04:14 AM
Harrow is offline
Find More Posts by Harrow
Yes, I know it's upside down.
Sydney, Australia
Joined Dec 2008
What is the minimum C rating of this odd battery?
I bought a ST Model RC 3S2P 2200mAh battery from a bargain bin the other day. Not until I got home did I realise that it did not have a 'C' rating. I plan to run it in a foam profile jet that only pulls 12A static, and I have never seen LiPo's under 6C, so I figure it is probably okay.
As long as I check the temperature every now and again on the first flight, and it does not get too warm, is there any other reason that it would not be okay?
Strangely, it weighs only 144g, which is rather light in comparison to my Loong Power 3S1P 2200maAh 25C that weighs 180g. It also came with 18 gauge leads, compared to the 12 gauge leads on my other brand. Although it is much shorter, it is also a little thicker than the other battery in the photo.
What is the minimum that it is likely to be??
Harrow.
Harrow is offline Find More Posts by Harrow
Old Mar 14, 2009, 07:27 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Google ST modelRC
hoppy is offline Find More Posts by hoppy
Old Mar 14, 2009, 09:29 AM
davecee is online now
Find More Posts by davecee
I'd rather be Flying
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
Personally I wouldn't be afraid of using 10C as a max rate with perhaps 12C as a burst rate. That's in line with some of the older, lighter weight packs I've had in the past.
If you can do a voltage check under load I'd use, as a maximum, an amp draw that would not drop the voltage below 3.5 volts per cell. That's a personal recommendation only. I tend to treat most of my batteries pretty gently.
Dave
davecee is online now Find More Posts by davecee
Old Mar 14, 2009, 09:50 PM
Harrow is offline
Sydney, Australia
Joined Dec 2008
Originally Posted by hoppy
Google ST modelRC
Hoppy, Could you please post the link to the site you found that I was unable to.
Harrow.
Old Mar 14, 2009, 10:26 PM
Elminister is offline
Find More Posts by Elminister
He who is Elminister
Syracuse, NY
Joined Mar 2008
www.google.com and type in ST model RC and hit search button.
Elminister is offline Find More Posts by Elminister
Old Mar 15, 2009, 04:19 AM
Harrow is offline
Sydney, Australia
Joined Dec 2008
Elminister, you are a very funny man. Now that Seinfeld has finished, I am sure you are just what they have been looking for to fill the gap. Give them a call.
Old Mar 15, 2009, 07:37 AM
Syracuse, NY
Joined Mar 2008
http://www.stmodel.com/
One of us is funny for sure but it isn't for the right reason and it isn't me..............
Your welcome.......... :/
You may need to install a chinese language pack of some sort for cite to display properly.
Old Mar 15, 2009, 07:59 AM
Murocflyer is offline
Find More Posts by Murocflyer
Promoting Model Aviation...
Murocflyer's Avatar
United States, CA, Tehachapi
Joined Nov 2005
I find this helpful also.
http://letmegooglethatforyou.com/?q=...search+feature
Frank
Murocflyer is offline Find More Posts by Murocflyer
Old Mar 15, 2009, 09:58 AM
davecee's Avatar
Nashville, NC, USA
Joined Mar 1999
I agree that the suggestions to search are not useful. I believe you mentioned that you did try to search for information. I've also searched and can not find any information on that "specific" battery pack (it's probably an older pack) on the stmodel site or any other. You don't see many packs of that capacity with that shape and weight. I've seen a couple.
However you don't need any specifications to use it safely. If you're balancng the pack and not over discharging it, and if it's not getting hot and if the voltage remains above 3.5 volts per cell under your max load, then it's OK.
Dave
Old Mar 15, 2009, 08:40 PM
paulo810 is offline
Find More Posts by paulo810
"On the Wing"
paulo810's Avatar
Ohio
Joined Jul 2006
Their website is clearly printed right on the battery pack. The site prints in both chinese and english on every page. No need to google anything.
www.stmodel.com
Hope this helps.
The only 3s2p I found there says 2900mah not 2200, could be a misprint. 20C.
paulo810 is offline Find More Posts by paulo810
Old Mar 15, 2009, 09:34 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Only references to the pack are 4 years old. That would place it in the <10C range IMO.
Old Mar 16, 2009, 12:52 AM
Harrow is offline
Sydney, Australia
Joined Dec 2008
Thanks all. I did look on their web-site first of all, and most importantly can see that they did once upon a time produce a 6C series of batteries, so this appears to be the potential worst it could be, and the weight and lead size suggest this could be true. I just made a profile jet that draws 12A peak, so it looks like this will be the batteries new steed.
Old Mar 16, 2009, 08:20 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Short flights and temperature checks are your tools to see how hard you can push the pack. Fly, check temp, fly check temp, etc. It will get the most temp rise near the end of the batteries capacity.
What rating is this Li-ion? MUDBOGGER2 Batteries and Chargers 2 Oct 30, 2003 06:07 PM
What rating Li-ion battery? newminimark Parkflyers 2 Sep 15, 2003 02:48 PM
What do you guys think about this battery combo? dmelton Parkflyers 2 Aug 21, 2003 09:00 AM
What would be a good charger for this battery pack? TurboRacer Batteries and Chargers 3 Oct 21, 2002 05:53 PM
What's going on with this battery? die fleidermaus Beginner Training Area (Aircraft-Electric) 3 Jun 30, 2002 12:36 AM
