This thread is privately moderated by juzwuz, who may elect to delete unwanted replies.
Old Dec 16, 2011, 04:43 PM
teknos is offline
Find More Posts by teknos
Trader Rating: 0
España, Comunidad de Madrid, Madrid
Joined Feb 2006
Trader Rating: 0
Thanks Justin!!
Templates at home, perfect!!
Thanks!
Antonio
teknos is offline Find More Posts by teknos
Old Mar 10, 2012, 02:07 AM
HannesJ is offline
Find More Posts by HannesJ
Trader Rating: 0
HannesJ's Avatar
Centurion, South Africa
Joined Mar 2004
Trader Rating: 0
Hello Justin,
Did you get my second PM sent on the 7th regarding the templates?
Regards
Hannes
HannesJ is offline Find More Posts by HannesJ
Old Mar 16, 2012, 04:45 PM
kpeevyhouse is offline
Find More Posts by kpeevyhouse
Trader Rating: 33
Sane til the lift starts!
kpeevyhouse's Avatar
Laguna Beach, CA
Joined Jun 2008
Trader Rating: 33
I just received a set of templates from Justin. He was able to make them customized to my specifications without any problems. The phenolic material is awesome! I can't wait to start spitting out foam cores with these babies!
-Keith
kpeevyhouse is offline Find More Posts by kpeevyhouse
Old Mar 16, 2012, 04:49 PM
A10FLYR is offline
Find More Posts by A10FLYR
Trader Rating: 7
Dean
A10FLYR's Avatar
USA, CO, Littleton
Joined Apr 2005
Trader Rating: 7
Keith, do you like phenolic better than formica? If so, why?
Thanks.....
A10FLYR is offline Find More Posts by A10FLYR
Old Mar 22, 2012, 10:55 AM
baffett is offline
Find More Posts by baffett
Trader Rating: 0
SF Bay Area
Joined Apr 2002
Trader Rating: 0
wanted Edge 2 templates
phenolic, leading edge ramp. wing and tails
Edge 2 Panel (3 templates) $22 + Edge Tails $13
I know above is formica pricing, let me know the phenolic pricing.
-Tom
baffett is offline Find More Posts by baffett
Old Mar 22, 2012, 03:56 PM
juzwuz is offline
Find More Posts by juzwuz
Trader Rating: 66
Seattle/Everett, WA
Trader Rating: 66
-Tom
Tom,
Phenolic pricing would be $10 more. It actually takes double the time to cut because it's just thick enough that my router bit does not like to cut it in one pass.
Justin
juzwuz is offline Find More Posts by juzwuz
Old Apr 01, 2012, 08:10 PM
baffett is offline
Trader Rating: 0
SF Bay Area
Joined Apr 2002
Trader Rating: 0
Edge and v4d vertical
Juzwuz,
OK. thanks for the heads up on formica vs. phenolic. I'll go with the formica. Can I get:
Edge 2Panel wing and Edge tail templates. Set the chord height to 7/8", I'm building some template holders and need a bit of room on the bottom for clamping them into the holder.
As to materials I've never used formica have always used that phenolic material but will go with what you think is best.
In addition to the above can you cut templates for the vertical using (z4d.dat), do you have the .dat file? I'd use the same planform as the Edge so same chord length as the Edge vertical templates.
Old Apr 01, 2012, 08:26 PM
target is offline
Find More Posts by target
Trader Rating: 80
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Trader Rating: 80
Justin-
Can you duplicate profiles from a molded tail and make me a set of templates to allow me to make a similar bagged tail, WITHOUT destroying the sample tails??
I want to make a tail with slightly longer span, and lighter than the stockers (I hope).
R,
Target
target is offline Find More Posts by target
Old May 07, 2012, 07:22 PM
nick_cool is offline
Find More Posts by nick_cool
Trader Rating: 1
y chucu, chucu, chuuuu...
nick_cool's Avatar
Argentina, Buenos Aires
Joined Apr 2003
Trader Rating: 1
Hello Justin, I would like to buy formica ribs for the SuperGee2.
Supergee2 + Supergee2 Tails
Can you tell me the cost plus H&S to Buenos Aires, Argentina?
Can I pay with Paypal?
Regards
Nick
nick_cool is offline Find More Posts by nick_cool
Old May 07, 2012, 08:34 PM
target is offline
Trader Rating: 80
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Trader Rating: 80
Originally Posted by target View Post
Justin-
R,
Target
Whats the chance of answering this??
R,
Target
Old May 08, 2012, 11:16 PM
juzwuz is offline
Trader Rating: 66
Seattle/Everett, WA
Trader Rating: 66
R,
Target
Target,
Sorry for the late reply. Didn't even see your post. I don't have a good way to duplicate an existing tail but it would be possible if someone had the proper equipment to take point cloud measurements. The easiest way would be to specify the airfoil and chord lengths and just make the airfoil templates.
Justin
juzwuz is offline
Trader Rating: 66
Seattle/Everett, WA
Trader Rating: 66
Regards
Nick
I'll send you a PM.
Old May 09, 2012, 11:16 AM
target is offline
Trader Rating: 80
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Trader Rating: 80
Originally Posted by juzwuz View Post
Target,
Justin
I have since posting damaged a tail panel. It may be repairable, but also may just get sacrificed for the cause instead.
I might try to fill it with a epoxy/ microballoon slurry befor cutting it up and sending it to you for template production.
That would work, right?
The coordinates are not published.
R,
Target
Old May 09, 2012, 02:09 PM
juzwuz is offline
Trader Rating: 66
Seattle/Everett, WA
Trader Rating: 66
R,
Target
Target,
If you can cut your tail in half at the root and put the end on a flat bed scanner, then e-mail the picture to me, I can probably convert that picture into an airfoil suitable for templates. I'll send you my e-mail through a PM.
Justin
Old May 09, 2012, 04:01 PM
target is offline
Trader Rating: 80
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Trader Rating: 80
Thanks, Justin.
Sounds like a plan.
R,
Target
New Product New! Kalteisen SU-26 Foamy with CNC cut airfoil wing! Quicker 3D Flying 205 Sep 04, 2009 01:51 AM
Discussion Kalteisen Katana Foamy with CNC cut airfoil wing. Quicker 3D Flying 27 May 20, 2009 07:54 AM
Sold CNC cut AG11 4.75 inch formica template juzwuz Aircraft - Sailplanes (FS/W) 10 Mar 14, 2009 02:44 AM
CNC cut shaft for ECO8 bertvk Electric Heli Talk 5 Oct 21, 2002 01:19 PM
Pretty-CNC cut kit, anybody interested??? modest-master Parkflyers 15 Oct 18, 2002 07:12 AM
