Old Mar 14, 2009, 10:34 AM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
HEAT>>>HEAT rejection ???
Plastic pipe is death to the motor. If I visualize the tube in a tube description correctly.
I did industrial upgrades for a living. How are you going to move enough air thru & around the motor in a fixed in position use ? Airplane motors are rated at typical flying speeds.......Some flying speed with good air movement.
cyclops2 is offline Find More Posts by cyclops2
Old Mar 14, 2009, 11:55 AM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
Originally Posted by Bruce Abbott
They do (in a poorly designed motor that doesn't have enough back-iron).
http://www.rcgroups.com/forums/showthread.php?t=953949
That is astounding. Never gave it a thought. Glad I use PU impregnated paper tubes now.
rich smith is offline Find More Posts by rich smith
Old Mar 14, 2009, 01:11 PM
landru is offline
Find More Posts by landru
landru's Avatar
Vancouver, Canada
Joined Mar 2003
On similar lines, using plastic instead of aluminum for the stator carrier (bearing tube) can noticeably improve the performance of an outrunner motor in some some cases.
landru is offline Find More Posts by landru
Old Mar 14, 2009, 01:26 PM
leybold12 is offline
Find More Posts by leybold12
USA, AZ, Tucson
Joined Aug 2008
I am using helicopter versions of the motor with built in centrifugal blower. At 8000 rpm the motor sucks quit a breeze through the windings. The motor itself was running quite cool, just the copper pipe was heating up very quickly. The original motor had a centrifugal blower attached to cool the same way.
The epoxy laminate fiberglass I ordered is rated to 510 F. The epoxy I will use is rated to the same temperature.
leybold12 is offline Find More Posts by leybold12
Old Mar 14, 2009, 01:31 PM
rich smith's Avatar
Joined Dec 2006
I noticed the aluminum stator tube seems to get hotter than the windings. I wonder if CF tube like the Westport kits would improve things.
Old Mar 14, 2009, 01:46 PM
cyclops2 is offline
Joined Mar 2003
You realize that the motor has almost NO metal holding all of the magnetic field in side of the motor ? I would just take the easy way out with non-metallic........ METAL. .....Should now be a known shortcoming of outrunners ??
Old Mar 16, 2009, 09:12 AM
USA, AZ, Tucson
Joined Aug 2008
I guess the question is whether the lack of iron in the rotor of the outrunner will cause a loss of efficiency at higher currents (higher magnetic fields) or a saturation point of the iron rotor where the motor will draw more current but not provide more torque.
Old Mar 16, 2009, 09:37 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
More than anything, the thin rotor iron will result in lower peak power output before the motor runs into saturation. Then it will draw excessive amperage with little or no power gain as you described. Efficiency usually isn't affected that much. Maybe 1-2% at most.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Mar 16, 2009, 10:08 AM
USA, AZ, Tucson
Joined Aug 2008
I guess I have to beef up the dyno so I can draw more than 30 amps off the motor to see the saturation point.
How to measure no load current of a brushless motor? Hovertime Power Systems 21 May 23, 2004 08:28 PM
5amps,6cells no load current draw too much? Foxy Power Systems 0 Feb 17, 2003 09:27 PM
1010 2Y DF no load current mumblety-peg Power Systems 0 Jun 25, 2002 09:05 PM
High no-load current on Astro 15G? Paul Power Systems 0 Apr 27, 2002 07:12 AM
"no-load current" -- what does it mean? joey221 Power Systems 3 Mar 29, 2002 03:49 PM
