This is one thing that I did and I'm not saying it has to be done, it's just my opinion. I took the nuts, bolts etc and threw them out. In the Chinese made kits I've found that the quality of the nuts, bolts etc. to be very hit and miss. Some are good while others I've had bolt heads snap off if you look at them sideways. I figure the cost to replace these accessories isn't that much especially when you consider what the cost would be should a critical one fail in flight.
Joined Feb 2012
I run Hitec HS 645MG servos on my plane. They are rated at 106 oz of torque @ 4.8 volts and 133 oz. of torque @ 6 volt. I think you could do just fine with the Hitec HS 485HB (or something similar), they are rated at 66.6 oz. torque @ 4.8volts and 83.3 oz. torque @ 6 volts. I would highly recommend using a metal gear servo in the rudder as it's taking a lot of abuse with the water rudder. |
Canada, AB, Sherwood Park
Joined Jan 2011
5s vs 6s
Flying By why did you go with 5s??? Just curious? I had to put my build on hold due to other projects and now im back at it and ill be ordering motors today and im going with 60 size, 50mm dia, in the range of 500-700kv. Whats the main benefit of KV at this point if anything? I plan on using 11x6x3 or 12x6x3 props for a mix of scale size and effeciency. |
Joined Feb 2012
I could have gone with a lower KV motor and 6S but I didn't find a motor that was in the price range and KV range that I wanted. Additionally, I have an EDF that I can use the 5S batteries in...and it wouldn't take 6S. |
| Thread Tools | |
| Build Log Depron Canadair CL-415 by Nibbio | meatbomber | Waterplanes | 7 | Jan 12, 2013 04:08 PM |
| Canadair CL-415 Progress | Slope Nut | Scale Electric Planes | 83 | Jan 31, 2009 01:06 AM |
| Beldone/RT Models Canadair CL-415 Construction | Rudderman98 | Scale Electric Planes | 71 | Dec 10, 2003 02:20 AM |
| Anyone built the Beldone Models Canadair CL-415? | Rudderman98 | Scale Electric Planes | 21 | Nov 30, 2003 03:27 AM |
| Canadair CL-415 inflight photos | Slope Nut | Scale Electric Planes | 5 | Jan 27, 2003 10:50 AM |
