Old Feb 11, 2012, 07:34 PM
KDube is offline
Find More Posts by KDube
Joined Oct 2011
Mainjet, there is a site on one of the discussion group (somewhere) that a guy had made one of these devices...I was interested because where we float fly it is difficult to launch and retrieve planes without stepping in about two feet of muck...His device let you place your airplane on the "craddle" and advance the throttle so the plane heads out into the pond, upon returning the plane is IDLED into the "cradle" and then you would advance the throttle slowly, the planes then rolls up the "tubes" there you have it...No mess. NO MUCK...Thanks...Kevin in Denver and it is cold here today...
KDube is offline Find More Posts by KDube
Old Feb 11, 2012, 11:25 PM
mainjet is offline
Find More Posts by mainjet
mainjet's Avatar
springfield, missouri
Kevin
ok I see. Let me know if you find the link I would like to check it out.
mainjet is offline Find More Posts by mainjet
Old Feb 26, 2012, 06:12 AM
flightrisk is offline
Find More Posts by flightrisk
United States, KS, Leawood
Joined Feb 2012
Hello,
I am new to the hobby but fell in love with this plane. I received the ARF kit this week and now need to get everything else but the remote (DX8) and the batteries (6S 5000mAh). Could one of you who is satisfied with the setup recommend a list of what to get for receiver, ESC, BEC, motor, propellers, servos, servo extensions, etc.?
Your help will be very much appreciated.
flightrisk is offline Find More Posts by flightrisk
Old Feb 26, 2012, 06:47 PM
lupy is offline
Find More Posts by lupy
Fuzzy Member
lupy's Avatar
Renton WA
Joined Oct 2001
How much stick time do you have? I don't mean to be critical, but I wouldn't dream of flying one of these as a first or even second plane.
Edit: looks like you shouldn't have a problem. didn't want to clutter thread with an extra post. Have fun, try to keep it light.
lupy is offline Find More Posts by lupy
Old Feb 27, 2012, 05:06 AM
Joined Feb 2012
Hy Lupi,
I actually flew gliders as a kid, and since I got back to it, I have been flying both airplanes and helicopters without too much damage:
- Airplanes: Alpha 450 3D, Icon A5, Stryker F27Q, Radian Pro
- Helicopters: Blade mQX, Blade mCP X, Blade 450 3D
I am not keeping count but maybe a total of 10 hours fixed wing and 40 hours helicopters in the last couple of months.
The part I need the most help with and that is new to me is putting together an ARF and selecting all the right parts. I just want to do everything I can to not mess up this beauty.
Thank you for your help.
Old Feb 28, 2012, 01:40 AM
mainjet is offline
mainjet's Avatar
flightrisk
It depends on what you are going for, high performance ? scale ? economy ? high end components ? are you going to fly off off water or land ? what level builder are you ? what components do you already have that you may be able to use ? all these things I consider before starting a build. Also I read thru as much info as I can find on similar builds of others who have had good results. My opinion is take your time and dont hesitate to ask questions if you are not certain about something.
mainjet
Old Feb 29, 2012, 01:04 PM
JGuilty13 is online now
Find More Posts by JGuilty13
JGuilty13's Avatar
United States, MI, Rochester Hills
Joined Nov 2005
Flightrisk, you're planning on using a 6s 5000 pack for this model?!
JGuilty13 is online now Find More Posts by JGuilty13
Old Mar 01, 2012, 04:34 AM
Joined Feb 2012
Hello all,
Yes i am planning 2 parallel 6S 5000mAh batteries for motors and 1 2S for receiver servos. Based on my reading of this thread, others have done that as well with success.
To answer the other questions:
- water only
- decent performance but realistic scale flight
- good value for money components (reliability will be important)
At this point I am thinking Castle for ESC and BEC, Turnigy for motors, couter-rotating 3 blade props, motor based rudder (no water rudder). Still need to figure out receiver (will most likely be Spektrum, but how many channels do I need? 8? 9?) and servos (quantity, size, specs).
Old Mar 01, 2012, 10:27 AM
Herman Munster is offline
Find More Posts by Herman Munster
Herman Munster's Avatar
United States, Mt, Libby
Joined Nov 2007
Originally Posted by flightrisk View Post
Hello all,
- water only
I'm using a 6 channel receiver on mine, the AR6210. I have Hitec 485 servos on everything but the elevator. I'm running Hitec 645MG on the elevator.
There's really no need to run counter rotating props, the full size doesn't have them.
Herman Munster is offline Find More Posts by Herman Munster
Old Mar 16, 2012, 10:14 PM
KDube is offline
Joined Oct 2011
Hey there all, does anyone have concerns about this plane becoming a swamped canoe and sinking...What about putting in some foam to at least help...Any thoughts..Also, concerning the canopy, how would one go about making this an EASIER acess point....Kevin in Denver
Old May 14, 2012, 02:02 PM
TripleW is offline
Find More Posts by TripleW
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
My friend maidened his today! Just some elevator trim was needed.
Power 46's with 13x6.5 props on 5s.
The phone wasn't up to the in flight pics. I'll see if I can get some later.
TripleW is offline Find More Posts by TripleW
Old May 15, 2012, 06:33 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
More Pics.
Old May 17, 2012, 04:25 PM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
The pics you did get are impressive. Very nice airplane!
You've got the the wingtips switched left to right.
Grejen is offline Find More Posts by Grejen
Old May 18, 2012, 02:58 AM
GIJon is offline
Find More Posts by GIJon
Joined Sep 2003
Second Maiden Attempt
I attempted my second maiden yesterday. It was a complete success and it flies great with the O.S. 70fs engines not to mention the sound. We were all impressed with how steady it flies and when using flaps with a little down elevator, it does not change attitude a bit.
GIJon is offline Find More Posts by GIJon
Old May 22, 2012, 07:39 PM
TripleW is offline
TripleW's Avatar
Prescott, Arizona
Joined Feb 2010
Thanks, I'll let him know.
Build Log Depron Canadair CL-415 by Nibbio meatbomber Waterplanes 7 Jan 12, 2013 04:08 PM
Discussion Canadair CL-415 Progress Slope Nut Scale Kit/Scratch Built 83 Jan 31, 2009 01:06 AM
Beldone/RT Models Canadair CL-415 Construction Rudderman98 Scale Kit/Scratch Built 71 Dec 10, 2003 02:20 AM
Anyone built the Beldone Models Canadair CL-415? Rudderman98 Scale Kit/Scratch Built 21 Nov 30, 2003 03:27 AM
Canadair CL-415 inflight photos Slope Nut Scale Kit/Scratch Built 5 Jan 27, 2003 10:50 AM
