Old Apr 29, 2009, 05:42 PM
High & Mighty is offline
Find More Posts by High & Mighty
High & Mighty's Avatar
NW Ohio
Joined Mar 2009
I am a diehard glow engine user but I would like some suggestions on prop size for 3-blade props. I will be using twin O.S. 55 AX's and have several choices from Master Airscrew for 3-blade props. Looked at some earlier posts in this forum and noticed a picture with a tape measure showing adequate prop clearance from CL of engine to fuselage side but I would be more concerned with the prop clearance to the waterline especially when flying in choppy waters and spray from fuselage chines.
My prop choices are as follows:
11 x 7
11 x 8
12 x 6
12 x 8
I think the 11 x 7 and the 12 x 6 are my two best choices since I think the 8" pitch is too heavy for flying off water and I do not need the heavy 8" pitch for flying. I also think the 11 x 7 or 12 x 6 would be my first choice since it would give me more prop clearance and less load on engines for takeoffs.
I would appreciate your comments.
High & Mighty is offline Find More Posts by High & Mighty
Old May 03, 2009, 06:55 PM
marnochs is offline
Find More Posts by marnochs
marnochs's Avatar
Canyon Country, California
Joined Dec 2006
Doesn't really mater if it's a 12 or 11, water coming off the nose gets sucked into the propellers as indicated in the pictures below. Besides an 11 in. properller is only 1/2" smaller in diameter and the plastic stands up to the water very well.
to minimize the water spray, I increase power very gradually for a slow acceleration. If you go the full power right off the mark, its going to sound like it's sucking in a gallon of water.
marnochs is offline Find More Posts by marnochs
Old May 04, 2009, 05:58 AM
jpgilbert is offline
Find More Posts by jpgilbert
MaineFlyer
jpgilbert's Avatar
Augusta, Me
Joined Feb 2005
I posted a video of the maiden flight of a buddy's CL-415 glow powered model. Presently flying without the motor cowls until he is happy with both engines. So far, he had run 4 tanks thru each and still has them running a bit rich. They are SuperTiger 40s. He is pleased at this time.
Joe
http://www.modelaviators.org/2009/Videos/2009Videos.htm
(Scroll down to the "Float" section and select Bob's CL-415)
jpgilbert is offline Find More Posts by jpgilbert
Old May 30, 2009, 02:20 PM
Fast Freddy is offline
Find More Posts by Fast Freddy
Madison, WI
Joined Feb 2004
Nitroplane Cl-415
Hey ScaleBrad, You there man? Has your CL-415 flown? Just wondering about an update and if everything is going well.
Later,
FF
Fast Freddy is offline Find More Posts by Fast Freddy
Old May 30, 2009, 02:45 PM
pappy69 is offline
Find More Posts by pappy69
Thanos Papantonopoulos
pappy69's Avatar
Edessa, Greece
Joined May 2007
Just noticed the problem that marnochs had and i think the solution is to increase by few mm the front end of the splash rails !!
That would help to avoid undesired water spray over the props!!!
The most important part that helps in exactly the same problem in real airplane is the front part of the splash rail.
The belly slides over the water and pushes the water to the front (like the real boat!!). The sides of the belly are pushing the water away.This extra sprayed water stays low because the front part of the splash rail kinda push the excess water again under the sides of the plane.
pappy69 is offline Find More Posts by pappy69
Old May 30, 2009, 02:58 PM
pappy69 is offline
pappy69's Avatar
Edessa, Greece
Joined May 2007
@ High & Mighty (although very late response!!!!)
The problem that you mentioned about the clearance of the prop
has to do with the size of the waves.
What i mean is that in real life this plane doesn't water land or takeoff if there are higher than 1,5m waves.
So the wave clearance you fly is scaled down as well!!!!.
Old May 31, 2009, 09:50 PM
ScaleBrad is offline
Find More Posts by ScaleBrad
115 inches of 'hog
ScaleBrad's Avatar
United States, FL, Orlando
Joined Aug 2004
Sorry guys I haven't flown mine yet. We have been house shopping every weekend and just not enough time lately. However, my new recovery raft will arrive tomorrow so that's one less excuse I have. I still have to make the final CG check, decals, and set the control throws..hopefully in a couple weeks she'll be airborne.
At the moment I am trying to finish up a big WWI plane in time for a June 17th event.
ScaleBrad is offline Find More Posts by ScaleBrad
Old Jul 05, 2009, 07:39 PM
Rudderman98 is offline
Find More Posts by Rudderman98
AMA 670207
Rudderman98's Avatar
United States, WA, Sumner
Joined Oct 2000
If anyone is interested?
SOLD
http://www.rcgroups.com/forums/showthread.php?t=1075279
Decided to keep my MR kit instead.
Perry
Rudderman98 is offline Find More Posts by Rudderman98
Old Jul 06, 2009, 01:26 AM
pappy69 is offline
pappy69's Avatar
Edessa, Greece
Joined May 2007
Rudderman98 Wise decision!!!!!!!!
Old Jul 07, 2009, 09:32 AM
ashdec87 is offline
Find More Posts by ashdec87
ashdec87's Avatar
United States, MI, Detroit
Joined Feb 2004
So I took the plunge and got Rudderman's plane.
Its gonna have monster power 46's with turnigy plush 60 amps esc's all powered by 4s 3500 packs.
Looking forward to building and flying this little puppy.
ash
ashdec87 is offline Find More Posts by ashdec87
Old Jul 07, 2009, 03:59 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
Does having counter-rotating props really help that much?? Normal props are just easier to come by.
Old Jul 08, 2009, 06:28 PM
wildcatfan42 is offline
Find More Posts by wildcatfan42
Joined Oct 2008
Is there an rc float plane about the size of this aircraft that has retracts for it that can be installedI want this model but i want to at Joe Nall 2010 be able to fly with it on the sea plane area AND the main flight line.
wildcatfan42 is offline Find More Posts by wildcatfan42
Old Jul 08, 2009, 06:37 PM
ashdec87 is offline
ashdec87's Avatar
Joined Feb 2004
https://mraerodesign.securicom.ca/en...fm?ProduitID=1
here's this one.
Old Jul 09, 2009, 08:15 AM
Joined Oct 2008
Is it an ARF because thats what im looking for ARF because i haven't built a model rather than fly them.
Old Jul 09, 2009, 08:31 AM
Madison, WI
Joined Feb 2004
Wildcat, MRaerodesign Canadair is not an ARF. It is a very involved, laser cut kit.
What you are looking for is here:
www.nitroplanes.com/cacltw0en80n.html
or here:
www.raidentech.com/cacltw0en80n.html
(same companies, different name)
Unfortunately both companies are sold out at this point. More are coming, but no one knows when they will arrive. Check the website daily as they will sell out again very quickly.
If you can't wait and simply must have it you can buy a Canadair Cl-215 for $140 more. This model is made by the same company that makes the CL-415 only different marketing. Go here:
http://www.kmp.ca/product_info.php?c...cd2b96c844d679
Good luck!
Build Log Depron Canadair CL-415 by Nibbio meatbomber Waterplanes 7 Jan 12, 2013 04:08 PM
Discussion Canadair CL-415 Progress Slope Nut Scale Kit/Scratch Built 83 Jan 31, 2009 01:06 AM
Beldone/RT Models Canadair CL-415 Construction Rudderman98 Scale Kit/Scratch Built 71 Dec 10, 2003 02:20 AM
Anyone built the Beldone Models Canadair CL-415? Rudderman98 Scale Kit/Scratch Built 21 Nov 30, 2003 03:27 AM
Canadair CL-415 inflight photos Slope Nut Scale Kit/Scratch Built 5 Jan 27, 2003 10:50 AM
