Old Jul 21, 2009, 11:17 PM
NipponDave is offline
Find More Posts by NipponDave
http://www.aircraft-world
NipponDave's Avatar
American in Japan
Joined Mar 2001
Originally Posted by ssatoru
Hi Steve,
That ESC is new Hyperion ATLAS and should be the similar as Scorpion? This has 120A 6S SBEC one temporarily which is a bit overkill. I heard it will be available soon.
Satoru
Yes, the new ATLAS are made in cooperation with Scorpion. But one needs to be careful in comparisons. The ATLAS are same as the NEW Scorpion Commander II series, which has not yet been released (or is just now). These are generationally very much improved compared to past versions, both in hardware and internal coding...
D
NipponDave is offline Find More Posts by NipponDave
Old Jul 21, 2009, 11:32 PM
QuietRCFly is offline
Find More Posts by QuietRCFly
All electric, all the time!
QuietRCFly's Avatar
USA, WA, Bellevue
Joined Aug 2005
Dave,
What's the ETA on the new Hyperion atlas ESC?
Chris
QuietRCFly is offline Find More Posts by QuietRCFly
Old Jul 22, 2009, 01:04 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
Originally Posted by QuietRCFly
Dave,
Chris
15V BEC and 26V SBEC types will be shipping to distributors this week. 50V and 68V will be some weeks behind. No certain eta yet on those.
INFO: http://media.hyperion.hk/dn/atesc/
D
Old Jul 22, 2009, 09:32 AM
QuietRCFly's Avatar
USA, WA, Bellevue
Joined Aug 2005
Thanks David! Do you have US pricing yet for the new 26v SBEC models?
Old Jul 22, 2009, 02:35 PM
Fox7 is offline
Find More Posts by Fox7
Culver City, Ca
Joined Mar 2009
ssatoru:
It is not so difficult to disassemble for transportation, only need to take care 6 wing bolts and 2 linkage rods.
Thanks for providing this info and the picture depicting this lying on the ground. I could not transport the model assymbled, and had wonder what would be involved in working with it in it's component form.
Fox7
Fox7 is offline Find More Posts by Fox7
Old Jul 23, 2009, 11:22 AM
Knotnuts is offline
Find More Posts by Knotnuts
Knotnuts's Avatar
Joined May 2008
FYI for those interested:
We now have the ZS4025 16 turn motor and a variety of the new G3 batteries in both 6S and 5S, as well as the right selection of props for this plane. Oh we have only one of the planes left an the moment, but should get more or we can have it drop-shipped if needed by the distributor.
Chris
Quiet RC Flying
www.quietrcflying.com
Chris, can you give me the dimensions on the 14 turn motor (Dia. & Length)? thanks!
Knotnuts is offline Find More Posts by Knotnuts
Old Jul 23, 2009, 11:43 AM
QuietRCFly's Avatar
USA, WA, Bellevue
Joined Aug 2005
Its gonna be the same as the 14 turn motor. Here is a link to the data sheet with dimensions for the ZS40 series motors. You would use the ZS4025 dimensions: http://media.hyperion.hk/dn/zs/ZS40-DIM.pdf
Looks like lenth, excluding x mount and shaft is 58.8mm and the diameter is 49.1mm. An length from the firewall (including x mount) to the back of the prop (where it rests against the prop adapter) is 80.1mm.
I do have one of these left.
http://www.quietrcflying.com/Product...d=HP-ZS4025-16
Chris
Old Jul 23, 2009, 12:56 PM
Knotnuts is offline
Knotnuts's Avatar
Joined May 2008
Thanks Chris, I'm still tossing around on motors for the Sampson. I really like everything about the Hyperion motor except the collet adaptor. I'm planning on 5S 5000's. Do you carry any other bolt on adaptor motors that might be suitable for this application?
Old Jul 23, 2009, 01:25 PM
QuietRCFly's Avatar
USA, WA, Bellevue
Joined Aug 2005
I don't stock any others. The Hacker A50L series motors would probably be a good fit and use a bolt on adapter, but I would have to order it and don't have prop test data to give a perfect fit recommendation with a prop, but I suspect we could find a good fit.
Old Jul 23, 2009, 01:28 PM
QuietRCFly's Avatar
USA, WA, Bellevue
Joined Aug 2005
Actually that is really better on 6S versus 5S.
Old Jul 23, 2009, 02:26 PM
maverickma is offline
Find More Posts by maverickma
maverickma's Avatar
Fogelsville, PA
Joined Mar 2004
So is a 5S 5000mah 20c battery enough to power the recommended Hyperion ZS4025 16 turn motor if I'm looking for sport aerobatic performance?
maverickma is offline Find More Posts by maverickma
Old Jul 23, 2009, 04:55 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Hi maverickma...
On 5S, you would be better off with the Zs4025-14...
SteveT
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Jul 27, 2009, 03:12 PM
Knotnuts is offline
Knotnuts's Avatar
Joined May 2008
Originally Posted by feathermerchant
I looked at the tail surfaces of mine as I packed it into the car tonite and the LE's are rounded, the TE's are square.
Feather, is that a true turn spinner on yours?
Old Jul 27, 2009, 06:47 PM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Nope. It's a Maxx products.
feathermerchant is offline Find More Posts by feathermerchant
Old Jul 28, 2009, 04:02 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
Originally Posted by Draknkep
Hi maverickma...
SteveT
Correct. With 17~18" prop depending on the battery voltage performance.
D
Discussion Hyperion's New Emeter II & RDU NipponDave Power Systems 898 May 25, 2016 03:02 PM
Discussion Blu-Baby Aerial Photography Aircraft mark II Tony65x55 Aerial Photography 6 Aug 07, 2007 11:46 AM
Hyperion CAP232 - aircraft-world.com Smifta Sport Planes 144 Dec 16, 2006 11:12 AM
Sold Samson II vett Boats (FS/W) 3 May 11, 2006 11:12 AM
Mystery Aircraft Vol II Sabrejock Scale Kit/Scratch Built 1 Apr 13, 2004 05:11 PM
