Old Sep 10, 2012, 09:29 PM
TomM is offline
Find More Posts by TomM
Rust: The poor man's Loctite.
TomM's Avatar
State College PA
Joined Jul 2002
I'll take one for a spare too.
TomM is offline Find More Posts by TomM
Old Sep 11, 2012, 01:32 AM
chopper62 is offline
Find More Posts by chopper62
Joined Apr 2008
Plane been at the lhs for a while so the owner is giving it to me for $150 plus an emergency repair of a broken helicopter for one of his customers.
chopper62 is offline Find More Posts by chopper62
Old Sep 11, 2012, 07:56 AM
ledgehunter is online now
Find More Posts by ledgehunter
USA, MI, Grand Ledge
Joined May 2006
Thanks Chopper, that's a great deal. I did see that allerc has them on clearance now too for about $175..
ledgehunter is online now Find More Posts by ledgehunter
Old Sep 11, 2012, 12:26 PM
daedalusrobert is offline
Find More Posts by daedalusrobert
daedalusrobert's Avatar
United States, GA, Valdosta
Joined Jan 2009
Yeah sorry...dyslexia got me again. Got it 175.00 plus shipping.
daedalusrobert is offline Find More Posts by daedalusrobert
Old Sep 11, 2012, 02:41 PM
Joined Apr 2008
I'm not planning to do high power manuevers (KE spin, pop top, tumbling, etc.) with this plane. I've left over from flying helicopter are these Jr. 8717HV servos rated at 215 oz/in at 6v or 230 oz/in (16.5 kg/cm) at 7.4v. Enough torque or should I go with servos with higher torque rating? Trying to save money on the servos so I can get a better 6S motor.
Also, I've got 6s 3000 mAh batteries (from the MSH Protos) and 6s 5000 mAh batteries from the 90 size electric helicopters. Too small and too big?
I went on AlleRc and I can get it free ground shipping to California! May be a spare kit ....
Old Sep 11, 2012, 03:55 PM
TomM is offline
TomM's Avatar
State College PA
Joined Jul 2002
Those servos are no good. You should send them to me.
They will be outstanding for this plane. They'll do anything the plane can do.
I'm running 6S 4900 so 5000 will be great. Batteries are pushed pretty well forward, so with 6s 3000 you might have to add some nose weight for only a shorter flight.
Old Sep 12, 2012, 05:44 AM
feathermerchant is offline
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Yup. You'll need the weight of the 5,000 for sure. A spinner would help.
feathermerchant is offline Find More Posts by feathermerchant
Old Sep 12, 2012, 02:53 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
And still don't believe the stated CG in the manual!! for first flight at least 3/8" forward if not more!!
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Old Sep 12, 2012, 08:46 PM
TomM is offline
TomM's Avatar
State College PA
Joined Jul 2002
Well, just bought my spare Samson @ All e RC. COuldn't pass up that price.
Old Sep 12, 2012, 10:53 PM
Joined Apr 2008
I've to admit that I'm a big fan of Motrolfly based on performance, reliability and most of all the personal services from Ken. As such, I'm thinking of getting this motor DM4235-340kv.
* Weight: 455 grams
* Stator Width: 43mm
* Stator Height: 25mm
* Motor Width: 54.8mm
* Motor Length: 52mm
66.3mm X mount to Hub face
* Hub Length: 38.5mm
* Hub Shaft: 8mm x 30mm
* Motor Shaft Size: 6mm
* 12 tooth 14 magnet DLRK
Motrolfly posted these test results:
18x8 APC, 21.7V, 6600 rpm, 59.36 amps, 13.9 lbs. thrust
18x10 APC, 22.0V, 6400 rpm, 71.0 amps, 16.25 lbs. thrust
19x10 APC, 22.1V, 6125 rpm, 83.77 amps, 17.5 lbs. thrust
Too extreme for this Samson? Hopefully the x-mount fits the bolt pattern and the motor will not be too long for the cowl.
Sorry, two more questions (and most likely will not be the last), how much room do I need to land this baby? Harrier landing possible?
Old Sep 13, 2012, 01:02 PM
Joined Jan 2009
Looks like they tried to address the weak LG mounting plate...mine (arrived yesterday) has a phenolic/G10 plate across the bottom!
Old Sep 13, 2012, 05:11 PM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
That's good....I never had any problems....but then, I fly off of a paved runway, and the only flight where I had a problem was on the maiden, since it was very tail heavy.
I really think that the biggest problem for me, (and this is pretty much for all Hyperion planes) is the lack of spare parts availability in case you do have a problem. I sold mine to a gentleman, and had it professionally packed, but not knowing any better, they supported the tail by putting some blocks under the stab at the tips, and due to getting bounced, both sides of the stab broke. The gentleman was very nice about it, and said he would repair it (fortunately, I had sent him a roll of the Hyperion covering that I had bought), and didn't even want any money back etc.... I called AlleRc and tried to get him a new stab, but there were none available, and it would have had to have been special ordered from wherever the planes are manufactured...and they really didn't act like it was feasible to do so....
SteveT
Old Sep 13, 2012, 11:10 PM
pootman is offline
Find More Posts by pootman
pootman's Avatar
Goleta, CA
Joined Mar 2006
Lack of parts is the reason my Samson's been sitting for over two years now with a broken cowl and wheel pants. I swore I wouldn't order another Hyperion plane, but I broke down when I saw the price at allerc. :-). The Samson is such a beautiful plane and it also flies great.
pootman is offline Find More Posts by pootman
Old Sep 14, 2012, 01:47 AM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
So did you let your wife fly it?
Old Sep 14, 2012, 01:51 AM
SteveT. is offline
SteveT.'s Avatar
San Jose, CA
Are they ceasing, or have the ceased production of this plane? If this why the clearance sale?
SteveT
Discussion Hyperion's New Emeter II & RDU NipponDave Power Systems 747 Jan 13, 2016 01:18 PM
Discussion Blu-Baby Aerial Photography Aircraft mark II Tony65x55 Aerial Photography 6 Aug 07, 2007 12:46 PM
Hyperion CAP232 - aircraft-world.com Smifta Sport Planes 144 Dec 16, 2006 12:12 PM
Sold Samson II vett Boats (FS/W) 3 May 11, 2006 12:12 PM
Mystery Aircraft Vol II Sabrejock Scale Kit/Scratch Built 1 Apr 13, 2004 06:11 PM
