Old Jun 05, 2009, 01:03 PM
All electric, all the time!
QuietRCFly's Avatar
USA, WA, Bellevue
Joined Aug 2005
So David, Do you NOT recommend the use of the ZS4025-14? We have the planes on the way, but now power system. Or do you recommend customers use only the ZS4025-16?
Chris
Quiet RC Flying
www.quietrcflying.com
QuietRCFly is offline Find More Posts by QuietRCFly
Old Jun 05, 2009, 07:01 PM
United States, MI, Cedar
Joined Apr 2007
motors
Hey guys, I just ordered mine, but I choice to go with the scorpion 4025-16 on a g3 6 cell 4200, will try several different props. I have 5 scorpion motors, and I luv them all,no problems, and sence they make the Hyeprion motors I doubt If I will notice that much diffrence for me, sport flyer, ethier motor should be great on 6 cells.
tcwoodie is offline Find More Posts by tcwoodie
Old Jun 07, 2009, 06:45 PM
QuietRCFly's Avatar
USA, WA, Bellevue
Joined Aug 2005
Originally Posted by feathermerchant
Something in the Power 60 class works well on a 16X8 or 16X10 depending on kV, battery, etc.
FM,
What motor did you use for the review? Sorry if you already posted and I missed it.
Chris
Quiet RC Flying
Old Jun 07, 2009, 06:50 PM
QuietRCFly's Avatar
USA, WA, Bellevue
Joined Aug 2005
My bad. They do have a 16 turn motor, I just looked in the wrong place.
Old Jun 07, 2009, 07:31 PM
http://www.aircraft-world
NipponDave's Avatar
American in Japan
Joined Mar 2001
16T should be in USA within the next 7~10 days. Hang on...
NipponDave is offline Find More Posts by NipponDave
Old Jun 07, 2009, 08:38 PM
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
Some pics from our local fly in this weekend. The biplane drew a lot of attention and flew well in the wind.
http://web.mac.com/donhenderson/Site...w-in_2009.html
feathermerchant is offline Find More Posts by feathermerchant
Old Jun 09, 2009, 04:12 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
Zs 4025 16 Props on 6S
Hi All,
Here is the prop data for the 16T motor on 6S. test used VX5500mAh, so a smaller or lower-c-rated pack will draw a bit less. For most Setups, 17x12 is the best place to start, imo, maybe up to 18x12 depending on personal preference and flying style.
FEATHERMERCHANT: A 16T motor is on the way to you today, with 17x12 prop. Please test fly and include the Zs40 motor info in the Ezone review, thanks.
BTW, I just noticed the rpm figures were too high in the first GIF image posted. RDU "magnet count" was set to "8" rather than the 14 for the Zs4025 (we were testing speed motors with 8 magnets earleir this week) GIF now has corrected rpm numbers...
Old Jun 09, 2009, 05:02 AM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
Dave - I submitted the review last night. I have the 4025-14 and the box says 314kV
Is that right?
I'll fly it on the 16T and shoot more video as soon as I get it. There will be a whole thread after the article.
Old Jun 12, 2009, 02:20 PM
Danger is my middle name
diamondd7711's Avatar
USA, DE, Magnolia
Joined May 2008
Bump....any news on this plane?
diamondd7711 is offline Find More Posts by diamondd7711
Old Jun 12, 2009, 03:17 PM
QuietRCFly's Avatar
USA, WA, Bellevue
Joined Aug 2005
We now have them in stock. However we do not ship to the UK, so you should check your locol distributor. However, no motors yet.
Chris
Quiet RC Flying
Old Jun 12, 2009, 04:51 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
The review should be out here on RCG very soon (days)
Old Jun 13, 2009, 05:11 AM
Where did Steve go ?
Alexandra
Joined Jul 2007
Woohooo flew mine today
After picking up the first Wolf II in OZ last week it was great to finally get a chance to fly her today.
She is running a ZS4025 swinging a 19x8 on 5s (5000) and flys extremely well. I did an amp draw test with a soft pack and found about 55 amps for a bit over a 1000 watts.
It was a bit gusty today but I had a hankering to fly some I decided to give it a go anyway. Takeoff was a gentle 5 metres into a soft climb. This power setup is definitely not unlimited vertical but it is more than enough to fly the plane and recover if needed. To be honest I bombed around on half throttle for most of the time.
Stall was the biggest surprise, I expected her to be a typical bipe and drop a wing but she just mushed and the nose slowly dropped, power on and away.
Landing was typical for a bipe and definitely one with a nose like this. Power on landings are a must. Here is where the wind became an issue. Power positive flying into a landing that is just below takeoff speed gets real interesting with the a gust at touchdown. The airframe is so light that power off on touchdown still takes the plane a while to become firm on the ground.
Anyway this ones definitely a keeper, well done guys.
Can't wait to try 6s next weekend with a slightly smaller prop.
flyingrally is offline Find More Posts by flyingrally
Old Jun 13, 2009, 09:35 PM
Joined Apr 2007
samson
mine is almost done, bench test with g3 4200 6 cell on a 18 x 12 xoar wood is running 1150 watts at 55amps. I am using a new scorpion 4025-16. It has a lot of pull, I could go as much as 70amps max and 2000 watts, not sure if I need that, hope to fly it buy next week.
Old Jun 14, 2009, 07:58 AM
Alexandra
Joined Jul 2007
Cog
With no manual to go on this is where I am flying with a 5000 5s battery pak located. The line marks the BACK of the pack. I think I can start to experiment with moving the pak back slightly, although I think I will experiment going forward a bit first
Old Jun 14, 2009, 09:38 AM
Joined Apr 2007
cg
the manuel says 3.5 from leading edge of top wing, I am using a 4200 6 cell, I will let you no where my comes up. going to try to use cg machine, dont think i can because of size of the plane, I can always make one using 2 2x4 with pegs in each one....
Discussion Hyperion's New Emeter II & RDU NipponDave Power Systems 676 Apr 12, 2013 10:46 AM
Discussion Blu-Baby Aerial Photography Aircraft mark II Tony65x55 Aerial Photography 6 Aug 07, 2007 11:46 AM
Hyperion CAP232 - aircraft-world.com Smifta Sport Planes 144 Dec 16, 2006 11:12 AM
Sold Samson II vett Boats (FS/W) 3 May 11, 2006 11:12 AM
Mystery Aircraft Vol II Sabrejock Scale Electric Planes 1 Apr 13, 2004 05:11 PM
