Old Jun 03, 2009, 03:00 AM
NipponDave is offline
Find More Posts by NipponDave
http://www.aircraft-world
NipponDave's Avatar
American in Japan
Joined Mar 2001
NOTE!! All the initial testing for the Samson was done using a 16x8~16x10 prop with the new (and rather fabulous) Zs4025-14 motor. However, after the new G3 4200 and 5000mAh VX packs were available to us, we found that a Zs4025 16-turn motor and bigger prop works even better, due to G3's higher voltage output.
Zs4025-16 motors (new release) will be available in USA on about June 10.
With the Zs4025-16 and suggested 6S batteries (4200/5000 VX 6S) prop to start should be 17x10. 17x12 or 18x10 are options depending on your style and batteries. (up to maybe 18x12 with static current test)
ESC should be 80A minimum. SBEC should be fine (only 4 servos). Atlas Digital DS20-FMD suggested for all positions.
Here're some more pics at Hyperion-world.com . Video should follow in a week or less.
NipponDave is offline Find More Posts by NipponDave
Old Jun 03, 2009, 06:16 AM
QuietRCFly is offline
Find More Posts by QuietRCFly
All electric, all the time!
QuietRCFly's Avatar
USA, WA, Bellevue
Joined Aug 2005
If you go with a less powerful battery, like the LVX series or CX, would you still use the 14 turn version? I am sure lots of guys already have those or TP or FP packs.
Chris
QuietRCFly is offline Find More Posts by QuietRCFly
Old Jun 03, 2009, 08:32 AM
Stuntman is offline
Find More Posts by Stuntman
Upside down Miss Jane....
Stuntman's Avatar
Georgetown, Newcastle, Australia
Joined Aug 2002
My Sampson II arrived today. WOW looks great, and its a big plane. ZS4025 coupled with G3 batteries will challenge some conventional thinking I reckon. I am with Chris though - I have motors that would suit and have older (25/30C) cells that are still fine. I am seriously thinking about trying a ZS motor but with the cells I have - is the 14turn the right motor?
Shawn
Stuntman is offline Find More Posts by Stuntman
Old Jun 03, 2009, 01:06 PM
feathermerchant is online now
Find More Posts by feathermerchant
Use the 4S Luke
feathermerchant's Avatar
USA, TX, Euless
Joined Aug 2003
You can always prop down. Drop an inch in pitch for instance and test amp draw on the ground.
feathermerchant is online now Find More Posts by feathermerchant
Old Jun 04, 2009, 01:28 AM
go-flight is offline
Find More Posts by go-flight
Hyperion Europe
Joined Jan 2006
Hi all,
Here is a video of a late prototype flying just after New Years eve in North Germany. Max Ebert, who is flying the Samson is a show pilot that is flying for Hyperion, showcasing mostly our aerobatic models. Max is also greatly assisting us in finding the optimum drive lines, CG and throws that fit not just one flying style.
We have tested everything from 5s to 8s and landed on 6s as the ideal setup considering AUW to power ratio and flight characteristics. It is really very powerful as you can see in the video.
Please note that this is a pre-production prototype. Scale details are improved in prodution model, but flight characteristics are very similar.
Samson flight video from Jan. 2009
The video is hosted by Max' club; thank you very much to MBC Lübeck! You can see some more pictures from the day the video was shot at the site of the club.
go-flight is offline Find More Posts by go-flight
Old Jun 04, 2009, 01:52 AM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
Wow, As a 3D pilot i was just going to get one as i think it looks just amazing, but now i get the best of both worlds. Just loverly. How easy is it to set up at the field ?
OzparkPilot is offline Find More Posts by OzparkPilot
Old Jun 04, 2009, 02:29 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
Hi G,
I'm 99% sure that this vid was shot on the Zs4025-16 motor prototype, but pls confirm that for me. Current (70A they listed) seems a bit higher than expected considering previous 4350Cx and 17x10.
D
Originally Posted by go-flight
Hi all,
Old Jun 04, 2009, 02:32 AM
Hyperion Europe
Joined Jan 2006
Hi D,
Correct, we used the 16-wind prototype of the Zs4025 in the video.
We tried a lot of props and made both static and dynamic measurements with the RDU. I will find the data and post in here.
Gudmund
Old Jun 04, 2009, 02:33 AM
NipponDave's Avatar
American in Japan
Joined Mar 2001
It's not too difficult to remove the wings. We use aluminum mount plates (epoxied into the wings) to attach the struts. The mounts are tapped, so you don't need to mess with nuts and washers.
Having said that, I'd personally prefer a vehicle that can hold the assembled model. Since it's a Bipe, the span isn't so big and most mid-size hatchbacks, etc, should be able to fit it.
David
NipponDave's Avatar
American in Japan
Joined Mar 2001
Hi D,
Gudmund
Thanks. We've just started testing the production motor, so need to check the data against yours...
David
Old Jun 04, 2009, 06:15 AM
Hyperion Europe
Joined Jan 2006
Samson throw recommendations
These are our recommendations for surface throws on the Hyperion Samson II:
For the first flight we recommend these settings
- Elevator 18mm up/down or 10 degrees up/down
- Aileron 13mm up, 6mm down or 12 degrees up, 6 degrees down
- Rudder 37mm
For 3D flying
- Elevator 36mm uo/down or 20 degrees up/down
- Aileron 33mm up, 17mm down or 28 degrees up, 15 degrees down
- Rudder 70mm
Even if you consider yourself a 3D pilot we do NOT recommend you start out with the 3D throws. Especially the elevator is very effective.
Expo as per preference as usual
Gudmund
Hyperion Europe
Old Jun 04, 2009, 11:42 AM
diamondd7711 is offline
Find More Posts by diamondd7711
Danger is my middle name
diamondd7711's Avatar
USA, DE, Magnolia
Joined May 2008
That is one hot looking plane. Need more video!!
diamondd7711 is offline Find More Posts by diamondd7711
Old Jun 04, 2009, 10:58 PM
Use the 4S Luke
USA, TX, Euless
Joined Aug 2003
There is some video shot by a friend during our review flying. It's the first or second flight. I'll try to get a link.
I watched the video above and all I can say is that guy is a great pilot. Very smooth.
Old Jun 05, 2009, 11:33 AM
thef is offline
Find More Posts by thef
France
Joined Feb 2007
thef is offline Find More Posts by thef
Old Jun 05, 2009, 12:06 PM
thef is offline
France
Joined Feb 2007
Discussion Hyperion's New Emeter II & RDU NipponDave Power Systems 968 Jul 31, 2016 05:11 PM
Discussion Blu-Baby Aerial Photography Aircraft mark II Tony65x55 Aerial Photography 6 Aug 07, 2007 11:46 AM
Hyperion CAP232 - aircraft-world.com Smifta Sport Planes 144 Dec 16, 2006 11:12 AM
Sold Samson II vett Boats (FS/W) 3 May 11, 2006 11:12 AM
Mystery Aircraft Vol II Sabrejock Scale Kit/Scratch Built 1 Apr 13, 2004 05:11 PM
