Old Sep 26, 2009, 12:02 PM
tIANcI is offline
Find More Posts by tIANcI
Xtreme Nut
Kuala Lumpur, Malaysia
Joined Oct 2005
Steve ... after finally trying the XOARs I ain't keen to go back to APC E props.
tIANcI is offline Find More Posts by tIANcI
Old Sep 26, 2009, 12:06 PM
ron9844 is offline
Find More Posts by ron9844
Joined Jul 2004
What is everyone using for a spinner, I have been looking at a 2 3/4" spinner but I cannot find one that will fit the propeller without cutting.
Ron
ron9844 is offline Find More Posts by ron9844
Old Sep 26, 2009, 04:50 PM
SteveT. is online now
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Hi Ron....
I don't know about a 2 3/4" but Great Planes has this 2.5" beauty at $23.95 (though I got mine for $17.95)...and you use this Dave Brown prop adapter. The screw that comes with the spinner is a 10-32 as is the thread of the adapter (8 X1.00mm prop shaft, 10-32 spinner bolt thread), you just need to use a shorter 10-32 spinner screw.
And... It fits an APC 18-10 perfectly no cutting, no filing...(haven't tried an 18-12)
And....the contour is almost perfect!!
OR... this 2.5" Tru-turn at $38.95
OR... this 2.75" Tru-Turn at $42.95.
You can use the same adapter....again using a shorter screw, however neither of the Tru-Turn spinners are polished, and they really aren't the correct contour..
SteveT
SteveT. is online now Find More Posts by SteveT.
Old Sep 27, 2009, 09:47 AM
Knotnuts is offline
Find More Posts by Knotnuts
Knotnuts's Avatar
Joined May 2008
The Maxx Products (MPI) 2 3/4" is another good choice, at about the same price ( $20-$25). No cutting is necessary for the 18" props. It will need a 8mm adaptor for the Hyperion motor. I beleive that Quitefly R/C carrys what you need.
Knotnuts is offline Find More Posts by Knotnuts
Old Sep 30, 2009, 09:32 AM
Steve Graham is offline
Find More Posts by Steve Graham
AMA L897187
Steve Graham's Avatar
NE Denver, CO
Joined Sep 2007
I am taking leave of the Samson for awhile until I feel like looking at it again. Exceedingly poor design of the landing gear box.
One gear broke off on a somewhat less than graceful landing. The landing gear plate, that has lightening holes in it for a reason that escapes me, broke in half with all 3 blind nuts still attached to the right gear. There was no bending of the landing gear plate so how hard could the impact have been to actually break the gear box in half. There was no damage to the AC other than the puncture to the wing skin caused by the gear fairing. Not even the prop broke. I really feel that the design should have at least allowed the gear to bend before tearing itself free from the airplane.I will eventually get around to redesigning it. If I can find a camera I will post some pics later.
Good chance that this will be my last Hyperion model as time and money are too short to waste on ill designed product. Sorry Nippon Dave but while I still claim that you have a model that presents beautifully I have to say that the 18 months and 4 peoples time spent engineering this model were largely wasted due to this fatal flaw. I've heard that some people always reinforce landing gear before flight but I've had many other models that did not require this and I consider it the realm of re-design.
Regretfully, Steve Graham
Steve Graham is offline Find More Posts by Steve Graham
Old Sep 30, 2009, 09:45 AM
Knotnuts is offline
Knotnuts's Avatar
Joined May 2008
Hmm... I'm still getting mine together, I have re-enforced the gear plate area with GG and additional CA. Would like some post accident pictures of where yours failed.
Old Sep 30, 2009, 11:58 AM
abuss is offline
Find More Posts by abuss
Switzerland, BL, Rünenberg
Joined Aug 2008
hi
reinforcing the landing gear area seems to be necessary for many models: I did it with Samson ( otherwise fantastic plane ), as well for example with Extremeflight`s 58`Extra300, E-flight Taylorcraft and some other planes. With the exception of Samson i ripped out the landing gear plates after the first few (not sooo bad ) landings. To prevent this i did it BEFORE braking Samsons gear. Now I do it with all my new Models, doing it before starting to build makes things easier.
Yes, manufacturers should take more care of those areas, it would cost nothing than a little bit of weight.
Regards from switzerland
Alex
abuss is offline Find More Posts by abuss
Old Sep 30, 2009, 12:09 PM
AMA L897187
NE Denver, CO
Joined Sep 2007
OK, I went ahead and took some pics. The damage looks a lot like some of the other LG failures we've seen. One thing that might help is if the Landing gear plate itself had been one piece instead of two separate sides. It appears to me anyway that the inner edge of the LG puts a lot of stress on a plate already weakened by lightening holes. Still considering how I want to repair it.
Old Sep 30, 2009, 12:51 PM
maverickma is offline
Find More Posts by maverickma
maverickma's Avatar
Fogelsville, PA
Joined Mar 2004
With my Hyperion planes (Yak 55 25e & Chippy 70e), before flying, I reinforce the gear area with epoxy, wood, CF tape etc...whatever I can get in there. I then go with softer wheels. Specifically Dave Brown Lite Flight wheels that are a tad larger in diameter and much softer which help to ease the trauma of landing. I fly off of a rolled grass field and so far this has worked for me. From my limited experience, the wheels Hyperion supplies are on the hard side which may contribute to the stress on the landing gear. Hope this helps.
maverickma is offline Find More Posts by maverickma
Old Sep 30, 2009, 03:38 PM
Knotnuts is offline
Knotnuts's Avatar
Joined May 2008
I'm going to mull over removing some balsa from the gear area on the bottom of the fuselage (where it won't be seen) over the landing gear bolts. Then add some re-enforcement to the L/G plate from the bottom of the aircraft to strengthen the area around the lightening holes. I don't see a better way to be able to get to the problem area. Might be able to put a piece of red Monokote back over the area that I remove to hide my surgery when I'm finished if needed. This is just to nice of an airframe to let a little problem like this get in the way. I know that future releases are going to correct this but...... Any other suggestions?
Old Sep 30, 2009, 06:11 PM
AMA L897187
NE Denver, CO
Joined Sep 2007
Knotnuts,
Just got back from the LHS. A couple of ideas emerged. Evidently split LG like this as in not one single piece of bar stock tend to tear out easier than one piece. One guy said to strap the two gear legs together with a strip of aluminum bar stock and I am going to try that. I'm also going to heavily gusset and reinforce the area with NON-litened ply. Of course in your case doing this means cutting out the balsa belly skin. That should be easy to repair and well worth it IMO. I picked up some stainless steel 4mm bolts and blind nuts at the hardware store. 4mm was the smallest they had, the big benefit of the new blind nuts is that they have almost twice the face area that pulls up to the wood and that should help a lot to spread out the loads.
Steve
Old Oct 01, 2009, 02:35 AM
flyingrally is offline
Find More Posts by flyingrally
Where did Steve go ?
Alexandra
Joined Jul 2007
mmMMM, one piece landing gear sounds like a very good idea. Never thought of that. Not something you can do in this kit from the start but once the skin is pulled back due to some damage you could do that and the reskin over it.
Nice one
Originally Posted by W.W. Corrigan
Knotnuts,
Steve
flyingrally is offline Find More Posts by flyingrally
Old Oct 01, 2009, 06:57 AM
ron9844 is offline
Joined Jul 2004
I have been thinking of making a strap to tie the legs together. I think that with the gear legs off you can slide a metal ruler in to get a measurement between the gear bolts and then get a measurement for the width of the bolts. I am thinking of using a piece of good Aluminum or Steel ( since it sounds like the plane can use a little weight up front) the same width and maybe a little thicker and paint it black. I haven't really looked yet buy also thinking of removing the Blind Nuts and adding another layer of REAL PLYWOOD under the gear mounting plate to help make everything stronger. This seems to be the weak area on most ARF's and it is such an easy fix for the manufacturer during beginning assembly, also why the like using LITE PLY instead of REAL PLYWOOD in such a critical area is very confusing since the cost would be very minor. When I finish I will post some pictures of the rework.
Ron
Old Oct 01, 2009, 11:35 AM
ron9844 is offline
Joined Jul 2004
Have all of the builders been using the Dummy Plastic Engine, Have you been cutting out between the engine outlines and if you are using it have you experienced any heating problems.
Ron
Old Oct 01, 2009, 12:44 PM
attack duck is offline
Find More Posts by attack duck
Joined Feb 2005
Sorry about your mishap Steve. The plane looked and flew fantastic. It's a shame Hyperion put so little thought into the gear strength. Then to add insult
to injury the gear fairings punched out the leading edges. On mine I will make the gear fairings out of foam so we don't get a repeat performance!
attack duck is offline Find More Posts by attack duck
Discussion Hyperion's New Emeter II & RDU NipponDave Power Systems 968 Jul 31, 2016 05:11 PM
Discussion Blu-Baby Aerial Photography Aircraft mark II Tony65x55 Aerial Photography 6 Aug 07, 2007 11:46 AM
Hyperion CAP232 - aircraft-world.com Smifta Sport Planes 144 Dec 16, 2006 11:12 AM
Sold Samson II vett Boats (FS/W) 3 May 11, 2006 11:12 AM
Mystery Aircraft Vol II Sabrejock Scale Kit/Scratch Built 1 Apr 13, 2004 05:11 PM
