Old Oct 04, 2012, 03:58 AM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
Some update in website http://www.smartmodel.com.hk/product...3&third_id=325
kin is offline Find More Posts by kin
Old Oct 04, 2012, 06:16 AM
Horseman is offline
Find More Posts by Horseman
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Originally Posted by kin View Post
Nice
Horseman is offline Find More Posts by Horseman
Old Oct 06, 2012, 02:38 AM
scraper is offline
Find More Posts by scraper
Joined Sep 2008
Originally Posted by Pelle57 View Post
Hi!! Can you show a picture of the status of the plug of 800-size UH-1D compared to the picture in # 3406 ??
I think we are many in here who are interested to know and see.
Thanks...
The basic plug is complete, i have started covering it with aluminum panels so it has a real wrinkled look to it like the real one. Here is a teaser shot of the horizontal stab nearly completed.
scraper is offline Find More Posts by scraper
Old Oct 06, 2012, 05:15 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Keep to work like this nice !!!!!!!!you are super !
Old Oct 06, 2012, 08:08 AM
Pelle57 is offline
Find More Posts by Pelle57
Joined Sep 2010
Super!!!!
That's looks really, really nice!!!!!!
Yes....it's a REAL teaser!
I will be lucky that day I can put my fingers on one of those.....can't wait!
Keep up the good work and thanks a lot for the picture....then we know the project are still running
Pelle57 is offline Find More Posts by Pelle57
Old Oct 06, 2012, 09:56 AM
Pelle57 is offline
Joined Sep 2010
Low headspeed 800-size
Hi!
When these birdies start to reach 800-size and bigger and some models are suitable with lower headspeed (UH1 for example), are there any solutions to keep a good tail rotor speed???? What I can read here in forum are 1100 rpm suitable to use if you not want to loose tail power.
Is it possible to change the gear ratio to tail in some way??
On the tail drive set it's two places with gears, does it exist some option gear to change???
Or are there any other solutions to clear the problem on a Trex 600 mechanic??
Old Oct 06, 2012, 11:59 AM
Brutus1967 is online now
Find More Posts by Brutus1967
the great Gassif´er
The Netherlands
Joined Nov 2009
Hi!
Don't worry too much about it: chances are (backed by my experience) that if you can lower the headspeed sheer due to increased helicopter size, very likely the tail speed does not need to be that high too (tail rotor size is increasing too, remember?)
Brgds, Bert
Brutus1967 is online now Find More Posts by Brutus1967
Old Oct 06, 2012, 04:05 PM
Rodan is online now
Find More Posts by Rodan
Rotor madness!
Rodan's Avatar
Northern AZ
Joined Oct 2006
Brgds, Bert
Not necessarily true in my experience... As the torque increases with longer, heavier, and more main blades, so the demands on the tail go up as well. My 60 size Jet Ranger is 12.5lbs running TRex 600 mechs at 1450, with 650 OF main blades and 105 tail blades. I have experienced LTE in moderate winds (8-10mph) when the T/R is pushing downwind. Nothing like an uncommanded 90 degree rotation to get your attention...
You can only increase the size of the T/R blades to a certain point... Speeding up the T/R is a much better way to counteract the increased anti-torque demands of a larger scale ship. Driving the tail off a second motor seems to me to be an excellent way of handling things, but has drawbacks with weight and complexity. A 'speed up' gear option would be the best method, but currently doesn't exist.
Rodan is online now Find More Posts by Rodan
Old Oct 06, 2012, 04:38 PM
cap231ex is offline
Find More Posts by cap231ex
Track clear , smoke on !
cap231ex's Avatar
3 miles from AMA HQ Muncie, IN.
Joined Jan 2009
I agree with Rodan on this subject , as my 60 size Long Ranger with T-600 mechs runs a HS of 1050 and 95mm tail blades but is runnig a higher tail rotor ratio.
I used this Thunder Tiger Titan SE Raptor 50 8t pulley on the tail rotor output shaft to greatly increase the tail rotor speed.
http://www3.towerhobbies.com/cgi-bin...?&I=LXAHBR&P=0
cap231ex is offline Find More Posts by cap231ex
Old Oct 06, 2012, 06:54 PM
the great Gassif´er
The Netherlands
Joined Nov 2009
Just switch off your headlock...
Your problem is not in tail authority, but in the headlock robbing you of the feedback that would otherwise have warned you way in advance, that you are about to overload your tailrotor. Once overloaded, the controlling action of the headlock makes sure it stays overloaded until airflow over the tailfin takes over. Hence the 90 degree turn or more, usually until the nose is in the wind again.
I have seen this numerous times.
I fly a 3 bladed .60 size trainer, running at 1350 RPM (manufacturer recommended max is 1500) and that thing is weighed down to not 12 lbs, but approx 18 (Yes.... Eighteen pounds) and that still does not have any tail problems, with stock tail blades and stock gear ratios
Don't take my word for it: Just get into rate mode, try it yourself and be amazed how much more your tail seems to be able to handle safely (but of course, don't overdo it).
Brgds, Bert
Old Oct 07, 2012, 12:34 AM
Pelle57 is offline
Joined Sep 2010
800 size headspeed
I am going to start to build a UH-1D, when it will be released, and have planned to use a 480kv motor on 8s which should give HS around 1000 and lower.
Have anyone tried HS 1000 or under that on 800-size scale bird? Want to try the setup on 8s (2x4s) because of the weight also.
Have seen some examples on youtube where they fly 700-size on HS around 700-900 and they fly great.....but of course, they are ordinary helis, not heavy scale machine.
Kin says he fly the UH-1 with HS 1100 and my question is.......do anyone know if it's possible to go under 1000 on 800-size with a 2-rotorblade machine??
Old Oct 07, 2012, 01:57 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Yes ! i think the HS below 1000 is not easy in market mechanic .first need to let the tail gear speed ratio success higher at least 15-20 % . at the same time tail blades length longer about 20mm but hope not out of scale look and no hit the main blades . In the torque tube system i have a new version HGR (Hight gear ratio) .The output gear have 5 teeth more (25 teeth ) , my now version output gear is 20 teeth , so 25% more different higher . now have doing the second version .SM-HGR tail drive system !!!!! It is 1:1.25 Ratio higher
Old Oct 07, 2012, 02:17 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Ok new ! SM -HGR (1:1.25 fast version) torque tube raise tail system coming soon .It will come out in middle Oct . Ha Ha ! Just a little bit different cost let me buy new gear ..188 usd only
Old Oct 07, 2012, 02:21 AM
Pelle57 is offline
Joined Sep 2010
Hgr
That looks really good Kin!!!
Hope that project will develope and sucsess in the right way.
Look forward to hear report from you and see testflight!
Keep up the good work Kin
Old Oct 07, 2012, 02:24 AM
Pelle57 is offline
Joined Sep 2010
So that means when the customers buy the scale kit from you they can choose if they want a STANDARD or a HGR version for the tail....right??
Discussion Trex 450/500/600 and Honeybee King II in same pic anyone? turnbui Micro Helis 0 Mar 15, 2008 10:18 PM
Discussion Looking for a cheap 500-600 size brushless Jupeli Power Systems 33 Mar 02, 2007 05:42 PM
Wanted Inflatable Floats for Trex 450 and 600 size helis ShokWaveRider Aircraft - Electric - Helis (FS/W) 0 Feb 12, 2007 07:54 PM
Discussion Trex 450 - Trex 600 Size Comparison mrfirkin Mini Helis 3 Aug 26, 2006 09:18 PM
high-rate NiMH button cells Capacity mAh: 120,400,450,500,600 GKP27 Scratchbuilt Indoor and Micro Models 2 Jun 21, 2003 06:03 PM
