Old Aug 31, 2012, 08:10 PM
scraper is offline
Find More Posts by scraper
Joined Sep 2008
This is what i started with
scraper is offline Find More Posts by scraper
Old Sep 01, 2012, 01:36 AM
Pelle57 is offline
Find More Posts by Pelle57
Joined Sep 2010
Nice, that is the UH-1 D, right? Very beautiful lines on that one.
Keep up the good work!
Pelle57 is offline Find More Posts by Pelle57
Old Sep 01, 2012, 12:18 PM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
Sorry for later reply guy ! Sorry just back from Shanghai hobby show . The Uh-1d will come out soon , the master plug will come to factory soon . My uh-1 rotor blades and head are ready here . TT drive system also fit to this fuselage . it size very close to 1/6 . so find your 1/6 figure is the time now .don't worry the fuselage , when the plug complete , within two week can see the first piece models . The new AS-355 F-2 also come out now .it will very good price ! 368 usd only
kin is offline Find More Posts by kin
Old Sep 05, 2012, 06:08 AM
ghostpipe is offline
Find More Posts by ghostpipe
Heli-Teck
Switzerland
Joined Nov 2009
Hi Kin,
do you have in stock your Scale carbon rotor blades 5 piece set for 600 /700 size?
In your web site I don't see the photo.....
Mirko
ghostpipe is offline Find More Posts by ghostpipe
Old Sep 05, 2012, 10:11 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
[QUOTE=ghostpipe;22645711]Hi Kin,
Mirko[/QUOTE
We have stock, Just the photo not update , Now the blades is new weighted version and 120 g each piece . WE have sold over 300 piece in market since two month ago . All good commend and now JX helicopter test fly in Japan , base report is very positive .And the safty test in high level now ! Because the super strong Blades gripe re-inforcment , i cut a section near the blades screw hole about 5cm distance . the carbon re-inforcement material still 35% inside the section ., i have cut other (super good band name blades ) to compare . we still the stronger one . but we make the products higher cost , but i want safty be the first . The weight is a waved shape lead , it wave shape and lock with the inside hard wood and fill full epoxy .not possible come out . it same the Align 3-D blades . but we never 3-D in scale .I am not the BEST rotor blades but i hiope to be the best SAFTY blades .
Old Sep 05, 2012, 11:32 AM
BlackTitanium is offline
Find More Posts by BlackTitanium
3D and Scale RC Heli Pilot
BlackTitanium's Avatar
Monroe, WA
Joined Jan 2007
Hi Kin,
I don't see 500 size CF scale blades on the website.
I need a set of 4 blades, and I need them shipped express.
Are they out of stock? No longer available?
BlackTitanium is offline Find More Posts by BlackTitanium
Old Sep 05, 2012, 12:25 PM
Heli-Teck
Switzerland
Joined Nov 2009
Kin,
thanks a lot for the reply! And the good news
I want to use this blades with the "SM CN1105 SCALE DAMPING 5 BLADES ROTOR HEAD FOR 30/50/600 SIZE", but the blade root are 16mm, and the bolt holes 5mm....
You can make the 5mm hole in the blades? Maybe do you have the washer for the blades root?
[QUOTE=kin;22647482]
Originally Posted by ghostpipe View Post
Hi Kin,
Mirko[/QUOTE
Old Sep 05, 2012, 12:30 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
[QUOTE=ghostpipe;22648665]Kin,
5mm screw is easy after i special match you a set of the blades . but 16mm can you find the spacer ? you can find funkey blades also come with some
Old Sep 05, 2012, 12:33 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Originally Posted by BlackTitanium View Post
Hi Kin,
500 scale blades will come out next month . we doing my owm design before is a out soucing products , but not scale looking !
so i stop that products and build my own blades now .
I will have 550mm . 680mm .425mm and 600mm Apache version .
Old Sep 05, 2012, 01:25 PM
Heli-Teck
Switzerland
Joined Nov 2009
ok, I write you a e-mail for make the order?
[QUOTE=kin;22648730]
Kin,
Old Sep 06, 2012, 06:22 AM
g5sean is offline
Find More Posts by g5sean
Joined Jan 2012
Originally Posted by kin View Post
The new carbon -friber rotor blade is come out now , it have 450 -325mm/500-425mm /600 -600mm . you can find in this link :http://www.smartmodel.com.hk/product...sub_cat_id=303
Dear Kin,
Are you going to make these in 650 to 680 length? We need these for the larger models and they would be perfect for the 700 sixed MD500.
Cheers,
Sean
g5sean is offline Find More Posts by g5sean
Old Sep 06, 2012, 10:51 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
The 680 still in conside the market . i think if keep this width 42 mm and extend to 680 , the look is very very nice , especial for 5 blades Hughes ,and fit the 700 size fuselage , it can call very very scale .i thinking the market is ok , i do it now ! any commend about this 680mm x 42mm size .but i can say .never disappointed ! Is it ???
Old Sep 06, 2012, 10:22 PM
g5sean is offline
Joined Jan 2012
Dear Kin,
Yes, it would be very scale for the 700 sized MD500! I need a five blade set now! Please make them symmetrical for left hand rotation, black, with square tips.
And please send me the update on our other project we are working on.
Cheers,
Sean
Old Sep 10, 2012, 11:33 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
In the fuselage .already start is the EC-145 900 size 1.7m . AS-350 900 size 1.75m .Super puma 550 size .3-D darwing now is the Airwolf ,it will have 700 and 900 size two different size .And a uh-1D from a friend master plug , it will sent here soon .ec-155 not yet make decision the size ,and let the fenestron work complete and set the size . Rotor blades is now making the 550/430/325mm in this month .The 680mm and 600 swept tip blades next month .Now i have completed the 780mm , i will make the photo tomorrow . it is clockwise , semi symmetical .mirror look ! super good surface and quality .after our different size cover from big to small 900-325, We will try to go 3-D blades market .but it is next year !.So the as-355 600 in products line now . i will painting about 4-5 standard colour scheme soon this month .EC-145 900 will post the master plug here about two week .it still in milling machine . the material is about 1.0 ton weight . it is super fat and my two daugther can sleep together inside .But it is possible for 700 mechanic and jet-cat mechanic . and full inside cockpit frame and door frame is standard . but not expensive .
Old Sep 10, 2012, 11:34 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Any idea want me to add to the blades ? please offer your idea ! Weclome ! i mean round tip /swept tip /Hughes Look ? eurocopter look? or see my base shape ? But i have no interesting the Lyxn version have a big thing in the tip !
Discussion Trex 450/500/600 and Honeybee King II in same pic anyone? turnbui Micro Helis 0 Mar 15, 2008 10:18 PM
Discussion Looking for a cheap 500-600 size brushless Jupeli Power Systems 33 Mar 02, 2007 05:42 PM
Wanted Inflatable Floats for Trex 450 and 600 size helis ShokWaveRider Aircraft - Electric - Helis (FS/W) 0 Feb 12, 2007 07:54 PM
Discussion Trex 450 - Trex 600 Size Comparison mrfirkin Mini Helis 3 Aug 26, 2006 09:18 PM
high-rate NiMH button cells Capacity mAh: 120,400,450,500,600 GKP27 Scratchbuilt Indoor and Micro Models 2 Jun 21, 2003 06:03 PM
