Old Jul 30, 2012, 01:19 AM
wilerbee is offline
Find More Posts by wilerbee
Hong Kong
Joined Jan 2002
How much is it bigger compared to TF Model's 800 ?
I don't see any difference !
wilerbee is offline Find More Posts by wilerbee
Old Jul 30, 2012, 08:45 AM
g5sean is offline
Find More Posts by g5sean
Joined Jan 2012
Hi Kin,
Where is the 407 in the schedule?
Sean
g5sean is offline Find More Posts by g5sean
Old Aug 03, 2012, 03:27 AM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
407 still in peoccess ! It is too early let it in the topic !
kin is offline Find More Posts by kin
Old Aug 05, 2012, 01:29 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
AS-355F-2 Ecureuil 2
New 600 size AS-355F-2 Ecureuil 2 come out this month , the master plug become complete. door are open and also inside room frame like the 429 . ceiling ,floor, base cockpit ,seat, door frame ...! it is one piece fuselage , matel landing gear , landing gear included the foot step . it is twins engines version . possible special order the colour scheme and factory standard 4-5 colour choice .
Old Aug 05, 2012, 07:25 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
I think the coming future scale model should be like that , inside and outside should be more detail like that photo in the model , it is the internal frame , the coming every models will have this inside detail included . from 600 size to 900 size all have this inside frame .and will included the base cockpit panel and seat , The coming AS-355 also included this detail . So it is a standard SCALE !
Old Aug 05, 2012, 08:36 AM
Rodan is offline
Find More Posts by Rodan
Rotor madness!
Rodan's Avatar
Northern AZ
Joined Oct 2006
REALLY nice stuff, Kin!
I'm looking forward to seeing the 407...
Rodan is offline Find More Posts by Rodan
Old Aug 05, 2012, 09:07 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
this is not only for one models like that detail . it is appear all models . so the work hours is more to develope it , so this year the models is come out slow . i need do double time for a models , because inside and ourside also need scale . the mechanic instill to the models . let see how the mechanic size , but the coming models will develope the dog house mechanic . let the inside room more scale space . and the battery will open hatch up side down in the bottom if necessary ! but i think they don't mind ! The coming AS -335 room same exciting like this . So the scale blades 650 mm will fit it . The new 650mm scale blades flying result very nice in european test pilot , hope the video sent me soon . it is a new drak gray colour , same same the real blades colour now ! the new rotor scale rotor blades weighted , it is 120g each , very happy in flight condition .
Old Aug 05, 2012, 11:07 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Two new member add to the list , they are 700 and 900 Airwolf , the 3-D drawing completed . so the two cnc machine are busy for milling now . The August issue of the helicopter world magzine have a factory walk around of our factory . you will see my face there .
Old Aug 07, 2012, 12:47 AM
eff is offline
eff
Find More Posts by eff
eff
eff's Avatar
Joined Nov 2010
your website is so empty now, not much to choose from, hope all these "coming soon" stuff really come soon.
eff is offline Find More Posts by eff
Old Aug 07, 2012, 10:11 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Yes ! When i have start the new products line , the target is next level in scale , the new models is a lot in the waiting list to the cnc machine . Now is doing the AS-355 TWINSTAR . After this is a Airwolf 800 . 407 is oem so not in my own list .and than should be the Super puma 550 size and a EC-155 Dophin 1/7 . Bell 430 600 size will be a new models(still conside) . After the tail fan models come out and finish the EC-155 , Last in this year is the new EC-146T2 .If the earth still keep rotation end the 2012 . 2013 will go to big size .
Old Aug 07, 2012, 07:31 PM
wangzx is offline
Find More Posts by wangzx
Singapore
Joined Sep 2009
Hi Kin,
When will be the release for Super puma 550 size and can advise me the price? I'm keen of getting one if the price is reasonable
wangzx is offline Find More Posts by wangzx
Old Aug 09, 2012, 12:55 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
The cost roughly 480 usd included the tail drive shaft system (Fit Align) .. retrac gear also included .The 550mm scale blades will have some different type coming out soon .and the 600 swept tip scale blades for Apache and seahawk will come out too .
Old Aug 10, 2012, 06:43 AM
lesskiss is offline
Find More Posts by lesskiss
Joined Aug 2012
Hi Kin,
I've read your posts because I'm looking for heli fuselage and i've seen on your website an 900 size AS350.
I've read it's a 1700mm lengh fuse, but can you tell me more about it?
I know that's a lot of work but If I'm right, i've to wait next year to purchase one?
Lesskiss
lesskiss is offline Find More Posts by lesskiss
Old Aug 11, 2012, 11:25 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
it is a new size 900 , it is a size between big ep and mini turbine mechanic , it possible to fit jetcat mechanic and you use a 700 mechanic to change the bigger motor about 2500 watt , it is so easy to finsd the motor in Neu or Kontronik and Leomotion motor , they are the best motor now in world . find the motor about 400-450 kv let the rotor head speed about 1100-1300 rpm . the models total weight is about 6kg -7 kg . the power set is so (confortable ) . The mechanic is better in 12 mm main shaft to fit my coming new rotor head . the coming models will have the scale head fit it . AS 350 is a very good size and it can easy let your car to transport , you just fold flat the front passenger seat . it is very good to let it sit to the front seat , and you also have two more passenger together in side the car . even your car is Mini copper !
Old Aug 11, 2012, 11:30 AM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
I have a Airwolf is 700 starting now , AS-350 is follow it . hope you can wait .
A younger brother 550 super puma will coming out in September .the time for the AS -350 900 will be in October or maybe Nov !
Discussion Trex 450/500/600 and Honeybee King II in same pic anyone? turnbui Micro Helis 0 Mar 15, 2008 10:18 PM
Discussion Looking for a cheap 500-600 size brushless Jupeli Power Systems 33 Mar 02, 2007 05:42 PM
Wanted Inflatable Floats for Trex 450 and 600 size helis ShokWaveRider Aircraft - Electric - Helis (FS/W) 0 Feb 12, 2007 07:54 PM
Discussion Trex 450 - Trex 600 Size Comparison mrfirkin Mini Helis 3 Aug 26, 2006 09:18 PM
high-rate NiMH button cells Capacity mAh: 120,400,450,500,600 GKP27 Scratchbuilt Indoor and Micro Models 2 Jun 21, 2003 06:03 PM
