Old Jul 05, 2010, 01:58 PM
kin is offline
kin
Find More Posts by kin
kin
Composite factory
Joined Sep 2007
Originally Posted by Bricobrac View Post
WOW !!!
There is only that amount of thread to hold the grips, from an aluminium hub ???
That is just.. crazy..
BEst regards,
Fabien
Yes! it is bad ! so we import models need very carefully the damaged hear are from RH ,no more next time !, so that why i need design ourself and make it in reliable cnc factory and i management the cnc factory to control the quality , So the deao head are ok and no complain in the quality and this new come Copter X are also good !
kin is offline Find More Posts by kin
Old Jul 05, 2010, 03:14 PM
Spidious is offline
Find More Posts by Spidious
Bush Pilots Bounce Higher
Spidious's Avatar
USA, IL, Champaign
Joined Dec 2006
Beautiful head...Can't wait to see what my 5 bladed one looks like !
Would be nice if it was all black...
The copter x one is nice.. But the simplicity of the other one (5 bladed) that has no anti rotation bracket should be even better !
Spidious is offline Find More Posts by Spidious
Old Jul 08, 2010, 11:08 AM
kcornels is offline
Find More Posts by kcornels
Joined Feb 2010
a lot of people are converting their CopterX heads into a rigid one, since the flaping hing is not working very well with stabilisation systems. If you are using softer blades, like the very nice asymetric spin blades, the flaping hinge is not very usefull, neither. The behaviour of the heli will be very soft, since the resulting damping is to big. I will make mine rigd, too. Lets see, how my Bo 105 will behave afterwards... .
kcornels is offline Find More Posts by kcornels
Old Jul 08, 2010, 11:13 AM
SidewaysLS4 is offline
Find More Posts by SidewaysLS4
Redjestird Youser
SidewaysLS4's Avatar
Joined Jan 2009
Shhhh...dont let the secret out! I got some shims on order to tighten up mine, getting kind of tired of the 'plate on a stick' effect on the disk upon transitions myself
SidewaysLS4 is offline Find More Posts by SidewaysLS4
Old Jul 09, 2010, 02:25 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
Hi ! I still alive !!!!!!!!!!! Some day no ba la ba la ....here! but i bring some good news ! The 600 size scale narrow blades are completed . It have two version ,round tip version (euro copter ) .and the Apache swept tip verion . Both syemmatical and make from injection mold . This 600 version are harder material .the carbon % are trim higher .so sport flying are better . the blades screw hold are passed the test over 600 lb . it is 100% safty blades ! i will post the photo soon . The Blue thunder process are become complete . And TF model are coming out the detail scale parts , it have the pitch control stick ,door hinge , RHF Antenna( some different size ). rain brush,wire cutter (some size ),....some item have forget !so i am very busy and not much time here this month . Sorry !
Old Jul 09, 2010, 02:57 PM
kcornels is offline
Joined Feb 2010
I completed mine today and the behaviour of the head is completely different. Before the mod, my Bo was controllable, but it handled a bit like a pregnant rubber cow... . Even in little winds, the heli tried to break out easily... .
Now it handles like a charm. It reacts directly to the controlls, the blade tracking, which has always been a problem in the past is correct. Even light wind isn't noticeable at all. I'm very happy with my rigid head... .
Just insert 4 small tubes with inner diameter of 4 mm and an outer diameter of 4.5mm and you are done... .
But I think, we should discuss this in another thread... . :-)
KIN, are you going to build a Gazelle, after the Blue Thunder is finished ?
Karsten
Old Jul 09, 2010, 03:28 PM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
Rigid head is much better when using flex blades ..... I guess when mechanically setup correctly e-stab will only make it easier to fly. I tried flapping head for 30 days last year; only to switch it back to rigid.
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Jul 09, 2010, 04:41 PM
Redjestird Youser
Joined Jan 2009
Tubes eh? Interesting. I'm going with Tamiya shims...4mmx6mm by .1 .2 .3 (we'll see what the total used is). Should get rid of the in/out play of the existing spacer to oring, and compress the oring tightening up the grip.
Old Jul 09, 2010, 05:34 PM
Minibichus is offline
Find More Posts by Minibichus
MB-Commander
Minibichus's Avatar
Joined Feb 2008
I fly my 600 with a fully hinged grip head and I can't tell any difference between that and the 500 which uses a rigid head. Both are responsive and neither of the two have any issues.
G.
Minibichus is offline Find More Posts by Minibichus
Old Jul 10, 2010, 01:04 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
A summer special offer Buy two get one free of the exi-450 kit and 3d-pro blades .
Old Jul 10, 2010, 01:07 PM
Wren1702 is offline
Find More Posts by Wren1702
Now Wren 1701
Wren1702's Avatar
Wren, MS
Joined Jul 2005
Kin, Any updates on the 600 Size UH-72A Lakota?
Wren1702 is offline Find More Posts by Wren1702
Old Jul 10, 2010, 01:15 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
yes! it landed in a airport in USA !the airport name www.scaleflying.com it have only 4 piece in the first batch .So you must order to Cliff asap. it is super light germany epoxy made . you are the lucky guy ! Because the 600 mm narrow scale blades are completed same time !!
Old Jul 10, 2010, 01:30 PM
kin is offline
kin
kin
Composite factory
Joined Sep 2007
scale blades list
Now we have the scale blades list is : 700mm Seahawk/Apache swept tip ,700 mm eurocopter round tip ,600 mm Apache/SeaHawk tip ,600 mm eurocopter round tip , 430 mm straight , 310mm Apache /black hawk swept tip ,310mm straight . The 600 and 700 mm will post in website soon . Now are the flying test only , it successful the screw force test in over 800 lb .
Old Jul 10, 2010, 02:38 PM
Wren1702 is offline
Now Wren 1701
Wren1702's Avatar
Wren, MS
Joined Jul 2005
I've been in contact with Cliff via phone and e-mail, didn't know if you had shipped the helis to him yet.
Did you leave out the windows in the clam shell doors?
Old Jul 10, 2010, 09:01 PM
Hoverup is offline
Find More Posts by Hoverup
2013 GRAND SPORT CORVETTE
Hoverup's Avatar
Golden Gulf Coast
Joined Jul 2002
Outstanding timing, as I need a set of the swept tip blades for my TFModel/SmartModel big Jayhawk and 600 size Apache AH-64.
The chassis for the Jayhawk is being assembled using a CastleCreations 110HV ESC,CC HV Pro BEC, 10s 6400mah Lipo packs and a 600rpm/vdc Xera 4035/2Y V2 BL motor with a 10 tooth pinion.
Should be a sweet setup for a big scale model with four blade head and four blade tail.
Hoverup is offline Find More Posts by Hoverup
Discussion Trex 450/500/600 and Honeybee King II in same pic anyone? turnbui Micro Helis 0 Mar 15, 2008 10:18 PM
Discussion Looking for a cheap 500-600 size brushless Jupeli Power Systems 33 Mar 02, 2007 05:42 PM
Wanted Inflatable Floats for Trex 450 and 600 size helis ShokWaveRider Aircraft - Electric - Helis (FS/W) 0 Feb 12, 2007 07:54 PM
Discussion Trex 450 - Trex 600 Size Comparison mrfirkin Mini Helis 3 Aug 26, 2006 09:18 PM
high-rate NiMH button cells Capacity mAh: 120,400,450,500,600 GKP27 Scratchbuilt Indoor and Micro Models 2 Jun 21, 2003 06:03 PM
