Old Dec 15, 2010, 12:05 AM
RogueTitan is offline
Find More Posts by RogueTitan
Foam Av8r
RogueTitan's Avatar
In Teh Garage (Rossville, GA. USA)
Joined Sep 2008
I just ordered a 11" 3 blade prop for my scratch built F4U Corsair
which should set it off!
I was wanting to make a request for larger sized variable pitch props maybe sizes 12" to 15" for my larger sized foamies
I am going to build 1/8 scale foamy Corsair and a 11" prop would be too small I would need something like a 14" or 15" prop
RogueTitan is offline Find More Posts by RogueTitan
Old Feb 21, 2011, 11:43 PM
DaveBC is offline
Find More Posts by DaveBC
Obessive Compulsive
Visalia, California
Joined Mar 2010
Any chance of seeing larger sizes of these? i.e. 13 thru 16 inch. My Hanger 9 corsiar .60 size would love one of these
DaveBC is offline Find More Posts by DaveBC
Old Feb 22, 2011, 08:37 AM
Jason Cole is online now
Find More Posts by Jason Cole
RCG Staff Member
Jason Cole's Avatar
United States, TN, Nashville
Joined Oct 2003
Not that I've seen. They only offer parkflyer electric props at the moment.
Jason
Jason Cole is online now Find More Posts by Jason Cole
Administrator
Old Nov 15, 2011, 03:38 PM
The6uest is offline
Find More Posts by The6uest
United States, GA, Conyers
Joined Jun 2011
Flyboone, when is HL supposed to get more of the 4 blade 11x10 props in stock? I've been waiting a few weeks and they are still unavailable. I've signed up to be notified when they're in stock again but I wonder how much longer it will be. I am planning to use this prop on a P47 kit I'm building.
The6uest is offline Find More Posts by The6uest
Old Nov 17, 2011, 03:14 PM
RCG Staff Member
Jason Cole's Avatar
Joined Oct 2003
Not sure when the next order is due. We do have the blades available though, just need to order two sets. http://www.hobby-lobby.com/spare_2_b...32897_prd1.htm
Administrator
Old Nov 17, 2011, 03:28 PM
The6uest is offline
Joined Jun 2011
Thanks Flyboone. I thought about doing that and buying the hub all separate but it would cost more that way. I may do that though if it doesn't come in stock soon because I'll want to test it when my motors come in.
Old Dec 14, 2011, 01:30 AM
ISI_ is offline
Find More Posts by ISI_
BelgiŽ, Vlaams Gewest, Kapellen
Joined Jun 2010
is it possible to make a pusher prop with these?
ISI_ is offline Find More Posts by ISI_
Old Dec 14, 2011, 09:18 AM
RCG Staff Member
Jason Cole's Avatar
Joined Oct 2003
You can use them in a pusher setup by take the prop off and putting it on backwards while still spinning the motor clockwise. There is no way to make a counter-rotating set though.
Jason
Administrator
Old Feb 01, 2012, 07:41 PM
The6uest is offline
Joined Jun 2011
Jason, have these props been tested for a safe maximum rpm? I have a 1000kv motor and 3S battery that I would like to use with the 11x10 4-blade prop and want to be sure that's not too much. I can limit the throttle if I have to.
Also I hope you get some more in stock soon! They said due December last year then due end of January and they still are out. I got the hub and blades separate already but it doesn't come with the stuff to adjust the pitch. I am guessing that only comes in the set..
Old Feb 02, 2012, 10:09 AM
RCG Staff Member
Jason Cole's Avatar
Joined Oct 2003
Hey,
We haven't tested them for Max RPM. We just recommend them for use in applications for 480 size motors and smaller. That Kv seems fine, what size motor is it? and what size airplane?
Jason
Administrator
Old Feb 09, 2012, 10:27 PM
The6uest is offline
Joined Jun 2011
I am planning to use this Turnigy motor and the plane is an approximately 1/12 scale P47 with a 35" wingspan. I may reduce the max throttle if it pulls too many watts.
Old Feb 10, 2012, 01:00 PM
RCG Staff Member
Jason Cole's Avatar
Joined Oct 2003
That will likely be just fine. If you want a better quality motor with great service and support, check out our eRC motor line here http://www.hobby-lobby.com/erc_motors_279_ctg.htm
Administrator
Old Mar 19, 2012, 10:16 PM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
I ran my 4 blade at 400 watts. held just fine.
capt soap is offline Find More Posts by capt soap
Old May 15, 2012, 08:49 PM
The6uest is offline
Joined Jun 2011
I hope more of these props come in stock soon! It seems like every month they are "due late" that month or the next month. Maybe some will finally come this month because I'm having to use other props while waiting for it to come back in.
Old Nov 02, 2013, 10:16 PM
jviss is offline
Find More Posts by jviss
jviss's Avatar
United States, MA, Westborough
Joined Oct 2013
Will these ever be in stock again?
jviss is offline Find More Posts by jviss
Sold 2 x VarioProp 3-Blade variable pitch Hubs for 4mm shaft and 9" blades CustomPC Aircraft - Electric - Power Systems (FS/W) 9 Jul 25, 2006 09:34 AM
AFPD and variable pitch props rc-eflyer Simulators 5 Mar 05, 2005 11:00 AM
Variable pitch props? Mopar92 Parkflyers 6 Dec 18, 2004 03:38 PM
variable pitch props for RC? Viper2000 Power Systems 11 Dec 18, 2003 05:49 PM
3-4 blade prop recommedation for Scorpio/Astra Spitfire pjsmith Power Systems 1 Sep 29, 2003 03:59 PM
