Old Mar 09, 2009, 05:41 PM
rapmoz is offline
Find More Posts by rapmoz
rapmoz's Avatar
deep south of France
Joined Sep 2004
whozit engine ?
I wonder if this one comes directly from the OS factory and I should be curious to drop a glance inside...
http://cgi.ebay.co.uk/OS-Max-80-TWIN...742.m153.l1262
rapmoz is offline Find More Posts by rapmoz
Old Mar 09, 2009, 09:33 PM
Rubidium is offline
Find More Posts by Rubidium
Austin, Texas U.S.A.
Joined Mar 2008
I wonder how the conrods are missing each other???
I guess you could have one rod with the bushing in the middle but not having the pistons move opposite of one another would kind of defeat the purpose of having a twin.
Rubidium is offline Find More Posts by Rubidium
Old Mar 09, 2009, 10:17 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I doubt that runs. I might be that only one cylinder works.
Here's one of these types of twins that actually runs.
HP 21 VT Twin Testrun (0 min 53 sec)
gkamysz is offline Find More Posts by gkamysz
Old Mar 09, 2009, 10:36 PM
earlwb is offline
Find More Posts by earlwb
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
That can't work, unless it is a single with a fake cylinder on one side.
Fora two cycle engine, both pistons have to travel to TDC and BDC in unison in order to work. So that engine has both pistons 180 degrees out of phase with each other. Thus it cannot suck air fuel in, nor pump air fuel into the combustion chambers with any efficiency.
The cylinders would need to be offset so that each has its own separate rod journal so the engines can be set to 180 degrees apart.
My first thought was a photoshopped engine pic.
But then one could simply reverse one engine half from the other since both ends bolt on.
But like you mentioned, one really needs to see what they did inside.
They possibly could have machined a new special crank with offset rods too. So that both pistons moved in sync for BDC and TDC.
earlwb is offline Find More Posts by earlwb
Old Mar 09, 2009, 10:45 PM
Jeffery is offline
Find More Posts by Jeffery
And You're Not
Timbuktu, Mali (Happy?)
Joined Oct 2002
The crank intake timing would be sort of problematic it seems to me (although I haven't taken the time to diagram it out). With the front housing being rotated 90 from "normal" no matter what cylinder you are looking at, the timing is probably going to be out of whack for both.
Jeffery is offline Find More Posts by Jeffery
Old Mar 09, 2009, 11:00 PM
Kmot is offline
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Same fellow made a twin VT61. I never heard of the VT61 before.
HP 61 VT Flat Twin -Testrun (0 min 50 sec)
Kmot is offline Find More Posts by Kmot
Old Mar 10, 2009, 12:15 AM
706jim is online now
Find More Posts by 706jim
http://www.youtube.com/watch?v=eR0ky...eature=channel
It sounds as if both of those twins are firing at the same time, unlike, say, an O.S. 160 or 300
706jim is online now Find More Posts by 706jim
Old Mar 10, 2009, 09:52 AM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
I have VT.61 in my collection. They are rather unusual. I don't think Mecoa ever produced this size. I think I asked Randy once, maybe the tooling was lost or damaged.
I've gotten into model engineering and on my list of twin projects is an inline two stroke using Norvel .061 pistons/liners and an inline twin using OS FS-30 or 40 parts. I have many things to build before I get to that. The Solidworks models aren't even started yet. Probably next winter at the earliest.
Greg
Old Mar 10, 2009, 10:49 AM
[IMG]OS 48 block casting[/IMG] This was modelled with Catia. I hear that Solidworks is similar.
Old Mar 10, 2009, 10:56 AM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Looks good what are you doing with it? I'm working on drawing the FS-30 head. I needed to check some internal clearances prior to modification.
Greg
Old Mar 10, 2009, 11:13 AM
Greg
I own an O.S. FS 40 marine engine that I've installed in a Dumas model boat. A friend of mine really liked it and wanted to buy one. However, the are now out of production, so I figured that maybe I could machine the fins off and install some sort of water jacket for him. This was as far as I got! There is very limited space for the jacket due to the pushrods between the crankcase and the head. I have the use of a machining center and will eventually make something that screws together. (Have patience Dan!!)
The whole thing was reverse engineered using a protractor, scale and vernier caliper, so is not "true" to the original O.S. design dimensions.
Fun exercise though.
Old Mar 10, 2009, 11:48 AM
earlwb is offline
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
The twin VT61 uses a 4 cycle engine. He only needed to adjust the camshafts to get both cylinders to work. The piston on the downstroke sucks in the air fuel mixture when the intake valve opens.
A 2 cycle engine uses the crankcase bottom end to suck air fuel in and push air fuel into the combustion chamber. If you have one piston going out and the other piston coming in at the same time, then you don't have the engine acting as a 2 cycle engine anymore. So he must have something clever for the crankshaft inside in order to get it to work.
But then who knows, the thing might actually run with the two pistons 180 degrees apart on a single common rod journal. I remember lots of engineers saying things won't work, and a modeller builds it and it does. Sort of like the Bumble bee can't fly myth.
But I suspect if it runs OK, then the builder has a fancy dual rod journal crankshaft inside.
Old Mar 10, 2009, 12:08 PM
gkamysz is offline
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
That's how I do my reverse engineering. I had a chance to buy two of the FS-40 marines not too long ago. I shouldn't have passed them up. I'm not a boat guy, but do collect some engines. I have the itch to try a boat. I actually have a couple hydros I need to get rid of. I got them from a guy with a pile of airplane stuff. I think the old FS-40 has more room around the cylinder to fit a water jacket, compared to an FS-40S or FS-48.
My project list is very long. It includes a marine diesel conversion of an FS-120. I was thinking it would make for a mild powerplant in a 48"(?) deep vee I have sitting around.
Here's a Norvel .074.
Greg
Old Mar 10, 2009, 12:15 PM
Kmot is offline
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
I have both a VT21 and a VT49 in my collection. I had never known of the VT61. Now I must have one!
Old Mar 10, 2009, 12:31 PM
Ed Cregger is offline
Find More Posts by Ed Cregger
United States, GA, Ringgold
Joined Oct 2005
Greg
I had, ran and flew the VT.49 plain head. Nice engine after one siliconed the shank of the carb to seal it up.
Easy starting, wonderful idle and transition. Power wasn't bad, but it was heavy.
I was ticked when I found out that there was a .61, but that it wasn't sold much here in the US.
Still, the .49 was an interesting and novel engine. It used to gather a crowd at the flying field because of the loud whirr of the gears driving the cylinder head's rotary valve.
Ed Cregger
Ed Cregger is offline Find More Posts by Ed Cregger
