Old Mar 08, 2009, 01:23 PM
BLG11 is offline
Find More Posts by BLG11
Joined Feb 2009
CMP J3 Piper Cub 120 91" Review and Instructions
Has anyone purchased and flown this plane who could talk to its quality and flight? Anyone find existing reviews or a copy of the manual? I am looking for a cub and this is the perfect size, but I can't find much info on it.
Any information would be appreciated. Thanks!
BLG11 is offline Find More Posts by BLG11
Old Apr 19, 2009, 10:36 PM
Erwin Z is offline
Find More Posts by Erwin Z
Erwin Z's Avatar
México, Jalisco, Guadalajara
Joined Sep 2006
Hello,
I am laso looking information on this plane, I have a SPE 26cc gasser, V 2., this new version has the carb at the rear of the engine and a pitts style muffler which also goes to the back of the motor. those changes make the engine longer but slimer than the previous version., I want to mount it on the CMP j3 cub
I would like to know what is the distance from the firewal to the hole in the cowl where the prop goes.
will appreciate your info.
Erwin Z is offline Find More Posts by Erwin Z
Old Apr 19, 2011, 11:18 AM
lmeidl is offline
Find More Posts by lmeidl
Joined Mar 2011
Okay, this is an old thread, but for those who stumble across it I'll update it. i have the CMP 91" Cub and it was easy to build, but the instructions are the usual Chinese quality, so use common sense when building it. I had heard that most CMP models were a bit heavy, so I decided to go with the lightest 20cc gas engine I could find...the 20cc DLE. it just so happens to be inexpensive and powerful as well. This cub came in around 11.5 lbs fully completed and flies like a dream. Plenty of power for full vertical flight, but looks and flies great at 1/4 throttle for nice scale appearance. It lands slow and soft. DO NOT USE the O-rings supplied for the main gear suspension...rubber bands or springs (like I use) are fine, but the supplied O-rings will fail on the first flight.
lmeidl is offline Find More Posts by lmeidl
Old Apr 19, 2011, 11:21 AM
lmeidl is offline
Joined Mar 2011
This is not the "Best built - best looking - best supplied hardware" type of kit. It is inexpensive, but will fly good if built correctly. DO use 2 servos for elevator as it has the servo tray setup that way even though in the instructions, it says to just use 1. I would replace the tail wheel (as I have) , but you can use the original and if it fails, switch to a better one later.
Old Apr 19, 2011, 11:28 AM
lmeidl is offline
Joined Mar 2011
Don't get me wrong...the finished plane looks very nice and flies very nice and I love it, but if your looking for the very best built ARF out there...this isn't it, but then again I paid $227 for it and it's been well worth more than that.
Old Apr 23, 2011, 11:56 PM
kerwin50 is offline
Find More Posts by kerwin50
kerwin50's Avatar
winston mo
Joined Oct 2006
That is a nice plane and set-up
kerwin50 is offline Find More Posts by kerwin50
Old May 02, 2011, 08:14 AM
lmeidl is offline
Joined Mar 2011
Well, I have about 2 hours of actual flight time on my Cub now and I can give you a full report now. It flies very well and lands soft and easy...easier than any trainer I ever had. I'd even recommend it as a good plane to fly for a new pilot who has only flown a trainer before. The only thing to worry about is to watch the rudder use on takeoff. If you use too much rudder, it will snap roll (tip stall) on takeoff. I have my rudder down to just 40% throws and it's plenty. I can even fly knife edge with the 40% rudder.
Old Oct 13, 2011, 07:46 AM
markog7 is offline
Find More Posts by markog7
Joined Oct 2011
Construction manuals for giant J-3 CUB 91"
I have the same question - does anyone have a pdf, jpg, png... file of a Piper J-3 CUB 91" instruction manuals, parts list...etc. handbook for me or any usable link or place to download it? In the giant package, there was NOT neither papers for construction manuals with descriptions to complete. Would be greatly appreciated.
markog7 is offline Find More Posts by markog7
Old Oct 14, 2011, 11:42 AM
JoeR is offline
Find More Posts by JoeR
USA, NY, Jamestown
Joined Jun 2000
Is this the same plane? Not much information provided on the web page. Not even a photo.
http://www.scaleflying.com/ARF-Scale..._c_11-2-4.html
JoeR is offline Find More Posts by JoeR
Old Oct 17, 2011, 09:30 PM
1320fastback is offline
Find More Posts by 1320fastback
Detroit 2-stroke junkie
1320fastback's Avatar
USA, CA, Oceanside
Joined Jul 2008
I maidened one for a friend this last weekend.
A few things I noticed were that the rudder is super powerful and the suggested throw is more than adequate.
You NEED to fly coordinated when turning. If you don't know what this means- search.
Landings are best done with a few clicks of power and slight "up" pressure on the elevator. You can easily land tail wheel first if you want.
1320fastback is offline Find More Posts by 1320fastback
Old Nov 02, 2011, 10:10 PM
fredo21 is offline
Find More Posts by fredo21
Never too much detail
fredo21's Avatar
Australia, VIC, Hampton
Joined Jan 2007
CMPRO Cub 91 Manual
http://www.hobbyking.com/hobbyking/s...X228638X52.PDF
Stuart
fredo21 is offline Find More Posts by fredo21
Old Nov 16, 2011, 09:04 AM
parambir is offline
Find More Posts by parambir
parambir's Avatar
United States, WI, Evansville
Joined Aug 2008
Hi all, I have a J3 Cub 120 and have mounted OS 160 on it. A bit overkill with 18x8W but believe me, she is a beauty. I have flown it extensively and just love this bird. I would not mind going in for 1/4 Piper and have two in the hangar Here is a video link to my piper flight.
piper low pass (1 min 11 sec)
Piper.avi (5 min 58 sec)
Cheers...
Parambir
parambir is offline Find More Posts by parambir
Old Apr 24, 2012, 08:30 AM
nalby is offline
Find More Posts by nalby
Professional Toothpick maker
nalby's Avatar
USA, NY, New Hampton
Joined Jan 2005
I'm real interested how you mounted the dle20 in planning on doing the same on mine. Did you have to do any mods to get it to fit?
Thanks Jim
nalby is offline Find More Posts by nalby
Old Apr 27, 2012, 05:32 AM
Big Nuts 181 is offline
Find More Posts by Big Nuts 181
Big Nuts 181's Avatar
Joined Jul 2004
Hi guys this is a great little plane a good value for money, I mounted an ASP 180 methanole 2 stroke and used it for glider towing for a while but it's great fun to putt around and then freak everyone out when you pull verticle and punch out through the clouds in a split second or drag a 5 meter model at 45 degrees +
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old May 19, 2012, 04:47 PM
nalby is offline
nalby's Avatar
Joined Jan 2005
Well here's mine dle-20 I had to open up the cowl because it was over heating, I don't think it looks to bad. Flys great loads of power even with those 20 oz's of dubro 6" inflatables.
WORLD MODELS J3 Piper Cub (Electric) guapoman2000 Parkflyers 380 Apr 03, 2010 01:08 PM
For Sale J3 Piper Cub 120 - 91" Engine Powered Scale bcdiscount Aircraft - Fuel - Airplanes (FS/W) 0 Nov 12, 2007 10:56 AM
Wattage 46" J3 Piper Cub jstanton Electric Plane Talk 9 Jun 24, 2003 04:09 PM
Kyosho Piper Cub EP - short review icebear Sport Planes 4 Jun 04, 2003 09:00 AM
71in J3 Piper Cub Conversion take off.....Yes! Magna Scale Kit/Scratch Built 0 Aug 28, 2002 12:17 AM
