This thread is privately moderated by skywarp1, who may elect to delete unwanted replies.
Old Mar 07, 2009, 10:44 PM
skywarp1 is offline
Find More Posts by skywarp1
Long live the Nuge!!!
skywarp1's Avatar
South Central......Kansas
Joined Oct 2007
New additions...
Since my last blog I have added a few new birds to fight line and one in particular, the Alfa P-47, is an absolutely amazing aircraft. First off though let me say that I have long since put some time on the Scorpio FW-190 and I love it! It is a great plane and smooth flier even with the fixed gear which I just don't mind at all. I am going to swap out the stock wheels though with some Du-Bro wheels the next size larger for the grass field I fly from and see if that makes landings any better.
Now for the Alfa P-47. The same power set up I used in the FW-190 I used in this bird. I put the BP 2212-13 motor, with an 18 amp ESC from BP (the 190 actualy has a Turnigy 25 amp ESC), and a 3s 1250 mAH Lipo all turning a Master Airscrew 9x6. With the exception of the ESC, this is a winning brushless combo for me for foamies 40" ws and smaller. I have flown my Alfa several times now and it is fast! With the battery I am using I get 12-15 minute flights easy. I never have to take it above 1/2 throttle, in fact the last flight I cruised around at 1/4, going to 1/2 for loops and rolls. The airframe tracks straight and needs very little trim. I will buy Alfa's again.
Next up is my Great Planes Hellcat that I had wanted for quite some time and finally got. I must say this little bird was quite the headache during assembly simply because of that small battery hatch. Then there was the matter of balancing it with a lipo instead of a heavy nimh. The maiden didn't go so well either with the elevator control quick link disconnecting from my servo arm resulting in a nose dive. The damage was minimal and repaired in an hour or so. After that the flying was pretty good although I am going to try a higher pitch prop next time out and see if I can squeeze a little more out of the stock motor. I figure if my Fun Force Hellcat (which has the same motor) with a 10 x 7 SF on little 640 mAH lipos can give me a 5 1/2 min flight, then I should be ok.
And finally, I lost my mind and invested in a Freewing F-15. I bought the airframe only and put together my own power system based on lots and lots of research. Once I got the airplane, I opened the box and when I seen how freakin' awsome this is going to be, I began to wonder if I got in over my head. We shall see.
That's all I got for now. Nose up, wings level, have a blast. L 8 R
Ken
skywarp1 is offline Find More Posts by skywarp1
Discussion New additions to fleet! KLH Parkflyers 12 Jun 19, 2007 11:17 PM
Discussion Couple new additions - Stout JW60 and Light XR infopimp Slope 6 Jun 25, 2006 09:52 AM
New additions... (Sidewinder, F-20 , Skua) stegre Slope 18 Oct 27, 2004 08:20 PM
