Old Mar 20, 2003, 09:32 PM
thazy2 is offline
Find More Posts by thazy2
thazy2's Avatar
Pueblo Colorado
Joined Mar 2002
Whats the difference? 72mhz or 75mhz
I'd just found out that the TWO piece mini dean antenna i'd installed on my ep concept is 72mhz when my 8U radio is 75mhz.
What will happen to performance?
I understand that they also has a ONE piece thats for 72 and 75 w/ the same spec.
thazy2 is offline Find More Posts by thazy2
Old Mar 20, 2003, 11:15 PM
rc-eflyer is offline
Find More Posts by rc-eflyer
T:W>1= :>)
rc-eflyer's Avatar
St. Louis, Missouri, United States
Joined May 2002
thazy2,
In the US 75Mhz is for surface vehicles only and
72Mhz is for aircraft only. I've never seen an
8U on 75Mhz
rc-eflyer is offline Find More Posts by rc-eflyer
Old Mar 21, 2003, 12:13 AM
thazy2 is offline
thazy2's Avatar
Pueblo Colorado
Joined Mar 2002
You are right!
I guess i was having one of those senior moment.
I'd looked and looked.....all i saw as 75 the first time...
Old Mar 21, 2003, 12:28 AM
hstewarth is offline
Find More Posts by hstewarth
Charlotte NC
Joined Feb 2003
I am curious if a 9CHP could be use for R/C Boats. I notice some are ar AM .
hstewarth is offline Find More Posts by hstewarth
Old Mar 21, 2003, 01:10 AM
T:W>1= :>)
rc-eflyer's Avatar
Joined May 2002
This one can http://www.futaba-rc.com/radios/futj89.html
or, you can purchase a 75Mhz RF modulator if you already
own a9CHP
Old Mar 21, 2003, 01:36 AM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Lets try the Radio Forum?
If you ae reffering to the black Revolution antenna. I have been using them for a year or so with no problems.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Mar 21, 2003, 08:42 AM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
AM and FM have absolutely nothing to do with whether a radio can be used for a boat, car, or airplane. AM and FM are simply different ways of sending the signal from the transmitter to the receiver. There are AM and FM versions of car, boat, and airplane radios.
Frequency is the important factor. In the USA and Canada, radios on the 72MHz band are for airplanes only, and radios on the 75MHz band are for cars and boats only. To use the wrong frequency is dangerous. Say someone is flying a park flier in a park. Some clueless chap comes in with a car, except he's using an airplane radio he had left over from an unsatisfying attempt at flying airplanes. Both radios just happen to be on the same frequency. As soon as the car guy turns his radio on, the park flier goes out of control and crashes into someone or something.
The 9CHP has a replaceable frequency module. You can install a 75MHz frequency module and use your 9CHP with cars and boats. You will also need a 75MHz frequency crystal for the receiver, and it is a good idea to get the receiver tuned by Futaba Service, so it's reliable.
mkirsch1 is offline Find More Posts by mkirsch1
Old Mar 21, 2003, 12:40 PM
Charlotte NC
Joined Feb 2003
rc-eflyer and mkirsch1,
Thank you... that answers my question.. I understand the difference of 72 and 75... I was thinking maybe of getting a boat and want to use my 9CHP. Swapping out the module would be fine. The boat would have a different set of reciever and servos..
I am not sure if I get on, but I got the 9CHP for expandability in future.. Currently a major overkill for my Corona and even a bigger over kill for a boat.. I belive boat only use two channels...
Old Mar 21, 2003, 02:07 PM
T:W>1= :>)
rc-eflyer's Avatar
Joined May 2002
Thank you... that answers my question.. ..
For what the modulator probably costs I bet you could get
a whole simple ground or boat system
Old Mar 21, 2003, 02:20 PM
thazy2 is offline
thazy2's Avatar
Pueblo Colorado
Joined Mar 2002
Fred...
I mean the TWO piece deans that you can order from Litemachine. The one piece works for 72 and 75. But the two piece works only w/ 72. Why?
If your using the 9 w/ 75mhz module, will the range be greater than a deticated 75mhz car radio?
rc-eflyer.....
If your using it for a small slow little boat, two channels works ok. But if you are able to use the 9 for fast high power boats, you can other channels for trim tabs remote adjustment which is very useful and convient (using micro servos of course to save weight). You would not need to stop the boat to make these minor adjustments for different water conditions.
Jason........
Old Mar 21, 2003, 10:33 PM
T:W>1= :>)
rc-eflyer's Avatar
Joined May 2002
Originally posted by thazy2
Fred...
rc-eflyer.....
Jason........
I agree and only mentioned the price thing since hstewarth
said the 9C was "overkill" for him.
Discussion Whats the difference 9C or 9C Super v6focus Radios 1 Aug 16, 2006 09:20 AM
J plug or S plug, whats the difference? Fiasco Parkflyers 5 Jun 05, 2005 12:12 PM
Mega/Phasor or Kontronic/Hacker Whats the difference? Phoenix-IT Electric Heli Talk 6 Feb 02, 2002 11:54 PM
