Old Nov 18, 2009, 06:00 PM
arniebud is offline
Find More Posts by arniebud
United States, FL, Pensacola
Joined Oct 2006
Thought it time to jump back in. I picked up an Escapade from the scratch and dent listing on Tower a while ago, and used some of my left over parts from my first one.See postings #31 and #124. This time I set it up using a Evolution 46, and balanced out with just 2 oz. of weight. What a sweet flying plane!! Plenty of power, almost unlimited vertical, and just glides in for landing. When I assembled, I fit 2 additional magnets, salvaged from small brushless motors, to the rear of the canope. All I do is place the canope in position, and the magnets pull it closed. It stays there throughout the flight.
arniebud is offline Find More Posts by arniebud
Old Nov 19, 2009, 11:14 PM
jriley1974 is offline
Find More Posts by jriley1974
Angry Flyer!
jriley1974's Avatar
washington state
Joined Oct 2008
no problems with my canopy...are you forgetting to slide the canopy forward? I know when I flip my prop and hold on to the canopy that it sometimes slides back disengaging the latch.
response to post 150
jriley1974 is offline Find More Posts by jriley1974
Old Nov 23, 2009, 06:08 AM
Hewey19 is offline
Find More Posts by Hewey19
Hewey19's Avatar
USA, MI, Lansing
Joined Aug 2009
I assume your 2 oz of lead was in the front? I am trying to decide if I want to go with a .46 or something in the .50 range.
Hewey19 is offline Find More Posts by Hewey19
Old Nov 23, 2009, 09:07 AM
pmmartin is online now
Find More Posts by pmmartin
Fly Every Day
pmmartin's Avatar
United States, FL, Sebastian
Joined Apr 2001
Not much of a difference here?
pmmartin is online now Find More Posts by pmmartin
Old Nov 23, 2009, 03:25 PM
Hewey19 is offline
Hewey19's Avatar
USA, MI, Lansing
Joined Aug 2009
An OS .46ax or an OS .55ax is what I meant.
Old Nov 23, 2009, 05:25 PM
arniebud is offline
Joined Oct 2006
I used a steel block and mounted it to the firewall just below the engine mount. I also use a standard 600mAh nicd battery, up front along side the fuel tank. I am sure that if I switched to a 2000 mAh pack, mounted in the same location as the weight, that would also balance out without any additional weight.
Old Nov 25, 2009, 06:11 AM
kingsflyer is online now
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
Originally Posted by Tommy D View Post
Has anyone found a motor brand <Rimfire aside> that will mount right up to the Escapades factory wood box?
Both the E-Flite Power 46 and Turn 50-55 are a no go.
Hyperion also NG.
Thoughts?
Tommy
I'm flying mine with a Turnigy 3548 1100kV and it fits perfectly. I just had to enlarge the TR X-Mount holes a little to match up with the kit blind nuts. I'm even using the stock spinner and I've got about 1/8" clearance to the cheek. I fly with a 12x8E APC prop, a 3750 3S 20C Rhino pack and a 60 amp ESC with switching BEC. No CG problems with this setup. I've had no problems with the hatch, but you need to be sure and slide it back to engage the magnets.
McD
kingsflyer is online now Find More Posts by kingsflyer
Old Dec 03, 2009, 03:00 PM
Kbofwy is offline
Find More Posts by Kbofwy
non-recovering R/C addict
Wyoming, USA
Joined Dec 2004
Can someone measure the battery/tank compartment, please? Looking to see if a 3" wide by 5" long flat 5s a123 pack will fit. Thanks.
Kbofwy is offline Find More Posts by Kbofwy
Old Dec 03, 2009, 03:40 PM
_HypnoToad_ is offline
Find More Posts by _HypnoToad_
_HypnoToad_'s Avatar
Joined Jul 2007
Hope this helps...
(The side crack was from a bad start with a chicken stick and is now fixed)
Tim
_HypnoToad_ is offline Find More Posts by _HypnoToad_
Old Dec 03, 2009, 06:01 PM
Kbofwy is offline
Wyoming, USA
Joined Dec 2004
Excellent, thanks Tim! That helps a bunch. Looks like I could squeeze my battery in there.
Old Dec 07, 2009, 06:39 PM
pmikeyg is offline
Find More Posts by pmikeyg
I try...really I do!
Dover, DE
Joined Apr 2008
This plane is the best money I have spent in a long time! It is a blast to fly. I am using a Super Tiger right now, but I may step it up to a 46 AX. Awesome plane! Great Planes needs a 60 size now.
pmikeyg is offline Find More Posts by pmikeyg
Old Dec 12, 2009, 11:21 AM
YarSmythe is offline
Find More Posts by YarSmythe
Addicted to RC
YarSmythe's Avatar
USA, TX, Houston
Joined Nov 2003
It's a Christmas Miracle !!!!
My LHS just called and said my Escapade cowl that has been on back-order since April arrived today!! Yippee!! I'll be heading over there later and posting photos soon!
THAT was a long wait. Hope all of the others out there waiting can get their hands on one soon. Tower Hobbies now shows them "In Stock".
-Lee
YarSmythe is offline Find More Posts by YarSmythe
Latest blog entry: Velcro Debate / Poll
Old Dec 12, 2009, 11:38 AM
flylower is offline
Find More Posts by flylower
"That's too low!"
Kokomo, IN
Joined Jan 2009
WOW!! And I thought I had a long wait. Mine's been on backorder since July, and it was shipped yesterday. I hope it was worth the wait...
flylower is offline Find More Posts by flylower
Old Dec 12, 2009, 05:15 PM
mustangaddict is offline
Find More Posts by mustangaddict
La Réole Field
mustangaddict's Avatar
Verdelais (France)
Joined Dec 2009
The Escapade is really the plane I was waiting for to begin aerobatics programs
My Escapade is powered by an old 40 OS MAX FS and to my mind, it is the right formula to get confidence in the aerobatics training. I'had never flew a drag tail plane before and the first take offs and landings looked like if a drunk pilot was holding the sticks , but now the plane goes straight.
I put a Sullivan tail wheel bracket that works well, and I add 1,15 OZ of lead under the engine mount to reach the perfect balance. I placed the battery inside the Canopy hatch to let the tank room clear (in case of a fuel leak) and I made a window over the receiver to check the right plugs position. I recently made a hight speed spin and everything was O.K. after I've landed...
The 40 OS MAX has new spares and delivers the perfect power to fly the plane at the right speed when you want to do aerobatics in a limited area, and the Escapade is able to do stiff curves without loosing height; so I'm very happy with both the model and the engine.
Here are some photographs of my Escapade :
Description: [ATTACH]Name: 014.jpg
Description: [/ATTACH]Name: 014.jpg
Description:
mustangaddict is offline Find More Posts by mustangaddict
Old Dec 12, 2009, 05:38 PM
Addicted to RC
YarSmythe's Avatar
USA, TX, Houston
Joined Nov 2003
It's so pretty!
I can't believe I'm this excited about a motor cowl. Should make this plane look a lot sharper.
Great Planes Escapade...has anyone flown? research_guy Beginner Training Area (Aircraft-Electric) 5 Aug 05, 2002 11:33 AM
Great Planes Escapade dave_lilley Electric Plane Talk 0 Nov 15, 2001 11:57 PM
Great Planes Escapade dave_lilley Site Chat 0 Nov 15, 2001 11:57 PM
Great Planes Escapade, a sweet little ARF! Paul Penney Parkflyers 9 Sep 18, 2001 10:13 PM
Great planes Escapade Paul Penney Foamies (Kits) 0 Sep 09, 2001 06:38 PM
