P-51B model
Take a look at this graphic. Open to feedback, critique', and commentary.
These aircraft have longer nose so we have to watchout from making it nose heavy. I still have to place the aileron servo, but figure the battery has to go on top with a low mount wing. Also could add a cavity for the esc and rx with a tape on cover cut into one of the outer nose laminations. This would clean up the appearance alot. I am thinking to reshape the outer and intermediate lam's as well. Ken
Latest blog entry: MPF M6 Mermaid Scratch and Kit Built
I definitely like the cleaner appearance. Like the Parkflyer pete multi layer fuses. gpw made the inner layer mostly cut out with minimal webbing, on 3 layers. With 5, one can get really creative!
Latest blog entry: OSE One Sheet Edge 540 Video
Now I am thinking with the internal space potential that I can cut a pocket for the aileron servo into the fuselage and mount it inverted but above the wing. I would like to keep the servo horn above the wing to maintain the natural differential that occurs there.
Ken
Jimmy,
It would be possible to build these with dihedral. I would leave that to the builder though. I think it would look better with a little dihedral and it would give it a little more roll stability. The hatch could be taped or magnet held in place. Ken
150 watts per lb.
These birds are not heavy or lacking performance. Power to weight ratio is 150 watts per pound. Thats no slouch. As far as the P-51B design goes, the amount of material is about the same as the other designs, maybe less. The motor is still wider than the fuselage at 5 laminations. This will be robust and light and nearly all your gear is concealed. Still using strapping tape top and bottom of wing at back of KF step and packing tape on the LE of the wing. Ken
FW-190 Plans
Here are the plans for the FW-190. Wingspan is 29-7/8" with 150 sq. in. wing area.
Ken
Joined Aug 2004
Okay, so far after getting the sq. in. of material out of the SketchUp files heres how they stack up.
P-64 = 421 Zero = 459 Bearcat = 480 Sea Fury = 494 P-51B = 538 sq. in. Now the Sea Fury has 152 while all the others have 150 sq. in. of wing area. I wieghed a 100 sq. in. sample of material and got 12.3g that calc's out to 14.4g difference from lightest to heaviest. I believe we could get some more material out of the Mustang on the core laminations. Ken
Lenox, Michigan
Joined Nov 2005
Ken,
Have you considered setting up a table at the Toledo show? I bet if you took 100 Combat Kits you would sell every one of them at $10 a piece. Pay off that Iron Printer! If it was me i would probably think about taking the rest of the week off and get a ton of them cut out! Seriously I know i have been talking a lot about weight and stuff but either way they are great classic designs with a nice twist that i have not seen anyone use for these type of designs. Make a D on that P-51 and i will take one. |
| Thread Tools | |
| Cool Not so new plane, finally found a name | David Forbes | Hand Launch | 5 | Feb 12, 2009 01:10 PM |
| Visited NPM, in France and I could not resist.... got a new EPP Plane | Patrick Plawner | Foamies (Kits) | 58 | Apr 02, 2003 06:11 AM |
