Help setting up a 5 blade head.
First off it looks like I have to have everything reversed in my radio. Down on the swash is up on the blades and left is right. I also need to ether turn all the links way shorter or move the swash clamp down. One more I have seen other heads and the swash clamp is about 1/4 or more off. Keeping the links all at a angle. Mine seems to be just a little off, this could be why the links are to long.
Latest blog entry: Logo build
Thank' alot guys this page is going to became my 5 blade setup bible.
This tail is from the venom night ranger and has the largest of all electric drives, but if it comes down to it not working I will just get a brushless motor and larger prop.
Ok I worked on the head today and I think I got the anti rotation arm set good for now. Wow it was way off. In the pic the blades are set as flat as I could and the anti rotation arm is just slightly up.
Joined Oct 2007
yes it's darthdrks 450 size CH-53.
One other question? If at the most I will only have 1 to 2 degree negative pitch why would I want the anti-rotation bracket level at 0° pitch? I would thing you would run into less binding by having the anti-rotation bracket level at +2 or +3° pitch
Here are some close ups of the head. I got it off ebay for $109. Took all the links off and checked all the blade holders. They were all smooth and everything was overly loctite. I had to us a lighter and pliers to get one of the balls off.
I would think that if you wanted to have it level at 4° it should be OK.
The reason level at 0° is so that you would have full travel to lets say -10° to +10° and it would be in the center at 0° pitch. So if you run -2°+10° the center would be at +4° Which means I should re-adjust mine, since I am now running at -2.5°+11° |
| Thread Tools | |
| Discussion I need help setting up my Blade 400 - Central Ohio | Blue Jacket | Mini Helis | 7 | Aug 10, 2008 05:19 PM |
| Discussion Need help setting up align gyro on blade cp | possumtrot | Micro Helis | 2 | Mar 09, 2007 11:33 PM |
| Question Need help setting up blade w/GY401 | landmlord | Micro Helis | 3 | Nov 03, 2005 08:38 PM |
| Help setting up RD6000S with ECO8 | JohnnyV | Electric Heli Talk | 4 | Jul 27, 2001 09:37 PM |
| Help setting up Demoiselle | Jim Winget | Parkflyers | 2 | Jul 03, 2001 10:06 PM |
